Old 09-11-2016, 06:33 PM   #15
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
Originally Posted by 86wtywly View Post
However on this car rpm falls below 1000 at second gear when the speed is 6 7 mph. When you try to move the car at second, the car shakes a little though as if it tries to engage with the gear or something
That would be lugging the motor, and its right up there with the worst things you can do for your car.
Shinigami301 is offline   Reply With Quote
Old 09-11-2016, 06:43 PM   #16
radroach
Drives: car
I downshift to 1st many times daily, usually double clutching for it. Very easy at the right speed.
For example turning into my driveway, it's an uphill driveway that I have to turn into driving uphill. I just clutch in from ~10mph from 2nd, momentum slows, double clutch and have a nice easy downshift to 1st for a right turn into the driveway. The clutch has no trouble catching at that speed, soft as a feather.
But It's also easy to just rev match downshift into 1st if necessary, for instance during Auto-X, but it is more forceful on the syncros.
Old 09-11-2016, 06:58 PM   #17
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by mdm View Post
And rolling slowly in 1st is hard to be done smoothly as there is huge engine braking effect, so when you lift your foot the car may become jerky.
I don't have this problem. Must be operator error.
I often end up in stop and go traffic that is moving too slowly for second gear, so I downshift to first and creep along at 1000 to 1200 RPM. The car will let you do it smoothly as long as your accelerator foot isn't spastic. I try to find the average speed of the traffic so that I don't actually have to alternately slam the accelerator and brake like the douches around me who are hell bent on keeping anyone from getting in front of them.
At low speeds this car--or perhaps the driver of this car--is susceptible to a phenomenon called pilot induced oscillation. PIO is an aircraft term in which the pilot (or driver in our case) fails to anticipate how the craft will react to an input and then overcompensates in the other direction. The operator repeats these poorly timed inputs in phase with the vehicle's reaction, and the vehicle's reaction feeds off the inputs as well until the vehicle is bucking around like a bull. You think it's the car that's jerky, but it's not. It's the driver. This problem is worst in situations where small operator inputs make relatively large changes, like moving the pedal at very slow speeds. To put it in plain language, you push the gas pedal ever so slightly too hard, the car takes off too fast, you let off the gas pedal too much, engine braking tries to stop the car and stall, you hit the gas again, etc. until you finally give up, clutch in and coast instead.
But you don't have to do that. If you know what the car is going to do, you can use smoother inputs and glide right through the car's tendency to oscillate. The car will allow very fine input to the accelerator if you don't try to riverdance on the pedals. It just takes some patience to learn the finesse.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
mdm (09-11-2016), Tcoat (09-11-2016)
Old 09-11-2016, 07:00 PM   #18
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Where I live, we have speed bumps. So I go ahead and buy one of the lowest stock cars ever made. There's reasons I didn't choose brain surgery for a career. So I have to shift down into first and crawl home off the street.
In second. Clutch in. Blip the throttle. drop a cog. Clutch out smoothly. Easy peasy
Old 09-11-2016, 07:02 PM   #19
humfrz
Originally Posted by Norville Rogers View Post
Wow.
........that's just for the hell of it .......
humfrz
Old 09-11-2016, 07:18 PM   #20
humfrz
Out of curiousity, do you guys downshift to 1st at low speed, for example like 7, 8 mph or keep it in second.
some ppl mention always double clutch to first. however, i tried to single clutch downshift to 1st with rev matching, it works fine. No clucking or grinding. Is it necessary to downshift to 1st with double clutch? try to practice double clutch a few times but end badly.
Well, 86wtywly, as posted above, you can see that everyone has their own technique and strategy.
As they say in the old Army "it depends on the situation".
Personally, I don't shift into 1st unless the car is stopped or I predict that the car's engine will lug (shutter) upon acceleration. Example: like going up hill, around a blind corner, on a gravel road, with no guardrails, at 12,000 feet of elevation.
Summary ..... I suggest just do what works for you and your car ..... just don't grind the gears or lug the engine.......
humfrz
mdm (09-11-2016)
Old 09-11-2016, 07:34 PM   #21
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Originally Posted by extrashaky View Post
I often end up in stop and go traffic that is moving too slowly for second gear, so I downshift to first and creep along at 1000 to 1200 RPM. The car will let you do it smoothly.
OK. Like I said, my experience with driving manual cars slowly does not include the twins.
mdm is offline   Reply With Quote
Old 09-11-2016, 08:05 PM   #22
Driving MT is probably the most over thought practice on the internet car forums. It doesn't matter what Billybob, Cletus or Bubba have to say since they probably don't do exactly the same thing all the time anyway. Double clutch if you want to and don't if you don't. None of the methods are "better" for the car really. Just relax and get used to the car and it will all come eventually. As long as you are not grinding, over revving, lugging or burning the clutch there is very little that can be done to hurt a MT during regular driving.
humfrz (09-11-2016), Ultramaroon (09-11-2016)
Old 09-11-2016, 10:19 PM   #23
Ultramaroon
not playing cards
Ultramaroon's Avatar
I do whatever it takes to get it into first without using force at any speed up to 25 mph or whatever first gear redline is. I developed a many-years-old habit of double clutching into first since the early 80s. I just recently began experimenting with leaving the clutch depressed in neutral and revving up to spin the clutch disc. I'm not sure yet that I prefer it over double clutching but old habits die hard. @Stang70Fastback
http://www.ft86club.com/forums/showt...19#post2743219
Stang70Fastback (09-11-2016), Tcoat (09-12-2016)
Old 09-11-2016, 10:31 PM   #24
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Haha, Ultramaroon and I had a discussion about this not too long ago! (The thread he linked above.) Here's a video I made (also in that thread) where I did NOT double clutch and was able to downshift to 1st at 15 and 20 MPH without issue.
[ame="https://www.youtube.com/watch?v=vcxhxA5RtGw"]Rolling Downshift to 1st in a BRZ - YouTube[/ame]
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
menikmati (09-11-2016), Ultramaroon (09-11-2016)
Old 09-11-2016, 10:33 PM   #25
Ultramaroon
not playing cards
Old 09-11-2016, 10:34 PM   #26
ghostzfh
Drives: 2016 Scion FRS Halo
Personally I think that shifting into 1st isn't necessary unless I'm on a ridiculous incline that requires a ton of torque. If I had to shift into 1st, I would just downshift revmatch. Even then, shifting into 1st is painful af in every scenario.
ghostzfh is offline   Reply With Quote
Old 09-11-2016, 10:37 PM   #27
ghostzfh
@Stang70Fastback ... Damn that looked really rough on your transmission.
Old 09-11-2016, 10:42 PM   #28
Cal3000
Drives: Panda FR-S
I'd double clutch into 1st gear if I'm going 15mph or something. As low as 7 or 8mph, you can just shift it into 1st. Double clutching places less strain of you sychros or no strain at all of you match the engine speed with your transmission.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
AT downshift issue FRSBRZGT86FAN Issues | Warranty | Recalls / TSB 92 12-04-2015 01:11 AM
Messed up downshift - how bad did i fuk up ? WGMGR Scion FR-S / Toyota 86 GT86 General Forum 22 11-05-2015 01:55 PM
Rev match downshift possible with OFT Simon99 Software Tuning 24 08-17-2014 04:20 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 08:33 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 03:41 PM
