Old 01-17-2017, 04:42 PM   #15
Kendallkab
Drives: Black MT LMT BRZ
Originally Posted by renfield90 View Post
Double check that your front sway bar isn't making contact with the control arms. This happens on some twins, especially when lowered. The solution is shorter endlinks.
To hell with the torque spec on the endlinks, get them on as tight as you can with a socket or wrench. They like to come loose. If you want to definitively identify this as the source of the noise, drive around with them disconnected.
Double check torque on the two strut bolts - you actually want the torque wrench on the nut, not on the bolt. I've made this mistake and they came loose due to lack of torque, I like to overtorque by ~5 ft-lbs here.
That's the conclusion me and my friend came to.. I have a another friend who has drove over 10k miles on his coilovers for his frs with the popping noise so I'm not worried about it anymore. My plan now is after I get wheels to get adjustable endlinks to hopefully make the noise go away. Thank you guys for all the suggestions and help!
Kendallkab is offline   Reply With Quote
Old 01-17-2017, 05:07 PM   #16
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Did you throw any loctite on the nuts that attach the camber plates(tophat) to the strut tower assembly of the car( fronts have 3, rear have 2). Most coilovers you only use between 15 to 25 ft/lbs when tightening these nuts down. And, while your car sits on the ground you likely wont notice if they become loose.
And as you hit bumpy pavement, you will hear a metal on metal popping sound. In other words, the top of your coilover is floating and not tight. So, if you didnt apply some loctite to each of the those nuts, they can easily loosen up and cause your exact symptoms. Just a thought, and very easy to check and fix.
And make sure you have the nuts torqued to spec.
Good luck.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following User Says Thank You to brzaapi For This Useful Post:
Kendallkab (01-17-2017)
Old 01-17-2017, 05:32 PM   #17
Kendallkab
Good luck.
I did not throw any loctite on them and they are torqued that was the first thing I checked.. I'm going to check the top hats before anything.. thanks boss
Old 01-17-2017, 06:27 PM   #18
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Installing coilovers in a few hours. Anything I should know?
Your stock suspension is much better?
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
ChaosTheSlayer (01-19-2017)
Old 01-17-2017, 06:33 PM   #19
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Good to know. Still smart, and horribly easy, to go back and throw some blue thread locker on those puppies. I always do it now, when installing coilovers. And i have learned that lesson from experience.
Daily: Audi TT RS
Old 01-21-2017, 12:26 PM   #20
MyGT86Yas
Drives: 2017 WRB BRZ
How did you tighten the top nut? What is a strap tool?
MyGT86Yas is offline   Reply With Quote
Old 01-23-2017, 06:16 PM   #21
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
pass through socket and hex?
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
finch1750 (01-24-2017)
Old 01-23-2017, 06:27 PM   #22
ryoma
ryoma's Avatar
you can buy a strap tool from Sears for like $10. you tighten the top nut with a pass through socket and allen wrench (I would use a set of pliers to hold the allen wrench. use the pliers to hold the short end of the wrench horizontally while you use the long end to insert into the hex on top of the shock)
http://www.sears.com/tools-wrenches-...s/b-1214364373
use the strap wrench to hold the shock shaft (the shiny metal part)
Old 01-23-2017, 06:36 PM   #23
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Interesting search results there, Sears:
Originally Posted by humfrz
I'm old and lazy
The Following 5 Users Say Thank You to Clipdat For This Useful Post:
8RZ (01-24-2017), finch1750 (01-24-2017), MarkR171 (01-23-2017), ryoma (01-23-2017), Tcoat (01-23-2017)
Old 01-23-2017, 06:40 PM   #24
ryoma
ryoma's Avatar
LOL I didn't even look that far down
Old 01-23-2017, 06:56 PM   #25
renfield90
The Stig's German cousin
I tried the strap tool and found it unsatisfactory for me. I use a deep offset box wrench like this: https://www.pegasusautoracing.com/pr...oIHBoCQrXw_wcB
Harbor Freight sells an ok-ish set that is deep enough to get into the stock top hat.
Old 01-23-2017, 07:08 PM   #26
ryoma
ryoma's Avatar
have you tried flipping the strap around? I was using the strap tool on the wrong side and kept noticing it slip. after I flipped the rubber (or whatever material it is) strap around, it gripped extremely well. it also helps to have a buddy around to help out
Old 01-23-2017, 08:22 PM   #27
Old 01-24-2017, 01:48 AM   #28
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Pass through socket and wrench like was said. I will add the vice grips or locking pliers of some kind are very helpful so you dont have worry about keeping pressure on multiple ways
***NEED SOME HELP IN THE NEXT FEW HOURS IF POSSIBLE??*** NorCalGirl Northern California 1 01-21-2015 06:39 PM
Help installing coilovers eSOLOR Northern California 13 12-16-2014 01:51 AM
Installing Coilovers in Las Vegas bobsacamenoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-09-2014 10:14 PM
Crap lights on my dash after installing coilovers. Eelusive BRZ First-Gen (2012+) — General Topics 43 02-12-2014 02:08 PM
32 Hours 7 Minutes Wes B. Other Vehicles & General Automotive Discussions 11 12-26-2012 10:10 AM
