#15 | |
In case you didn't read in the post, he said he doesn't want to buy something to fix it this soon.
#16 |
Drives: 2016 Subaru BRZ Limited CWP MT
This was the first thing I tried before posting. And the method I used in the posted video.
Hindsight is 20/20 |
#17 |
Drives: 2005 Toyota Camry
My way:
Warm up car Start car with ebrake on and foot on brake pedal. Brake 3x (hold at end) Ebrake 3x (hold at end) Brake 3x (lights come on) I can replicate this procedure on any FRS/BRZ without issue. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | BDKane01 (05-20-2016) |
#18 |
-Alex, I already tried this method as well.
#19 |
#20 |
@BDKane01 repeat the 3x + hold procedure going back and forth. Sometimes the car will not catch an input if it even slightly overlapped.
An "easy" way to do it is 3x brake + hold, 3x ebrake + hold, 3x brake + hold, 3x ebrake + hold, 3x brake + hold, 3x ebrake + hold, over and over until it works. Usually you don't need more than 1 repetition unless you're really messy, but it sounded like you were fully lifting on the brake pedal in the car. Fun fact: this works on the LFA... |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#21 |
not playing cards
Unless someone beats me to it, I'll post a clip after I get home tonight. It's a snap once you get the rhythm.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | BDKane01 (05-20-2016) |
#22 | |
I don't think that is the case. I can make more videos of me trying all the methods.
#23 |
Posts in the nude
Drives: 2016 WRB BRZ
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography "Lesbian trees have no wood." - Scoobs McGee |
| The Following User Says Thank You to mixtape For This Useful Post: | zc06_kisstherain (05-20-2016) |
#24 | |
That would be helpful. Though I don't think it's user error.
#25 | |
The pedal dance doesn't care how many times you enter it, as long as you enter the correct sequence within 30 seconds of the car starting up. If I were you, I'd just keep doing 3x 3x 3x 3x 3x until 30 seconds has elapsed before saying it's the car's fault. The key part is that the ECU needs to see the following conditions: warm engine/normal idle stationary car first 30 seconds of engine startup At least this following sequence: 3x brake pedal 3x hand brake 2x brake pedal All needs to be done in a sequence and any deviation of any of the conditions will not activate diagnostics mode. -alex |
#26 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
After watching the video, I'm with mav and assume this can only be user error. It took me some time to figure it out for the first time as well, so don't worry. I learned easiest after I sat in the car and watched others do it. You don't need to be so deliberate and cautious about it. I see those who are used to this process literally spaz out and accomplish the task in just a few seconds. Don't pause in between the alternating of e-brake and pedal. Picture it like sheet music written in 4/3 time signature lol: 1-2-3-1-2-3... no rests and don't count how many you do. Just keep doing it till you see the lights.
| The Following User Says Thank You to Toyarzee For This Useful Post: | BDKane01 (05-20-2016) |
#27 |
On my 15 minute break at work after driving back from a hangar... I had the idea to unplug the negative terminal and replug.
The nannies went off and the lights went in one try after the reconnection. I have tried three times in a row and it works. So issue resolved.
| The Following 5 Users Say Thank You to BDKane01 For This Useful Post: | CSG Mike (05-20-2016), FRSBRZGT86FAN (05-20-2016), mdm (05-20-2016), Toyarzee (05-20-2016), Ultramaroon (05-20-2016) |
#28 |
Thanks for everyones input and help!
| The Following 3 Users Say Thank You to BDKane01 For This Useful Post: |
| Pedal dance | Simqc | Issues | Warranty | Recalls / TSB | 6 | 05-22-2016 09:56 PM |
| OFT - Pedal Dance Mode. | RustySocket | Software Tuning | 2 | 08-24-2015 06:55 PM |
| Is there a way to turn all the aids off w/o doing the pedal dance? | D K | Tracking / Autocross / HPDE / Drifting | 4 | 07-07-2014 09:16 AM |
| Pedal Dance Device | robot | Tracking / Autocross / HPDE / Drifting | 3 | 01-10-2014 09:26 AM |
| Gas pedal dance brake thing.??? | gdrider77 | Software Tuning | 9 | 12-22-2013 08:43 AM |
