#15 | |
Ahhhh.......yes, back-in-the-day, as several remember, just use two 9\16th inch wrenches and adjust the clutch linkage. Have we made progress or what .... ![]() humfrz |
#16 | |
Drives: 2013 FR-S 10 series [755]
Thanks |
#17 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
My guess is the TOB as well...
With the clutch depressed, does the "hissing" sound like water flowing through pipes? |
#18 |
One big detail is missing, does this sound occur only when the engine is running?
If the problem is isolated to the hydraulic mechanism, then the sound should also occur when the engine is off as this is an independent system. (I agree bleeding this system every couple years is still recommended). If the sound occurs only when the engine is running, it might be related to the throw out bearing. This bearing is only loaded when the clutch pedal is depressed, and will only make noise when its spinning. It could also be the clutch fork, when you operate the clutch pedal, you can see the slave cylinder pushrod extending and retracting to move the top of the fork, these surfaces may be dry or something. Something in my own clutch system squeaks when I move the pedal and I suspect it's this interface, but I haven't been concerned enough with it to investigate it yet. |
#19 | |
not playing cards
On yours, the main pivot is dry.
#20 |
The guys have it covered so I will just leave this here and stroll away.
#21 |
#22 |
watch out for an RKO outta nowhere
#23 |
not playing cards
If you pull the boot (gotta pull the slave cyl) you can get a dab in there with your finger/screwdriver. Jiggle and repeat.
#24 | |
if its the TOB,,then i am fk ... so frustrating looking for the problem....all problem occurs start when winter comes... |
#25 |
#26 |
#27 | |
not playing cards
#28 | |
| Hissing/rattle from 3.5-4k RPM after OFT | illmatic_frs | Engine, Exhaust, Transmission | 28 | 03-21-2017 08:02 PM |
| Clutch noise new to-day | Skye | Issues | Warranty | Recalls / TSB | 16 | 11-19-2016 11:42 AM |
| clutch grinding noise | BoxerBlock88 | Engine, Exhaust, Transmission | 13 | 11-14-2015 06:12 AM |
| Clutch scraping noise | 8 six | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 01-05-2015 02:39 PM |
| Winding Noise From Clutch | Bach415 | Northern California | 0 | 06-24-2013 07:19 PM |
