Old 09-27-2016, 01:31 AM   #15
shellslinger
Drives: Whiteout FRS
I see what you're talking about. You were talking about adjusting the ride height. You are looking for that spanner wrench that lets you adjust height I'm assuming. You can probably get replacement ones from Megan or buy one online or in store. Also, something is up with your coilovers thats for sure. It seems that @swarb is right about what happened. I'm pretty someone else with better knowledge can help you with the issue of the damper adjustements.
But as far as ride height goes:
I.E. https://www.amazon.com/Aldan-America...0VMJTCMBYJBWEE
Spanner wrench size:
http://www.meganracing.com/tech/faqs...h%20Dimensions
Make sure you read this:
http://www.meganracing.com/tech/?id=75
Or take it a competent shop that knows what they're doing. The clunking sound may be inherent design of the coilovers themselves. I would suggest if you do not know how adjust the ride height I would get a shop to help you out and have them do a once over on the installation to make sure everything is torqued properly.
Make sure you also get an alignment done as well.
shellslinger is offline   Reply With Quote
Old 09-27-2016, 06:54 AM   #16
bryansuriel3
bryansuriel3's Avatar
Drives: Red Brz
I have the spanner wrenches I was the one who adjusted it but it seems that on the right front side of the car the coilover won't go any lower I tried to bring it down then the coil gets loose and I could spin it I have a feeling that it has something to do with the top hat bolt. If you see in the picture I showed of the top hats one of the bolts thread is sticking out. And that's the one that I can't lower any further. My theory could be wrong but is it possible that the top hat was put wrong? On that side? The thread shouldn't be showing maybe with more thread showing it takes away some ride height?
bryansuriel3 is offline   Reply With Quote
Old 09-27-2016, 07:30 AM   #17
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
Bryan
The driver side needs to be tightened more or your missing something on the passenger side that lets you screw it in more. They should look the same on both sides. With the weight of the car on the coils, can you screw the top bolt more?
If it doesn't go in anymore, either the coil shaft is spinning while you are trying or it might be cross threaded.
Originally Posted by bryansuriel3 View Post
The ones that are lower is the back the front is the higher one it's weird Asf I'm guessing it has to do with those thread bolt things I tightened a lot under the hood on the top hat. There not the same length please help. Right now it's not clunking at each bump but when I turn hard it clunks a little low tone
endless_pain is offline   Reply With Quote
Old 09-27-2016, 07:41 AM   #18
endless_pain
After a quick search, it seems that the passenger side might be threading in too much.
http://www.ft86club.com/forums/showthread.php?p=1933992
Old 09-27-2016, 08:37 AM   #19
swarb
Top hat nut is a totally different problem, your theory is wrong.
You're adjusting the height wrong. Read the instructions. Or just youtube "how to adjust coilovers".
Old 09-27-2016, 10:20 AM   #20
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
As @swarb said, there are two separate issues (adjustment and top nut tightness).
Let's start from the beginning. With the coilovers off the car, assemble the coilovers similar to this:
Install the camber plates and top hats using a torque wrench and strap wrench (if you're careful, you can use vice grips or channel locks and a towel). The target torque for our top hats is 40 ft-lbs. If you can't get it torqued with the right tools, it's time to inspect the parts for damage.
It should have a few threads popping out, like this:
Now, adjust the pre-load to keep the spring captive:
Tighten the upper jam nut:
To adjust ride height, loosen the lower jam nut and spin down the lower bracket:
Grimmspeed did a excellent DIY for installation:
http://www.ft86club.com/forums/showthread.php?t=12864
One side note, make sure your parking brake is disengaged during the install. It prevents the rear suspension from going back together properly.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
18x9.5 tires for Seattle weather (damp) sittinSideways Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-24-2014 01:07 AM
Damp rid, condensation and moisture radroach Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 08-27-2014 11:21 PM
