#15 |
Drives: Toyota GT86
Thanks for all the replies. Ok, I found the thread from Celek. 2.3 liter is more like it.
As far as I can tell he is not done with it yet?I suppose a build like that is more like 10k+$ and an endless amount of time investment. Will be very curious to see what kind of power that can make. Would a less extreme version be doable for normal human beings and on a more limited budget? Like sleeves to increase the volume but on stock crank and some head work to increase the rpm?
#16 |
I think heads/cams/intake manifold that make power north of 8000rpm (and rockers that don't blow apart) are the key to making big gains NA. The manifold gets interesting with runner lengths and the distance between heads.
#17 | |
Drives: UK GT86
.: Stealth 86 :.
#18 |
...Just add nauseum
Drives: 2003 (AP1) S2000
Intake runners are your obstacle for revs.
The head needs no work for a budget NA build. The stock valvetrain will hold up reliably to right around 8k as long as it's not a '13 motor... Oh, and around 8,400 the oil pump gives up anyway. Even with sleeves you're only getting .1 liters out of overboring. Not worth it without increasing the stroke. JUN proved that simply shortening the runners at stock diameter carries the torque curve up by several hundred RPM, which reflects as a proportional increase in power. Something I have said for years. If I was doing a budget NA build on an FA20, it would be ACE header, tuning & flexfuel, stock unopened motor, make (or have made) a custom aluminum intake manifold with shorter runners... Think 15mm shorter. A simple one with tubular runners, hand milled flanges, and a sheetmetal plenum. Tuning on ECUTEK with a rev limit of 8000. Throwing blind darts, I'd bet very safe money on 210 peak WHP on pump gas. 200 if you didn't touch the intake manifold... (But then you wouldn't raise the rev limit because there's no point doing that NA until the intake manifold is addressed. Moving an identical torque curve to the right is what makes the extra peak power.) Oh, and it's worth mentioning I'm speaking in terms of repeatable, uncorrected dyno numbers on an accurate machine. E85 is getting into guesswork territory but I figure another 5-8% ...Any reasonable amount of extra money would buy you only disappointment. Beyond that, the classic Subaru exhaust ports are going to be the choke point that becomes a hard limit. Now here's the caveat. Find someone similarly knowledgeable who disagrees with me... And isn't trying to sell you a product.
There are many ways to displace.
-Spartarus Last edited by Spartarus; 12-16-2016 at 02:08 PM. |
#19 | |
Drives: Track preped NA FRS
#20 | |
...Just add nauseum
That would put it between an NA build and a low-budget FI build... And between those two, I know which one I would be willing to thrash on a track without the constant fear of blowing it up. Oil cooling is the only additional necessity for track use. Buying the actual JUN manifold will set you back over 2k, and then we're getting into FI-money territory... But it makes power with proven theory that holds up in the real world, not smoke-and-mirror snake oil bullsh*t.
-Spartarus |
#21 | |
Resident Gear Head
But time and money are a constraint. I have been working with a couple companies on being able to have them offer a kit at less of a cost. The issue is you have 1 set of rods/pistons made at a time the cost is 20% higher than having 5 sets made at once. Keep your eye out on the market you may see a more affordable version of mine for around $3500 in parts to make a 2.3 liter
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
#22 |
Anti stance.
Kinsler needs to make a proper ITB setup.
#23 |
Drives: Subaru BRZ / Toyota 86 Experts
Piper Cam installed.
#24 | |||
Drives: Toyota GT86
And if having a 2013 engine (like I do) what needs to be changed? Quote:
*edit* Is it this you mean? http://www.junauto.co.jp/products/su.../index.en.html Quote:
#25 | |
Drives: Toyota GT86
#26 | |
...Just add nauseum
2. Yes, that's the JUN I'm talking about. Here's a link to the original thread. The math in there explains why it works. http://www.ft86club.com/forums/showthread.php?t=110517 3. Yep, leaves ACE and a tune, but it'll do better than you're guessing. Oh, and a drop-in filter if you care... 199 WHP can be done consistently on a normal dyno (not a hero-run on a dyno) on just that... With normal-people pump gas. Every NA hp after that is an expensive diminishing return.
-Spartarus |
#27 | |
Drives: Toyota GT86
I am skeptical about the 199whp on E0, of course, depends on the dyno and stock baseline. That's why I prefer crank hp for comparison. 230 crank with just an ACE header and tune I would suppose is the absolute maximum. 199whp in my baseline would equate to 250 crank.
#28 |
Drives: Lightening Red BRZ Ltd.
All this NA talk makes me
I wonder how much capable the 17 motor is with the headwork, cams, and intake manifold from the factory is... |
| NorCal shops for engine builds? | Cacksta | Northern California | 5 | 03-06-2016 12:30 PM |
| all season high performance or winter performance tires? | Aloxi | NY / NJ / CT / PA | 29 | 03-24-2015 09:23 PM |
| Engine Builds-Reviews | tg_1981 | Forced Induction | 17 | 01-13-2014 05:19 PM |
| Engine Builds-reviews | tg_1981 | Engine, Exhaust, Transmission | 3 | 01-12-2014 09:14 PM |
| High performance and race engine oil tests | Kamran | Tracking / Autocross / HPDE / Drifting | 16 | 02-10-2013 12:06 PM |
