Old 05-10-2016, 08:18 AM   #15
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Goto the store and purchase better luck. That or pull your engine and check the clearances, subaru has been letting this slide.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
nickw14 (05-19-2016)
Old 05-10-2016, 01:21 PM   #16
Originally Posted by SPCorBUST View Post
whats the fix so that these types of failures don't occur?
PM me.
Old 05-10-2016, 03:35 PM   #17
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
PM me.
I'd be curious to know as well. Is this issue present on all FA20's or just the early year engines?
xsnapshot is offline   Reply With Quote
Old 05-10-2016, 04:24 PM   #18
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
was the lash checked during reassembly?
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 05-11-2016, 01:46 AM   #19
dj2020
I'd like to know as well...
dj2020 is offline   Reply With Quote
Old 05-11-2016, 09:17 AM   #20
Ashikabi
Ashikabi's Avatar
Subd
Old 06-20-2016, 10:20 AM   #21
EdiVip
Drives: Mario
Ok, so This is my solution for this problem. Custom Rocker Arm Cage developed by my Tuner!
I hope this help U to solve this issue before Your heads will blow!
EdiVip is offline   Reply With Quote
Old 06-20-2016, 12:33 PM   #22
-Phil
Drives: Rb25 neo brz
What were you revving this car to when the failure occurred?
-Phil is offline   Reply With Quote
Old 06-20-2016, 12:44 PM   #23
Irace86
Drives: BRZ + Ducati M796
That cage looks scary
Irace86 is offline   Reply With Quote
CA-FI Heads Up Display XtremeMaC Electronics | Audio | NAV | Infotainment 3 08-18-2015 08:41 AM
Heads Up BRZ Available In So Cal ZmZMWagon Southern California 17 06-18-2012 03:10 PM
