Old 11-16-2016, 06:20 PM   #15
Originally Posted by ATL BRZ View Post
Still doesn't explain why his car was relatively down on power for that compression ratio and boost pressure. I'm guessing either the belt or the clutch or both were slipping on the dyno.
Originally Posted by DeliciousTuning View Post
According to the compressor map on these superchargers the efficiency area of these superchargers is up to about 15 psi. The intercoolers are still working really well and the supercharger is not generating too much heat. With that in mind you get a cooler denser charge (more air) which allows the tuner to increase timing, lean it out, play with the cams and make power.
When you start pushing above 15 psi the heat starts to increase dramatically and at 20 psi the supercharger is generating enough heat that the intercoolers cannot quite cut it and so you need to dial the tune back a bit on the top end.
Diminishing returns.
ATL BRZ (11-16-2016)
Old 11-16-2016, 06:28 PM   #16
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Hmmm just wondering why the AFR's seem to be all over the place? And its quite lean?. Would be a blast to drive at that power!
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
Old 11-16-2016, 08:06 PM   #17
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
The location of the wideband was not in the most ideal location for his vehicle; at the tailpipe on one side and we were using it more as a reference during pulls.
We actually use the OEM sensor (which we have rescaled) for more accurate measurements and continuous closed loop fueling.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
Stimmed (11-17-2016), whataboutbob (11-17-2016)
Old 11-17-2016, 01:09 AM   #18
Irace86
Drives: BRZ + Ducati M796
Originally Posted by VIP BRZ View Post
didn't he juts buy a GTR? Blowing an engine on a car he doesn't even drive would only boost his channel views..
I think that was just click bait. He has a fair share of it.
Irace86 is offline   Reply With Quote
Old 11-17-2016, 02:19 AM   #19
FRS Justin
Drives: 2013 Asphalt FRS
Bill you been busted riding in a customers car, now you have to ride in the ft86project9s car no excuses and yes you will be holding a camera. And a go pro facing you.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
CSG Mike (11-17-2016), DeliciousTuning (11-17-2016)
Old 11-17-2016, 02:08 PM   #20
Does that mean he has to also go on track with me now??!?
Old 11-17-2016, 03:50 PM   #21
FRS Justin
Yes sir, I really can't see a way out of it lol
710whp
The Following User Says Thank You to FRS Justin For This Useful Post:
Old 11-18-2016, 03:14 PM   #22
sdot
Drives: 2015 WRB BRZ
Is this set up CARB legal?
sdot is offline   Reply With Quote
Old 11-18-2016, 03:35 PM   #23
chaoscentral
Drives: 2013 Scion FR-S Series 10
Once you remove the CARB tune it is technically not CARB legal. Especially once you go adding E85 into the mix
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
chaoscentral is offline   Reply With Quote
Old 11-19-2016, 02:03 AM   #24
Irace86
Nevermind, he bought a GTR.
Old 01-04-2017, 03:39 PM   #25
DeliciousTuning
Yes he bought one and going to working on a Flex Fuel Kit and tune for his GTR next. Stay tuned...
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
nmastereal (01-06-2017)
Old 03-28-2019, 09:04 PM   #26
casing
Drives: stock
so what kind of numbers can you expect with the stock pulley, UEL and 91 octane?
casing is offline   Reply With Quote
Old 04-12-2022, 03:25 PM   #27
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
is the dyno graph still available? It looks to be removed from the post.
GPhilly is offline   Reply With Quote
Ernest's Flex-Fuel, FBM Stage 2 Turbo, Built FA20-V161 Driven BRZ - PHOTON Enalband24 Member's Car Journals 78 02-04-2020 02:55 PM
Delicious Tuning: Edelbrock E-Force Supercharger with Flex Fuel – Official Dyno Data DeliciousTuning Software Tuning 53 10-19-2018 12:55 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 10:40 PM
Moto-East Edelbrock/Flex fuel Combo -Phil Forced Induction 1 10-21-2016 06:28 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 10:36 AM
