Old 04-01-2016, 02:31 PM   #15
strat61caster
strat61caster's Avatar
Originally Posted by RickyRacer View Post
what brake fluid would you guys recommend? any guide that compares them out there
DD only? Maybe a bit of autoX and backroads? Any DOT 4+ fluid will cover you just fine. My money would go to ATE TYP 200, used to be called 'Super Blue' is <$20 for 1L enough to do a full flush. Tons of love from casual trackers too so it's affordable and exceeds most needs for the casual enthusiast.
If you're tracking hard is when fluid needs to be upgraded, lots of options going all the way up to $60+ per Liter.
ineedyourdiddly
Old 04-01-2016, 02:38 PM   #16
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
just the best fluid money can buy for a DD with spirited mountain driving
RickyRacer is offline   Reply With Quote
Old 04-01-2016, 02:39 PM   #17
ZionsWrath
Thanks
ZionsWrath's Avatar
Get a motiv power bleeder. Second best tool I ever bought for working on my car.
Old 04-01-2016, 02:42 PM   #18
strat61caster
That's such a silly statement, based on your description you won't be able to tell the difference between $20/L fluid and $70/L fluid.
Here's the CSG comparison mentioned before:
http://www.ft86club.com/forums/showthread.php?t=47686
ineedyourdiddly
Old 04-01-2016, 02:50 PM   #19
ZionsWrath
Thanks
ZionsWrath's Avatar
Unless boiling fluid it should feel the same. So average person street driving isn't going to tell a difference.
Depends on usage if its worth getting a pricier/better fluid. I like my Project mu over RBF600 and it actually is cheaper cuz of its life. Going for rt700 next time. But I go to HPDE events so my usage is different.
The Following User Says Thank You to ZionsWrath For This Useful Post:
strat61caster (04-01-2016)
Old 04-01-2016, 02:55 PM   #20
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
thanks.
I really don't know much about brake fluids
should I just get OEM then? or ATE type 200 as strat suggested?
I just want the least headaches with the same performance as when i purchased the car brand new
Old 04-01-2016, 06:53 PM   #21
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
thanks.
If you're not tracking, use OEM. Keep in mind, your brand new car had OEM fluid.
infinity21 is offline   Reply With Quote
Painted brake calipers meeskee2 Cosmetic Modification (Interior/Exterior/Lighting) 20 04-15-2014 05:19 AM
Painted Brake Calipers Roborat Cosmetic Modification (Interior/Exterior/Lighting) 67 12-01-2013 04:51 AM
Painting the Brake Calipers Wasta Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-26-2013 08:12 AM
86 brake calipers Hardrock4445 Cosmetic Modification (Interior/Exterior/Lighting) 19 03-17-2013 09:04 PM
