Old 07-13-2012, 10:41 AM   #15
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
This is exactly what I want. Simple and elegant yet (hopefully) functional and no CEL's or MAF misreadings.
Old 07-13-2012, 10:52 AM   #16
chadz
chadz's Avatar
Drives: 2013 brz limited
Yes, this is all after the maf. Its the same size as stock and same routing. I like the stock intake and plan on keeping it. Not worried about heat soak because the pipe is so short and the air in there doesnt stay long enough to get hot. Most aftermarket intakes are aluminum. I do plan on adding a apexi filter and getting it tuned. It does growl a bit and I dont know if its a placebo effect but throttle response seems better. I also did the tb coolant bypass but i doubt that does anything.
chadz is offline   Reply With Quote
Old 07-13-2012, 12:40 PM   #17
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by ahausheer View Post
Air pressure doesn't work like that. There are aftermarket intakes that will cause a check engine light if the ECU is not reprogrammed. Ill bet this intake is fine but there is a possibility that the MAF readings are off. The engine can adjust using other sensors but with the complex D4-S and high compression I would personally be concerned. Also the fact that the spark plug change interval is so low tells me you don't want to mess with the air fuel mixture as it already seems like a very sensitive thing. But I am no expert and I am often overly cautious when it comes to stuff like this so don't take my word for it.
Those intakes make changes around and before the MAF. This is after the MAF. The only way for energy to travel upstream to disrupt airflow around the MAF would have to be some sort of resonance. But all of the stock resonators are still in place.
Old 07-13-2012, 12:43 PM   #18
MarkRacerX
MarkRacerX's Avatar
Drives: 12' Evo X , prior 1st 86 FR-S
Looks much cleaner! Nice and simple, thanks for sharing!
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few:
12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi,
08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV
MarkRacerX is offline   Reply With Quote
Old 07-13-2012, 12:49 PM   #19
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Clean looking! If you can record the sound would be great.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 07-14-2012, 06:16 PM   #20
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I was going to do something similar with 3" silicone brake duct hose as I've done before with my Integra, but you've made me want to try this out; I just ordered the parts to prototype a similar setup. Had to go with 2 different vendors (Silicone Intake Systems and Votion Speed) because the stainless silicone joiner wasn't available from Silicone Intake (out of stock). Total Cost ~ $100 ($21 of that shipping). Once I get it in and assembled I will post pictures and video. Should look really clean with the stainless T-Bolt's, no metal joiner exposed at all, and Silicone Intake's custom Silicone Port System for connection to the stock breather hose.
Wanted to go with blue silicone but they were out of the 3" 90-degree elbows, so black silicone it is...
Vracer111 is offline   Reply With Quote
Old 07-15-2012, 01:45 AM   #21
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
where did you get those hoses ?
looks good
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 07-15-2012, 02:52 PM   #22
chadz
chadz's Avatar
Heres a quick clip [ame]http://m.youtube.com/watch?v=2qHtmHYBC8I[/ame]. Car's running good. Drove about 200 miles and no CEL. I got the hoses from ebay. Vracer, looking forward to yor setup. Keep me posted and thanks for the comments.
Old 07-15-2012, 03:22 PM   #23
xcelir8brz
Drives: 2013 BRZ Limited
Can you make the video public?
xcelir8brz is offline   Reply With Quote
Old 07-15-2012, 07:23 PM   #24
chadz
chadz's Avatar
Sorry about that. Its public now. Ignore the girl in the background lol. I will try to kake a better vid.
Old 07-15-2012, 07:36 PM   #25
White64Goat
A specific list of the vendors on e-Bay from whom you bought all your items from would be especially helpful and what each supplied (part numbers would be a plus too). Thanks
Your set-up looks really nice, clean and hopefully foolproof. (No CEL's etc.)
Old 07-15-2012, 08:23 PM   #26
xcelir8brz
Thanks.
Working on a kit of my own. Should have parts by weeks end in which next weekend I'll fabricate at least two variations. I think I should have something together that will rock. R&D baby!
Old 07-16-2012, 02:03 PM   #27
chadz
chadz's Avatar
I got the hoses from this vendor. http://myworld.ebay.com/boomautoparts/ but any 3inch 90 degree elbow and coupler will work. You just have to cut it to fit. The pipe, I got done from a local shop Wired in Linden, NJ. Vendors will probably come out soon. I know AVO has one but it still retains the sound tube. Good luck xcelir8. Please post pics and video when you're done
Old 07-16-2012, 02:05 PM   #28
Turbowned
Turbowned's Avatar
Simple, effective, and best of all, inexpensive! Good job
Nameless Performance Track Pipe Installed MTeator Engine, Exhaust, Transmission 46 09-15-2013 08:57 PM
New intake? Mo707 Engine, Exhaust, Transmission 13 07-10-2012 05:55 PM
X-Pipe with Muffler delete dav0777x Engine, Exhaust, Transmission 3 06-21-2012 10:30 AM
Intake resonance pipe? tranzformer Engine, Exhaust, Transmission 20 12-05-2011 04:09 AM
