Old 02-04-2017, 07:37 PM   #15
BRZnut
Drives: BRZ DGM Limited
I hear it on the video. Sounds like plastic touching plastic. You need someone else to drive while you put pressure on any place where parts are coming together in the dash.
Old 02-05-2017, 08:25 AM   #16
scirocco78
Drives: Scion FRS
I had this problem. I bought a package of felt from Home Depot. Removed the gas pedal and made a felt gasket. Placed this under the gas pedal and now the noise is gone.
I learned about it here:
http://www.ft86club.com/forums/showt...al#post2817589
scirocco78 is offline   Reply With Quote
Old 02-05-2017, 11:13 AM   #17
I had a terrible buzzing (meaning I could hardly hear it) and after much searching by my son in law while I drove around he found it was the speaker cover on the dash. I was convinced it was way back in the door someplace so would never have found it on my own. I just gave it a good smack with my hand and it went away (the buzz not the son in law).
Old 02-05-2017, 11:23 AM   #18
Cole
Not a troll
Cole's Avatar
My drivers side dash speaker cover buzzes like crazy when it's cold out. Maybe I'll give it a good whack today.
Old 02-05-2017, 03:06 PM   #19
humfrz
Reminds me of the time, waaay back in the day, one very cold winter night, back in CT, that the first mrs humfrz and I were leaving a party.
Now, our 1970 MGB never would warm up inside in the wintertime, the mrs humfrz was bitching about being cold, I had consumed waaay too much whisky to be driving, and I was lost (errr .... temporarily disoriented - an Army soldier never gets "lost").
(in my defense, upcountry in CT, isn't much on street lights or road signs)
The dash started squeaking and buzzing ....... and that tore it ...... so, I gave it a really good whack with my iron like fist ...... and it quit making noise.
However, when we finally arrived in our garage, I noticed this long crack that ran the entire width of the dash ....... but, it didn't squeak anymore .....
humfrz
Old 02-05-2017, 10:35 PM   #20
Impureclient
Drives: 2015 FR-S
Tried the foam/felt under the accelerator assembly. Didn't fix it.
Impureclient is offline   Reply With Quote
Old 02-05-2017, 11:44 PM   #21
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
The dash needs to be removed. It is a combo of the way the ducting mounts/overlaps. One half of the ducts has been deformed on everyone I have taken out. New ducts won't help as its a shitty/cheap mold. They need to be taken apart and foam insulation added to remove movement. I have fixed 4 or 5 including mine.
LavosTRD is offline   Reply With Quote
Old 02-06-2017, 01:04 AM   #22
Impureclient
Drives: 2015 FR-S
How long does that take to remove and reinstall?
Old 02-06-2017, 10:13 AM   #23
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Originally Posted by phrosty View Post
I may have the same thing. Sounds like something is swinging around when on a bad road at low speeds. Took the dash apart last week and didn't find anything that looked unusual, but I'm no expert.
Only happens on cold days (like, below freezing cold).
Mine is more of an incessant "tapping" sound, as if something was loose and tapping on the windshield glass. It taps and taps and taps, over every single bump in the road, but even if the chassis so much as flexes a little bit. It is infuriating because it simply doesn't stop. Happens only when it's really cold, and therefore hasn't happened in a few weeks now, as it's been warmer lately up here.
You ever heard of Chinese Water Torture? They strap you to a board and drip water onto your forehead until you go insane and crack.
This is what that is like. It doesn't bother me for about the first 5 minutes, but after that, I'm nearly ready to rip my dashboard out to make it stop.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 02-06-2017, 10:49 AM   #24
mazeroni
Drives: 2013 Scion FR-S Series 10
The static sound? Like what happens with an Iphone is next to a speaker and receives a text? It is hard to tell what you mean but I did notice the "electronic sound."
If that is what you are talking about, I get that all the time. I couldn't tell you the specific circumstances because I keep my music turned up so I don't have to listen to all the rattles, bangs, tapping, vibrations, clunk-clunks, etc.
I think it normally occurs when in a higher gear and you put the engine under load around 1.5-2K rpms.
mazeroni is offline   Reply With Quote
Old 02-06-2017, 11:41 AM   #25
ChimpMania
Drives: 2014 WRB BRZ 6MT
mine does a tapping sound...so i bang on it a few times and it goes away then comes back sometime later
ChimpMania is offline   Reply With Quote
Old 02-06-2017, 11:49 AM   #26
JD001
JD001's Avatar
Drives: Subaru BRZ
Too much 'whacking' and 'banging' for my taste.. I keep thinking that cars built for America/Canada are manufactured to a lower quality as I don't get any buzzing or other noises from my dash.
Old 02-06-2017, 06:22 PM   #27
Gunman
Drives: 2019 Mazda Miata RF
I searched all over my dash for a noise, and it wasn't in the dash at all. Screws in the rear view mirror adapter were backing out, and the shape of the glass caused the sound to appear in the dash.
Gunman is offline   Reply With Quote
Old 08-23-2021, 09:00 PM   #28
iag48st
Drives: 10Series 0945
Ive been dealing with this buzz for a long time now. It's not the gas pedal because it occurs off or on throttle. Today I stuffed a t-shirt and some foam under the dash behind some metallic box thinking that may be the source but Its still there.
If I reach under and pull the thick cables towards me the buzzing stops so it has to be something with those cables. I also thought it might be something in the door panel, also read somewhere that the window tint may be peeling off and rubbing against something.
iag48st is offline   Reply With Quote
Buzzing at 2.5k rpm oppiee Issues | Warranty | Recalls / TSB 9 03-06-2017 09:22 PM
Light buzzing sound from driver-side dash BRZprime Issues | Warranty | Recalls / TSB 51 08-21-2015 09:34 PM
High rpm buzzing noise Frsultramarine15 Scion FR-S / Toyota 86 GT86 General Forum 21 11-13-2014 01:58 PM
Buzzing speakers FRS_Sovereign Electronics | Audio | NAV | Infotainment 8 06-09-2013 02:41 PM
exhaust buzzing 3k to 4k input please! ft86me Engine, Exhaust, Transmission 11 03-24-2013 01:02 AM
