Old 12-12-2016, 02:29 PM   #15
whataboutbob
AutoX-10/10ths every run
Originally Posted by mitch t View Post
How was the FF kit to install?
I assume pump and injectors?
Man I really want to pick up another engine to build a little bit.
Do you have any thoughts on compression ratio, if I'm looking to go "big" , power wise?
The kit is very easy to install. I'd contact Delicious Tuning directly and discuss. They can provide guidance on what is needed to support the FF kit at your desired power level.
Build thread:Here
Old 12-13-2016, 04:13 PM   #16
How big?
Old 12-23-2016, 11:16 AM   #17
scraejtp
Drives: 2013 Subaru BRZ
Originally Posted by wparsons View Post
One thing to watch with a twin screw blower is how the tune works down low if you start cranking up the boost. A turbo or centrifugal blower will build boost linearly and not try to load up the engine too much at lower rpm. A twin screw blower can be much trickier to tune down low and can blow an engine easier even if the peak hp is the same.
Turbos being known for building boost linearly, great joke.
scraejtp is offline   Reply With Quote
Old 12-23-2016, 01:44 PM   #18
Bfranklyn86
Drives: GT86 Harrop S/C
Although it makes sense to suggest that mid range torque from the twin screws should blow more engines, is that actually what has been demonstrated on our platform? Since I've been paying attention (not that long admittedly) I've seen no blown cosworth/harrop/edelbrock set ups and only a couple of sprintex ones (which are known to run hot).
I anecdotally hear of far more turbo and centrifugal SC set ups going bang than the twin screw.
Bfranklyn86 is offline   Reply With Quote
Old 12-25-2016, 08:32 AM   #19
wparsons
wparsons's Avatar
Talk to any tuners that have tuned the bigger sprintex blower...
flickr
Old 12-25-2016, 03:50 PM   #20
Yoda
Drives: Crystal Black BRZ(Sophia)
Have not heard of any JRSC casusing any catastofic engine failure. Correct me if I am wrong.
Yoda is offline   Reply With Quote
Old 01-04-2017, 06:02 PM   #21
whataboutbob
I have a buddy that had a JRSC C30 on a stock motor that shoved #3 rod all around making swiss cheese.
Build thread:Here
Old 01-05-2017, 09:56 AM   #22
Yoda
Welp then there is that.
Old 01-06-2017, 04:55 PM   #23
mitch t
mitch t's Avatar
Drives: stx class lava frs
I'm not sure one broken engine is really evidence of anything. if it becomes a trend, that is another matter...
i know folks that could break an anvil, so no matter how good you make your stuff, someone is going to figure out how to wreck it.
mitch t is offline   Reply With Quote
Old 01-06-2017, 06:40 PM   #24
Irace86
Drives: BRZ + Ducati M796
Seems like these power threads pop up all the time, and the conversation is the same. Ugh.
Irace86 is offline   Reply With Quote
Old 01-07-2017, 08:58 AM   #25
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
thats because folks don't like the answer
Matt@Cosworth is offline   Reply With Quote
Old 01-07-2017, 03:00 PM   #26
strat61caster
strat61caster's Avatar
If you're willing to divulge, was that an off the shelf setup or one that was pushing more power?
Keeping a close eye on the CARB legal FI kits, one is probably in my future when I'm satisfied with my autox adventure.
ineedyourdiddly
Old 01-07-2017, 07:07 PM   #27
whataboutbob
It wasn't an off the shelf kit. Stock boost but had a FF kit.
Build thread:Here
Old 01-09-2017, 05:14 PM   #28
mitch t
mitch t's Avatar
Not sure what you guys are getting at.
My OP was asking what I can expect reliably w the stock bottom end and fuel system, (sounds like about 300max) and what the blower would be capable of with a built bottom end and fuel mods (probably more than I need)
I don't want to spend a bunch of $$ on a tune, only to find that it either doesn't make much power, or is too aggressive and causes an engine failure.
Nor do I want to build a motor and fuel setup, if the blower is running out of headroom to take advantage of it.
I think everyone has been pretty informative, and all their answers seem pretty reasonable to me.
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
FS: BNIB Edelbrock Supercharger Avo1789 Engine, Exhaust, Bolt-Ons 52 02-03-2017 11:44 AM
EDELBROCK SUPERCHARGER BRZFRSSTORE Forced Induction 1 12-05-2016 04:41 AM
Review: Edelbrock Supercharger Kit NotSoJDM Forced Induction 153 02-25-2016 06:53 PM
Edelbrock supercharger is out. Need expert thoughts on it. stockysnail Northwest 125 09-04-2015 01:51 PM
