Old 05-22-2017, 09:18 PM   #15
Edibrac
Edibrac's Avatar
Drives: 15 Series.Blue
So did you try any of the suggestions given in this very thread?
Edibrac is offline   Reply With Quote
Old 05-22-2017, 09:35 PM   #16
steve99
Originally Posted by mattyd97 View Post
So I just got off the phone with someone at K&N. They told me if I've had the CAI for almost two years it's most likely not the intake unless I didn't take care of it. I've only put about 8k miles on that intake at most, so I really don't think that would be an issue; however he said since my secondary cat is bypassed I have to turn the sensor off for that cat. Does this seem right to you guys? Just looking for a couple of opinions. Thanks.
Bold bit is incorrect,
1. only primary CAT in header is monitored by ECU. Secondary cat is not monitored.
2. The cel code produced when you remove the PRIMARY CAT in header is P0420, not a lean code PP219A "Bank 1 Air/Fuel Ratio Imbalance.
3. Removing even both cats will NOT cause the lean code just the code P0420 cat efficiency. assuming the 02 sensors was not damaged and installed correctly no exhaust leaks.
4. Even straight piping the entire exhaust wont cause car to run lean.
you have a perceived lean condition could be many things. see my previous posts and like another guy said you need to monitor LTFT , commanded AFR and Actual AFR.
WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor driftking96 Want-To-Buy Requests 0 02-16-2016 04:57 AM
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 03:20 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 09:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 07:39 PM
