Old 10-27-2016, 01:36 AM   #15
aaguirre123
Drives: sti 2012 sedan
Originally Posted by FRS Justin View Post
Pauter rods, Outfront Motorsports Custom 12.5 piston made by CP, Stock headgasket. Supertech valvetrain......
Here's why, when you boost a motor you need to increase the ring gap, and possibly the piston clearance depending.. I would never try to push 3X more power on a stock piston. Pistons are cheap compared to doing it a second time....
Can you share the piston clearance and ring gaps for all three rings?
Also with the 12.5 CR, is it a forged 2816 or a 4032?
aaguirre123 is offline   Reply With Quote
Old 10-27-2016, 12:02 PM   #16
FRS Justin
Drives: 2013 Asphalt FRS
I'm using a big turbo pushing over 30psi so I am sure my specs will not be the same as what would work best for you. I would talk to my engine builder about that. I could tell you for example .004 but then on the street motor with lower boost smaller turbo it would use oil. NOW THATS JUST A EXAMPLE spec but when you build these engines you have to build them for what your going to use it for... Sorry I couldn't help you more.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
driggity (10-27-2016)
Old 10-27-2016, 03:16 PM   #17
wbradley
Sarcastic SOB
wbradley's Avatar
Forgive me if missed something here. I was of the impression you can't find forged rods that will fit on the stock piston. You either change the piston too or grind out part of a brand new forged rod to fit the stock piston.
Old 10-27-2016, 03:57 PM   #18
aaguirre123
thanks. i understand that engine build is depended upon the purpose of the user. i wanted to find out what specs you agreed with your engine builder. to see if your build specs bearing and piston to cylinder wall clearances are good for my engine build and also compare to other engine builds (FA20).
thanks anyway.
College Budget Build jaorocks1 Member's Car Journals 26 05-04-2016 07:43 PM
Critique My Budget Build Wolfdogelite Electronics | Audio | NAV | Infotainment 10 04-05-2015 03:27 PM
Budget stereo build toast Electronics | Audio | NAV | Infotainment 4 12-17-2014 05:10 PM
My boosted build...on a budget PineappleFriedRice Member's Car Journals 95 08-17-2014 10:29 PM
Aznsky's budget STX build Aznsky Tracking / Autocross / HPDE / Drifting 13 05-12-2014 09:44 AM
