Old 06-27-2016, 08:24 PM   #15
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Dry sump is the ultimate solution. If you are getting a lot of blow-by you should do a compression check just to rule out failed rings or cracked ringlands.
TRAKRAVN is offline   Reply With Quote
Old 06-27-2016, 09:16 PM   #16
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
The fa20 with a baffled oil pan doesn't have the same issue the ej had. At the same time the fa20 doesn't have a dry sump option. Everyone is making this topic into something else.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-03-2016, 03:10 PM   #17
pleong
Drives: 2013 Whiteout FR-S
It's funny that I found this thread, because just last night someone on the 86 track cars fb page was showing their setup on resolving this issue. I'm going to do this myself to test. I'm running about 20psi at times and when I push the car, it get quite a bit of blow by, I think at least. I see a lot of oil under my car all the way to the rear diff. I don't have any leaks anywhere.. I've checked multiple times by wiping it off, and driving. Only time I get all this oil coming out is when I'm at the track, putting it through its paces...
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
The Following 2 Users Say Thank You to pleong For This Useful Post:
COO86L (10-11-2016), DustinS (08-11-2016)
Old 08-03-2016, 03:14 PM   #18
pleong
Also, compression is fine and no leak according to the leak down test. Head gasket is fine too
Old 10-10-2016, 12:42 PM   #19
D K
Stig's dark passenger
Originally Posted by Irace86 View Post
Should it matter how much boost or how much lateral g's someone is consistently putting the engine through?
LOL.
Yes.
I dont think my car would idle at normal temps...
D K is offline   Reply With Quote
Old 10-10-2016, 12:49 PM   #20
D K
Got it resolved now.
Bespoke baffled 'can' feeds into another baffled can from the last chamber and the last chamber of that can feeds into the intake via a reducer.
Havent seen blowby since.
Old 10-11-2016, 07:59 AM   #21
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Got any more details on this? Is it just a drain back style going to the filler? I'm digging it!
COO86L is offline   Reply With Quote
Old 10-11-2016, 08:04 AM   #22
pleong
No I'm not the originator of this idea but it doesn't drain back into the filler, it's actually a vent that drains into a catch can. The owner says it worked well on the street but at the track it didn't solve the issue 100%
I'm trying this out, in addition to the velox AOS and another catch can.
My next track event won't be until December though.
Combating the heat toekneehair Forced Induction 823 12-23-2021 08:06 PM
Does you A/C blow cold? boredom.is.me Issues | Warranty | Recalls / TSB 45 07-29-2017 03:04 PM
catch can for blow-through maf jamesm Forced Induction 13 05-25-2017 10:54 AM
Huge blow-out bestwheelbase Announcements, Contests, Giveaways 3 12-16-2013 06:08 PM
Blow through vs draw through MAF mrk1 Forced Induction 9 07-24-2013 07:21 AM
