Old 10-03-2016, 01:28 PM   #15
FTA_Dave
Drives: 2013 Frs, E46 Bmw
The rocker panels poorly sealed by the rubber air flap ahead of the rear tire. I recently pulled the interior out of my car and found the rockers full of sand/ salt. I vacuumed an easy 8-10 lbs out of the rockers/quarters/trunk of the car. If you plan on keeping this car for the long term get a winter beater.
FTA_Dave is offline   Reply With Quote
The Following User Says Thank You to FTA_Dave For This Useful Post:
Ultramaroon (10-03-2016)
Old 10-03-2016, 01:43 PM   #16
scmil95eg
Drives: '95 delSol, '13 EvoX, '14 Leaf
Originally Posted by Stang70Fastback View Post
I had a 1998 Subaru Outback that had 286,000 salt-covered winters on it.
That's a lot of winters in 18 years!
scmil95eg is offline   Reply With Quote
The Following 2 Users Say Thank You to scmil95eg For This Useful Post:
ajcarson11 (10-03-2016), Stang70Fastback (10-03-2016)
Old 10-03-2016, 01:51 PM   #17
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by ajcarson11 View Post
Having an intention of keeping my car for a long time
You are a minority. Nice decision!
The Following User Says Thank You to nikitopo For This Useful Post:
Mr.Impreza (10-03-2016)
Old 10-03-2016, 02:00 PM   #18
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Haha, shit. Fixed!
Stang70Fastback is offline   Reply With Quote
Old 10-03-2016, 02:01 PM   #19
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
My car has been through 3 Canadian winters now and it's 4th is fast approaching. I haven't done any rust proofing at this point. I've done lots of work to my car this year and found lots of surface rust in various places. I'll talk about the places that I've noticed and any notes about them:
1. Heavy surface rust on suspension knuckles.
2. Heavy surface rust on hubs, probably because they were exposed with my winter steelies.
2. Completely rusted front sway bar end link nuts and bolts. I had to cut my OEM end links out in order to install my upgraded suspension.
3. Minor spots of surface rust on front and rear subframes.
4. Heavy surface rust on exhaust, completely covered from front pipe to back wheels.
5. Minor surface rust on the bottom of my pinch welds. I suspect this is due to scraping over some particularly nasty speed bumps. I've since learned how to take these bumps without scraping even though I'm lowered now.
I've got a small laundry list of things to do to the car in preparation for next winter so when I'm under the car for that, I'm going to clean up any minor surface rust that is starting and hit it with some corrosion inhibiting paint and hope for the best. I think the parts that are completely covered in surface rust are a lost cause (knuckles and exhaust) and will have to be replaced when they start to fail.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
Old 10-03-2016, 03:43 PM   #20
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
I Krown the p!ss out of mine.
Guru Woodman is offline   Reply With Quote
Old 10-03-2016, 09:59 PM   #21
one2onejackpot
one2onejackpot's Avatar
Drives: 2016 Subaru BRZ Series.HyperBlue
Salt? What's that?
Ha, I love the Steelies! I live in Hawthorn Woods, not too far from Schaumburg. I bought some winter tires for mine just in case, but you'll never see me driving on salted roads unless I have to. My car has all the underbody paneling and isn't even a year old and I've seen rust spots pop up on the bolts last time I jacked it up to make adjustments on my Borla rear diffuser. The front end links were already rusting when I changed out the sway bars a week after I bought the car. I got mine at the end of January, so the dealer could've had it for 3 months. It only had 12 miles on it though.
On a side note, keep that car inside if it hails. If that's not an option, throw something over the all aluminum hood.
LOVE. It's what makes a Subaru, a Subaru.
My 2016 Subaru BRZ Series.HyperBlue Build
one2onejackpot is offline   Reply With Quote
Old 10-03-2016, 10:50 PM   #22
Stang70Fastback
A.K.A. Starlord
Yeah, she has heated indoor parking, and I keep a keen eye on the weather when I'm out and about
What should I do to my car in preparing for a supercharger? djdrugga24 Forced Induction 26 02-21-2016 01:18 PM
Preparing for winter! Elliryx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 09-03-2015 10:14 AM
Preparing for a road trip nickw14 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 05-07-2015 01:42 PM
EcuTek preparing to release PRO ECU software for BRZ Visconti Engine, Exhaust, Transmission 335 08-14-2012 12:34 AM
