Old 09-16-2016, 07:42 PM   #15
TRAKRAVN
Drives: 2015 Scion FRS - Raven
I'm running an upgraded rad with oil cooler and a stock motor. AL driveshaft 5.29 gears, 1.5/2 way MFactory diff (set as 1.5) with a Greddy diff cover.
Fluids are
Engine: 5w-40 Motul 300V
Brakes: RBF660
Transmission: 75w-90 Motul Gear 300
Diff: 75w-140 Motul Gear Competition
Coolant: Distilled water with Mocool
I change all the fluids once a year at the beginning of the season. About 2500miles and 8-10 full day track events with ~125miles on track per day.
It was suggested that I change the fluids at 5 track days, does that seem overkill or should I be changing fluids more often?
TRAKRAVN is offline   Reply With Quote
AT fluid change when going FI? xsnapshot Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 05-31-2016 07:03 PM
What are the oil change intervals listed for 2015 cars? pantdino Issues | Warranty | Recalls / TSB 8 09-06-2015 01:36 PM
AT Fluid Change? Estey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 45 10-23-2014 09:55 PM
Oil change intervals? nickw14 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 08-10-2014 04:06 PM
Overview of suspension options beyond coilovers (starting point) dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-27-2014 10:07 AM
