Old 03-14-2016, 12:25 PM   #15
HeartbeaT91
Drives: 2013 Sterling Silver BRZ Limited
hmmm.........have you checked out that right front brake/bearing area ...... ??
Leaking brake line ..??
Sticking caliper .. ??
Can you further describe the burning smell .. ??
Gasoline; oil; clutch disk; brake pads; leaves; antifreeze .... ??
(they all have distinctive odors)
humfrz
I'm not very experienced with car issues - so pleaes excuse my ignorance. this BRZ is the first time I was able to get a car i've always wanted. with that said, i'm completely unsure of what kind of burning smell this is, because i've never smelled burning smell in my previous beater.
Can you perhaps describe what each burning smell differs by?
Originally Posted by Turbo95eg6 View Post
I'm at 17,000 miles, yes it still happens. It's definitely a burning rubber smell, maybe plastic. As long as my car doesn't burn down on the freeway it doesn't bother me too much, but I'd like to know what it is too.
I'm at 16,000 miles, I'm 75% sure we have the exact same problem ... Hopefully we iron this one out!
HeartbeaT91 is offline   Reply With Quote
Old 03-14-2016, 01:45 PM   #16
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Are you both sure its not just your clutch :\
PandaSPUR is offline   Reply With Quote
Old 03-14-2016, 04:58 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Things that can burn or smell:
Clutch
Engine oil
Brakes
Coolant
Transmission oil
Differential oil
External sources not directly related to car
You need to figure out what it is by trying to replicate the conditions that create the smell...
Old 03-14-2016, 06:01 PM   #18
HeartbeaT91
Does clutch burn smell linger after you're done driving and parked? I've smelled burning clutch before - but for the most part i smell them right away (after i slip too long or something) and then they disappear briefly.
So from my experience, it wouldn't be the clutch because i'm able to smell something burning/burned after i've parked (i usually neutral into my lot so I wouldn't even have touched the clutch) for 5 minutes.
Old 03-14-2016, 07:32 PM   #19
humfrz
I'll try.
gasoline - smells like the vapors that come off your lawnmower after you overfill it.
oil - smells like a BBQ after you have sprayed Pam on it when grill is hot.
clutch disk - smells like nothing else ..... sort of like a hot/baked/oven mitt, you left in the oven.
brake pads - smells like a burning, hot, stinking piece of wet wood.
antifreeze - smells sort of sweet and alcoholic
caliper - (actually the pad would be burning)
............and then we have electrical insulation, rubber, hot belts
I suggest you ask your co-pilot where they think the smell is coming from and what it smells like .....
humfrz
Trust86 (03-14-2016)
Old 03-14-2016, 08:11 PM   #20
Trust86
Drives: 2016 Halo FRS
Maybe your accidentally pushing the nitrous purge button?
Trust86 is offline   Reply With Quote
Old 03-14-2016, 08:25 PM   #21
roddy
roddy's Avatar
Drives: '13 Ultramarine
The stench of burning clutch can stick around for a while, and the smell of overheated brakes is very similar to my nose (though that can vary a bit with different pad compounds). I had a sticky caliper that would intermittently give me some issues (and smell). I found the issue one day with a small spray of water. Pick up a cheap spray bottle, and fill it with water. The next time you encounter that smell, pull over, and give each rotor a squirt or 2. They will likely all sizzle a bit, but if one is really hot it will steam and sizzle more noticeably than the others...that one will be your problem.
The Following User Says Thank You to roddy For This Useful Post:
humfrz (03-15-2016)
Old 03-21-2016, 05:35 PM   #22
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Based on that video I posted above, the dealer is removing my engine as I type.
I took it in for a headlight replacement and said "Have a look under the timing cover".
They said "Yup! your timing chain cover and upper oil pan seals are leaking"
They said engine out and two days to complete the repair.
Car has 35k miles.
justatroll is offline   Reply With Quote
Burning smell PLease help! Chase1996 Issues | Warranty | Recalls / TSB 62 11-02-2015 01:11 PM
Burning alternator smell btsokolas Issues | Warranty | Recalls / TSB 1 09-22-2015 11:15 AM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 01:31 AM
burning smell when in reverse fito68 Southern California 8 12-30-2014 06:21 PM
Burning smell Boofneenee Issues | Warranty | Recalls / TSB 6 09-30-2013 06:28 PM
