Old 07-12-2012, 02:38 PM   #15
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
I just got mine in the mail today. Not that it's a big deal, but I didn't realize the clear JDM lenses have that little hump sticking out the side compared to the stock ambers being flat. Anyone know the reason for this?
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 07-14-2012, 01:33 AM   #16
spyke
spyke's Avatar
Drives: 2013 BRZ LTD
Just speculation, but the way the pop-out part is cut, it refracts light. Since the sidemarkers are also turn signals on the JDM model (per ayau's information) I assume that this refraction (causing the lens itself to glow) allows the light to be seen from all angles when signaling. Our sidemarkes are only designed to provide visibility of the car and show direction of travel when viewed from the side.
spyke is offline   Reply With Quote
Old 07-14-2012, 02:45 AM   #17
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Aha! Excellent info. I actually didn't realize ours were not turn signals until just now. Lame.
Owner's Journal
Old 07-15-2012, 02:03 AM   #18
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Just wanted to say thanks again for the write-up. Just swapped mine out today and it looks so much nicer now.
Owner's Journal
Old 07-16-2012, 09:05 PM   #19
Drvortex
The WeatherMan
Drvortex's Avatar
Drives: Blue Limited BRZ
Originally Posted by ayau View Post
i bought mine from japanparts.com
you can also look at the vendor section on this forum. a couple of them are selling them as well.
I went to Japanparts.com. Did you just get the lenses or the set to include bulds and socket? I have the limited BRZ and wondering if I only need the lenses. Thanks.
Drvortex is offline   Reply With Quote
Old 07-16-2012, 09:19 PM   #20
ayau
Drives: Some rust bucket
just the lenses. you can buy the amber bulbs at autozone for $5. :happy0180:
Old 07-16-2012, 09:53 PM   #21
Drvortex
The WeatherMan
Drvortex's Avatar
Thanks. I'm looking at those lenses as well. Also, been checking out the bulbs from Meng Motorsports to continue doing some light changes. Still researching the little things until I get enough funds and wait a little longer for the aftermarket stuff comes out.
I'm so looking around for gold rims w/ polished lip. Will be very sexy on a blue BRZ.:happy0180::happy0180:
Old 07-23-2012, 10:19 PM   #22
WithNolock
Drives: Scion FR-S
Success! Thanks for the write up, definitely helped. I used a small flathead screwdriver to unclip the side marker. Seemed to work well.
Result:
WithNolock is offline   Reply With Quote
Old 08-03-2012, 09:11 PM   #23
frs
Drives: frs
wow, it looks so simple but i just couldnt get them out, i tried like 1 hour then i gave up.
i just duno how the thing works, maybe im too dumb for that
frs is offline   Reply With Quote
Old 08-03-2012, 09:23 PM   #24
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
The best spot to pry is between the gray housing on the back of the marker and the car. Doing that will release one clip, making the other two easier. If you look at the OP's picture, pry in the gap to the left of the gray plastic.
Jidonsu is offline   Reply With Quote
Old 08-03-2012, 09:56 PM   #25
frs
Drives: frs
thanks for the tip, ill try that tmr. its dark already here.
Old 08-04-2012, 09:32 AM   #26
Toyobrzu
Drives: Scion FR-S (firestorm)
I'm having a difficult time taking out the original side markers. On my FR-S
Toyobrzu is offline   Reply With Quote
Old 08-04-2012, 05:57 PM   #27
EZWood
BAMF
EZWood's Avatar
I found that its easiest to grab the frnder with one handwhile pushing on the bottom clip with a flat head screwdriver and that allows you to pull the bottom of the light out. Either put something behind of the marker to prevent it from popping back in or hold it with your hand. Then take the flat head while laying on your back, my head was pointed towards the rear of the vehicle, use the new marker for reference to how you need to push on the metal piece to pop the top out and wedge the flat head straight up through the metal clip on the frnder to pop the top out and that will release the third clip simultaneously. Twist out the bulb plug, swap out your bulbs and bend the mounting brackets back into place if necessary and pop the new markers back in bottom first was easier for me.
Old 08-11-2012, 05:07 PM   #28
Hanakuso
Anyone else havin problems inserting the new side markers? Mine doesn't seem to be as snug as it should be. Possibly one of the clips aren't in all the way but I don't see how to make it sit properly
Hanakuso is offline   Reply With Quote
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P BRZ Photos, Videos, Wallpapers, Gallery Forum 109 08-19-2014 10:56 PM
** Toyota Japan FRS and BRZ Clear Markers, Emblems and more ... ** Carson Toyota Exterior Parts - The Rest 308 04-02-2013 11:03 PM
before and after clear markers DEC1 Cosmetic Modification (Interior/Exterior/Lighting) 28 07-07-2012 05:36 PM
FR-S / BRZ side markers interchangeable? Slant Cosmetic Modification (Interior/Exterior/Lighting) 2 06-30-2012 07:26 PM
