Old 10-25-2016, 02:55 PM   #15
shattered_memory
Drives: Satin White BRZ Limited
Originally Posted by twag4 View Post
Whiteline caster correcting bushings. KCA-434 is the part number.
Thanks for the suggestion, but I already installed energy poly bushings for front LCA. I probably should have gotten the whiteline bushings in the first place lol.
Originally Posted by Tor View Post
Some of the other suggestion might help, but the most cost-effective would be slight toe-in at the front. It will make it stay in lane better too, but at the cost of turn-in.
Personally, I'll take a light feel (toe out) and good turn in over heavy steering feel.
With toe, we are talking miniscle differences with large effect. Try 0.05 inch deg toe-in instead of 0.
Thanks for the advice! I want the best in both worlds for turn in and steering weight. I will probably go -2 degrees of camber in front with a little bit of toe out in the front.
Originally Posted by nikitopo View Post
There are some bigger steering bolts and you can change also the bushings. Image of bolts:
After installation it is definetly heavier, but after a few days you'll get used to it ...
After your post, I went ahead and ordered a set of the STI bolts. I currently have energy poly steering rack bushings,but with the stock bolt.
shattered_memory is offline   Reply With Quote
The Following User Says Thank You to shattered_memory For This Useful Post:
nikitopo (10-25-2016)
Old 10-25-2016, 03:13 PM   #16
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
I'm glad I ran into this thread. Last year I got RCE Yellows installed and noticed a huge difference in handling but that was to be expected. I think i noticed the lighter steering the most and i wasn't a huge fan of that. I went back and checked the alignment report and saw that the car had negative toe up front and I had asked to be dialed back to 0 degrees thinking any amount of toe wasn't good. This thread helped answer the question as to why the steering feels so light...not a bad thing but I also prefer just a tad more heavy-ness.
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 10-25-2016, 05:04 PM   #17
twag4
Drives: frs
[QUOTE=shattered_memory;2783015]Thanks for the suggestion, but I already installed energy poly bushings for front LCA. I probably should have gotten the whiteline bushings in the first place lol
Easy to change, and not too expensive. You will get the results you're after.
twag4 is offline   Reply With Quote
Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 Hachiroku BRZ First-Gen (2012+) — General Topics 118 11-16-2017 03:19 PM
[Power Steering/Electrical/Warranty] Problems, could use some advice. Ajax969 Issues | Warranty | Recalls / TSB 7 07-26-2015 08:01 PM
How different is handling with heavier/rep wheels? HachiRo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-28-2015 11:19 AM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-21-2013 12:45 AM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 05:52 PM
