#15 | |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
#16 | |
The Stig's German cousin
![]() Pro tip, if anyone runs into trouble: the scissor jack comes in handy for getting that first inch of lift...or buy a new jack. |
#17 |
Drives: 14 FR-S, 21 Supra 3.0, 23 Z
Thinking about taking this route over coilovers. I don't necessarily want to be dropped up this is a nice drop if I couple it with RPF1s (going with the 18 inch wheels). Think the fitment would be nice?
------—-------—-------—--------—-----— Instagram: Vangloriousm Twitter: vanivglorious
14' Hot Lava ZN6 OFT Stg II+ CNT UEL headers- Eibach Sportline springs - 25mm spacers (front-back)- TRD-style rear spoiler - kouki tail lights - Black Winjet headlights - Red Raceseng Ashiko shift knob - Blitz drop-in filter - WORKS ABM - Crawford BPB
#18 |
The offset and tire size will figure into it, but 18's will generally fill up the fender better.
| The Following User Says Thank You to Twinz For This Useful Post: | 31x86 (07-12-2016) |
#19 |
Drives: Raven 2016 FR-S
The balance. Yes the RX-7 had more oomph (FD3S), but even the RX-8 handled better than the FD. I'm not a fan of turbo lag either. I loved my RX-8, but she was starting to lose compression and it was going to cost more to fix her than she was really worth. The electrical system was starting to have issues too. I was thinking about getting another rotary in a few years, but I think I can build a nice track twin pretty good too. Probably cheaper in the long run seeing has how rotary parts are getting harder and more expensive to get. Sorry it took so long to respond.
#20 | |
Drives: 2013 FRS
I am running CS this summer with TRD springs, Koni yellows, stock sway bars (for now), and Falkens new 200AA tires. Alignment has front -1.8 camber with crash bolts, rear is same, toe about zero all around. I seem to mostly get entry understeer and some exit oversteer. Right now I am trying to decide if I should get the TRD bars or just someones front bar. Like adjustable Perrin or a Strano. My assumption is the TRD bars were designed to work well with the TRD lowering spring. |
#21 |
TRD bars front and rear created a lot of understeer pretty much any time I turned at the limit.
You may be able to clean up the entry/exit balance issues with the rebound on the Koni's but it's counter-intuitive. (Soften rear to get the front to bite on entry, soften front to get the rear to hook up on exit) |
#22 |
Drives: '14 BRZ 6MT
very nice!! awesome opportunity for comparison shots. glad you took advantage!
#23 |
#24 |
I know this is a super late response, but are you using pedal dance to turn of traction control or just pushing the button? Being able to have stronger trailbraking and weight transfer might eliminate the entry understeer for you allowing you to put a stiffer sway up front to help corner exits and slaloms.
http://www.ft86club.com/forums/showthread.php?t=25494 |
#25 |
Drives: 2013 FRS
I just hold the button.
Yes, under braking there is less understeer. I think setting the konis with stiffer rear and full soft front helps. Hoping to keep up corner speed and handle any exit problems with throttle control. I may try putting the stock bar back on. Sent from my SM-G930V using Tapatalk
WIFE: "How can there be anything left to buy?"
| ***Rexpeed Convex Side Mirrors and Carbon Fiber Side Mirror Covers*** | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 249 | 12-07-2015 01:28 PM |
| WTB: Drivers side and passenger side fenders condition don't matter | Hollwood_lives | Canada Classifieds | 5 | 07-30-2015 04:53 PM |
| FR-S Steel and Argento are not the same color (side-by-side pics) | thismock | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 09-28-2014 10:09 PM |
| Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) | Moto-P | BRZ Photos, Videos, Wallpapers, Gallery Forum | 109 | 08-19-2014 10:56 PM |
