Old 01-13-2017, 01:16 PM   #15
DAEMANO
Time Traveller
Originally Posted by 504 View Post
Why? Ethanol is a natural solvent and the gunk is probably it picking up deposits from normal fuel with all the additives it contains. I've got a picture on one of my posts of my injectors after 7000 km pure E85 and they looked immaculate.
My Perrin catback has only seen ethanol and even that has literally no black deposits
Ethanol is awesome!
The one tankful was done as a precaution for a $30K investment not rated to run as a FFV, not an ideology. I'm very happy with the way my car has run and held up on e85 if I didn't make that clear enough.
Old 01-13-2017, 02:33 PM   #16
g0lds
Drives: 14 BRZ Limited
Do a Google search for "E85 black beard" or "E85 black goo". Theories state that its because E85 is stored in stations' old diesel tanks and the black beard is the E85 degrading the lining of the old diesel tanks. Again just speculation. Regardless, E85 black goo is definitely a real thing. I ran E85 on my DSM for about 30k and my injectors were nearly completely covered.
Best practice is to run one tank of 93 every few fill ups as stated before. I plan on doing one tank of pure 93 to use up the remaining E85, one 93 with Chevron Techron fuel system cleaner, and one final tank of pure 93 to use up the rest of the Techron.
g0lds is offline   Reply With Quote
Old 06-14-2017, 04:14 PM   #17
Lantana frs
Drives: 13 frs red
Hate to bump old threads but e85 has made me appreciate this car more than ever. Imo 93 in the south Florida heat makes my car feel like shit, especially with ac on.
Lantana frs is offline   Reply With Quote
Old 02-06-2018, 05:04 AM   #18
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Question
Since Lantana set a precedent, I'll necro bump this thread too.
When you guys run a tank of 91 every now and again, do you flash back to a 91 tune or just mix that tank with the old tank (not a complete fill up- like fill up when you have a half tank of E85 left)
Old 02-06-2018, 12:26 PM   #19
Submarinesonce
Drives: Frs
I've switched to 100% e85...and I don't plan to switch back honestly.
However, don't mix fuels if you don't have a flex fuel kit. If you're on e85, and want to run a tank of 93, then run it all the way down, fill with 93, and flash the 93 tune.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 02-06-2018, 04:48 PM   #20
supercommode
supercommode's Avatar
Drives: 2017 Toyota 86 860 Special Edition
When I installed headers, I switched to E85. It was great great except for the mileage. I drive almost 100 miles a day and I have only found 1 pump close to where I live. Nothing close around work. I did have a little trouble with some cold starts (30F), but there is a noticeable difference in power between the 2 fuels (E85 and 93). Wish there were more pumps, I would use it more often.
supercommode is offline   Reply With Quote
Old 02-07-2018, 04:52 AM   #21
guybo
Huge E85 fan!
guybo's Avatar
I'm runing down my last tank of 93 then I'm switching to E85 this week. The only problem is that there's only 2 stations close to my commute to work or where I drive. None near my home (at all!) and several way out f the way. But I'm going for it, I'll just have to stop and fill up twice a week.
I'm not going to run a tank of 93 every month and re-flash. But I do plan to start using a bottle of 2 stroke oil in my fuel every few tanks.
Old 02-07-2018, 10:19 AM   #22
Submarinesonce
Drives: Frs
Thorntons has had consistent, and high content e85 in our neck of the woods, I use theirs exclusively. for what its worth, I did a UOA after my first full e85 oil change interval (7000 miles on the tune total at the time) and it came back great.
Old 02-07-2018, 10:38 AM   #23
bababooey
Drives: BRZ SWP Limited -6MT
thats interesting considering it was recommended to change slightly sooner @ like 5k mi. ive only ran a tank or two when first got my tablet w/o header. im waiting for premium prices to go thru the roof or have access to easier oil changes (apartment life) before committing to e85.
Old 02-07-2018, 11:26 AM   #24
Submarinesonce
Drives: Frs
7000 miles on the tune total, changed oil at 5
Old 02-07-2018, 12:26 PM   #25
bababooey
thanks for clearing that up.
Old 02-07-2018, 01:18 PM   #26
Teseo
Drives: frs
This thread is useless until someome tear down the engine after had run at least 50k miles and inspect tolerances etc
Old 02-07-2018, 03:06 PM   #27
Submarinesonce
Drives: Frs
yeah.....no one is going to do that. If its running well, making good power, and used oil is coming back without excessive wear products/degredation, then im going to call it good.
Old 02-07-2018, 07:27 PM   #28
guybo
Huge E85 fan!
guybo's Avatar
There's a Thorntons on the way home from work, it's hwere I'll get my E85 most of the time. the other place is a Speedway.
I can't find the thread (I saw it yesterday too, I drove myself nuts trying to find it!) buut someone did an engine break down after extended E85 use. He said the engine looked great. I think he broke it down to rebuild due to engine miles.
AP Racing "Sprint" BBK long term update CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 90 06-18-2016 10:58 PM
E85 long term update texasbound972 Engine, Exhaust, Transmission 21 05-17-2014 02:05 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
