Old 06-09-2016, 05:15 PM   #15
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Originally Posted by nikitopo View Post
lol... this guy in the video is funny! I haven't seen more ridiculous car review
And where did you found that Cayman weights 150 lbs more? Cayman is in the range of 3,000 lbs which is roughly +400 lbs. And don't forget, Cayman is a 2-seater. 911 Turbo S is a nice car, but it is far away from the category of BRZ. We should be reasonable when doing comparisons ...
Why is your BRZ so light?
murdoc is offline   Reply With Quote
Old 06-09-2016, 05:31 PM   #16
Pat
Pat's Avatar
Drives: 2023 BRZ
@Pat did you do the metalurgical analysis done?
Unfortunately not. I have provided as much detail as I have.
The Following User Says Thank You to Pat For This Useful Post:
CSG Mike (06-09-2016)
Old 06-09-2016, 05:41 PM   #17
strat61caster
strat61caster's Avatar
If something really matters, then be sure that Subaru will do the best and use the best materials.
Perspective, >95% of 86's will never see track duty I'd wager. Seriously consider how often wheels come off say your mom's sedan, maybe once every 2-3 years for a brake job or tire replacement? Hell I bet I've driven cars that haven't had their wheels taken off in nearly 5 years.
75-80 wheel installations is not a ludicrous lifespan for a economy car, I'm just glad most people strip the threads before they shear the bolts. ARP studs went on my car about 9 months ago after I stripped the OE studs. Makes me feel better that it wasn't operator error, only wish I had kept track of wheel on/offs, I don't think I surpassed 50...
Full tank of gas and all equipment the 86 comes out to 2750 pretty consistently, strip the trunk and run it under a quarter tank and you'll be under 2,700 lbs. One of the few upsides to this car not many people talk about, it really is a lightweight while most cars come out heavier than advertised. I want to say that some manufacturers advertise dry weight, so no oil in the engine, coolant in the radiator, or fuel in the tank so the actual cars come in 100+ lbs heavier than the spec sheet.
http://www.ft86club.com/forums/showthread.php?p=845661
http://www.ft86club.com/forums/showthread.php?p=362020
http://www.vorshlag.com/forums/showthread.php?t=8275
ineedyourdiddly
murdoc (06-09-2016)
Old 06-09-2016, 06:09 PM   #18
murdoc
murdoc's Avatar
I was just confused as to how 3000-2750=400+ lbs, But reading it again i see its +400 not 400+
Old 06-09-2016, 06:10 PM   #19
renfield90
The Stig's German cousin
Originally Posted by Pat View Post
Dorman's set of studs goes for $40. ARP's is maybe $200. Is there really much difference? As JimR noted, "Even Dorman's cheap aftermarket replacement stud specifically for our cars shows grade 10.9 on the head."
Generally you get what you pay for, but if the grades are the same, how much difference can there be?
The ARP studs are lengthened - if you need to run spacers, you have the room.
The ARP studs also have a little bit of dead area with no threads at the end of the stud. This little detail makes it almost impossible to cross thread the stud when putting it back on.
Above all realize that if you race your car, studs/lugs are a wear item and should be replaced regularly - even if you've upgraded.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
DAEMANO (06-10-2016), DarkSunrise (06-10-2016)
Old 06-09-2016, 06:24 PM   #20
HunterGreene
Hail Magnet
HunterGreene's Avatar
75-80 wheel installations is not a ludicrous lifespan for a economy car...
If responsibly done, tire rotations count in there as well, which can be up to 2-3 times per year. Add in one extra for winter rubber (at least in the northern zones) and you have 4 tire changes per year. That means that we will wear out the studs after 18 years--Wait, nevermind, thats totally reasonable.
It has priests in it?
The Following 2 Users Say Thank You to HunterGreene For This Useful Post:
Dadhawk (06-10-2016), strat61caster (06-09-2016)
Old 06-09-2016, 06:57 PM   #21
OkieSnuffBox
Drives: '23 BRZ Limited
And he's adding 100lbs to the Cayman.......which also has 50% more HP.
And he completely ignored everything I said regarding build quality. Porsche is at the top of the heap when it comes to any mass-produced vehicle. And bests many of the boutique vehicles.
EDIT: Guess depends on if we are talking about the Cayman or the 718 Cayman. The new Turbo 718s are a touch heavier ~3000 lbs. The 6 cyl cars are ~2900 lbs.
But still 2764 (published base weight) to ~3000 is 236 lbs, not 400.
Old 06-09-2016, 07:13 PM   #22
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Exactly, this discussion was pretty much useless. Personally I replied because there was a suspicion in the topic that Subaru is a cheap company. For sure it does not have the glamor of Porsche or other big companies, but it is an earnest car manufacturer. In some cases much more earnest than the bigger guys.
Old 06-09-2016, 07:16 PM   #23
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If I got 80 changes, I'd be a super happy man. Instead, I'm waiting until I can install these ARP studs.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 06-09-2016, 07:36 PM   #24
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
But still 2764 (published base weight) to ~3,000 is 236 lbs, not 400.
The 1st generation Cayman (987c) which was produced till 2013 was heavier. The base car with the 265PS weighted 3,100 lbs. The newer versions are lighter, but also newer designs.
For me quality is a relevant thing. If you mean the leather and the premium feel, then you are right. If you mean not to break, then I insist that Subarus are better.
Do you know who was the chief designer of Porsche all these years? Do you know who designed 911, Cayman, Cayenne? His name was Pinky Lai. He was a designer from China. Try google and you will find a lot about this guy. Do you still believe that Porsche is a real German company?
I will not say anything else because we are already off topic
Old 06-09-2016, 07:55 PM   #25
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Our STX car endured 2 full seasons of autocross, changing tires 2-3 times each weekend.
Stock studs, no issues.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
e1_griego (06-09-2016), TrqlessWonder (06-10-2016)
Old 06-09-2016, 08:56 PM   #26
OkieSnuffBox
I don't even know what to say.
Don't forget your meds in the morning.
Old 06-10-2016, 01:30 AM   #27
Pat
Pat's Avatar
Drives: 2023 BRZ
ARP offers an OEM length option now.
Old 06-10-2016, 01:39 AM   #28
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by jamestown View Post
What kind of tires was your friend using
IIRC RS3s.
WTB WHEEL STUDS TomShugoy Want-To-Buy Requests 0 02-08-2016 07:44 PM
ARP Wheel Studs FR-S Matt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-09-2015 07:50 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 09:31 AM
WTB OEM Wheel Studs Anthony Want-To-Buy Requests 8 08-27-2014 04:22 PM
Meeting with Subaru field engineer in two weeks Subie Issues | Warranty | Recalls / TSB 35 02-25-2013 02:50 PM
