Old 07-04-2012, 09:41 PM   #15
xwd
Interesting that's the first trans used in a Subaru I have heard of that doesn't have a dipstick. Then again Subaru generally designs their own transmissions and this one is from a 3rd party manufacturer.
Old 07-04-2012, 10:23 PM   #16
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Makes sense it is a Toyota trans
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 07-04-2012, 10:34 PM   #17
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
Yep, just like the J160, V161, R154, W58, T50 etc etc
JP is offline   Reply With Quote
Old 07-04-2012, 11:18 PM   #18
csaba
Drives: scion tc
Originally Posted by Draco-REX View Post
Don't drive the car any more and get it to a dealer asap. Something is definitely wrong.
Uhh, no. Transmission fluid and gear oil breaks down just like engine oil, just as a much slower rate. It should NOT last the life of the car. Your trans fluid/oil should be changed at every 30K service.
That's excessive and it pisses me off that manufacturers are doing this more and more on new cars. They say they're doing it because people can't tell the difference between the engine oil dipstick and the transmission dipstick. They much think their customers are all idiots. (Yes, quite a few are, but not all). But it keeps people from easily checking their fluid levels which is just wrong. As above, at least one car has left the factory with no transmission fluid, and this might be the second. Without a simple dipstick, it can't be checked without a lot of work, so it's not done during a PDI where it could be easily discovered.
Forget being empty, do we know that our transmissions were filled to the power level? Maybe they're low? But we can't tell unless we have at least a floor jack and four jackstands and an hour of time.
Drives me batty. I think I'm going to request my dealership spend some warranty time on checking my trans oil level...
Good for you than change it at 30K!
csaba is offline   Reply With Quote
Old 07-04-2012, 11:22 PM   #19
csaba
Drives: scion tc
Originally Posted by JP View Post
to check the oil you need to raise the car up, remove the undertrays, remove the filler bung on the side of the box and put your finger in to feel the oil level.
There's 2 bungs on the side, lower is the drain, upper is the filler. Detailed on page 66 of the service manual.
So I get my car from the dealer and do all that to make sure I have trans oil.
Than I might as well buy a used junk!
Old 07-04-2012, 11:26 PM   #20
JP
Backyard Fabricator
nobody said you have to check the oil level, if they didn't put oil in and the trans gets lunched, it's under warranty.
At predelivery they just check that there are no transmission oil leaks.
Changing the transmission oil at regular service intervals will prolong the life of your synchro's.
Old 07-04-2012, 11:46 PM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
My troll sense is tingling.. Next thing he'll be complaining that he has to change his engine oil every 7.5K when it should last for 15K.
Old 07-06-2012, 05:29 PM   #22
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Most manual transmissions don't have dipsticks FYI. Something is seriously wrong with this guys Tranny or linkage. I hope we get details on the verdict.
PS- I plan on getting my car off the truck while I am there and watch the mechanic do the PDI and not let him drive it.
PPs- I am a certified mechanic also.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 07-06-2012, 06:18 PM   #23
2pt5RS
Berz
Originally Posted by Mr.Jay View Post
wtf? That doesn't sound right at all
My 6MT is fine real smooth. Only issue is shifting into 1st and from 1-2 when the car hasn't warmed up at all.
I would get the dealer to look at it considering we already have heard of a dealer not putting any tranny fluid in a car before selling it.
the dealer doesn't put the transmission fluid in the car, that happens at the factory.
2pt5RS is offline   Reply With Quote
Old 07-06-2012, 06:23 PM   #24
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
There are several models of Toyota that do not have change intervals for the transmission fluid, including manual transmissions, and this also includes the TL70 in the FR-S. There is no scheduled maintenance for the M/T Gear oil, it is meant to be a "lifetime" fluid.
I still usually change mine every now and again, but I'm just saying.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 07-06-2012, 07:18 PM   #25
gt86init
yoimlevinit
Drives: gt86
I have to say it is very notchy and tough to shift on 1st , 2nd & 6th when car is cold.. again im only at 100 miles so i wanna give it some time to loosen up a bit..
gt86init is offline   Reply With Quote
Old 07-06-2012, 07:31 PM   #26
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
http://www.ft86club.com/forums/showthread.php?t=10450
According to this it is done during PDI
crap just re-read that thread I was wrong!
But still that must of been a crap PDI since they sold the car and didn't notice
Out of the FRS game
Old 07-07-2012, 02:48 AM   #27
phenom86
phenom86's Avatar
Drives: Scion FRS Asphalt
mine is the same thing, its not as smooth as it should be.. ill stop by toyota tomorrow and have them quickly check it out
phenom86 is offline   Reply With Quote
Old 07-07-2012, 03:04 AM   #28
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
but after a good minutes driving around its smooth..
imravenit is offline   Reply With Quote
What transmission? Ess Vee Engine, Exhaust, Transmission 9 06-25-2012 02:56 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 12:48 PM
