Old 07-21-2016, 01:45 PM   #15
Chimera
Drives: FRS
the frs/brz is actually pretty LED friendly in the dome light fixture as long as you don't short it. The BCU even provided a PWM on off cycle that helps keep LEDs working right.
I actually have an entire SSR setup on mine with what is effectively underglow for the entire car all run off that circuit.
Old 07-21-2016, 01:52 PM   #16
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Originally Posted by danielremjativa View Post
my dome light would work sometimes and sometimes not. then it started getting worse and now it doesnt work at all. it seemed to start happening ever since i replace the original bulb with an led but even after switching back it still doesnt work. anyone have this problem?
I had that same issue a year ago and my led dome bulb was from DD.
But when I put the original bulb back in there was no problems.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 10:39 PM
Interior Dome Light Issues Mongo Issues | Warranty | Recalls / TSB 3 03-19-2014 05:52 PM
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 09:59 PM
Interior Dome Light in DOOR mode works in reverse! shaoster Cosmetic Modification (Interior/Exterior/Lighting) 1 04-07-2013 02:37 AM
