#15 | |
driving smoother faster
Drives: Sold
Oil pressure/temp gauges & block8head.com gauge pod
Hi, it seems very solid to me but I haven't tried the others so not sure...I probably wouldn't put more than two gauges there to avoid too much distraction. My Stack gauge flashes on min threshold and I plan on glancing at the P3 for temp only when Stack flashes. I only glance at AFR/boost sometimes to check tune (delicious has worked great for me) or boost for leaks. I plan on hooking up BT OBD2 with Harry's Laptimer to record more data, though I will have to unplug P3 first. Defi was recommended but I wanted the flashing face feature since things move fast on track... Also, p3 is completely blocked by my left hand holding the wheel at 9 o'clock when my seat is adjusted for track. Single blockhead gauge is completely unobstructed...not sure how many would remain unobstructed...also depends on height, seating position... |
#16 | |
Drives: Sold
I checked - 6 ft tall person in optimal seating position and hands at 9-3 o'clock would be able to see all three blockhead gauges without having to lean head to the left. With a wheel turned and hand blocking the view, only the leftmost one would stay unobstructed. No big deal as it's easy to lean a little when needed - most importantly eyes don't have to travel far from the driving line of sight. In other words, it looks like any number of blockhead pods would work well wrt placement/visibility. Keep in mind that the pod takes pretty small gauges so any feature that makes it obvious when something is wrong is even more welcome...that's primarily why I ended up with Stack. |
#17 | |
Drives: GT86
The pod is PITA to install and thus very stable enywhere. I have oil temp sensor pluged instead of oem dummy pressure switch and oil pressure on top of the block near A/C. I have this for 3+ months and 0 problems. I think dual pod is optimum, I would put third pod into vent. |
| The Following User Says Thank You to GT86_PRAGUE For This Useful Post: | dp1 (04-25-2016) |
#18 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
| The Following 2 Users Say Thank You to Cockatoo For This Useful Post: | dp1 (04-25-2016), GT86_PRAGUE (04-26-2016) |
#19 |
Drives: 2013 SWP BRZ Ltd. / E60 M5
Thanks guys. I'm probably going to do the dual pod for oil t/p and coolant in the left vent.
Anyone want a p3? Mine will be for sale.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
| The Following User Says Thank You to Alan For This Useful Post: | GT86_PRAGUE (04-26-2016) |
#20 | ||
Drives: 2013 BRZ black
Note for those that install a dual or triple pod Block8head. It helps to push up from the bottom the dash panel with a pry bar to get it to clip into place. Very difficult to snap into place from the top side only as it wants to push down on the dash while going in. ![]()
| The Following 3 Users Say Thank You to xkalelx For This Useful Post: |
#21 | |
Drives: Toyota 86 GTS
![]() ![]() Reason I ask is because I am installing an oil pressure and temp gauges. Looking at using the port next to the throttle body for temp. According to auto meter, they recommend using the factory sensor location for oil pressure. My worry is the ECU is no longer receiving this information. Should I be worried?
#22 | |
not playing cards
Also, the thread for the pressure switch is BSPT (British Standard Pipe, Taper) An NPT fitting may start but will quickly jam because they differ by one thread per inch.
#23 | |
And yes, I will be purchasing the correct adapter. Want to do it right the first time!!
| The Following User Says Thank You to arthur93 For This Useful Post: | Ultramaroon (11-24-2017) |
#24 | |
not playing cards
I can easily picture stripping the head.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | arthur93 (11-24-2017) |
#25 | |
#26 | |
not playing cards
#27 |
Legend. Thank you for your advice!!
#28 |
not playing cards
No sweat. Pics or it didn't happen.
![]() Good luck!
| The Following User Says Thank You to Ultramaroon For This Useful Post: | arthur93 (11-25-2017) |
| Block8head defroster vent gauge pods (all 52mm varieties) with pictures. | Cheeseballs | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 03-20-2016 11:46 AM |
| Fs: block8head single gauge pod and AC vent pod with reducer ring | protpibe | Interior Parts (Incl. Lighting) | 4 | 02-13-2016 10:03 PM |
| WTB: Block8head Vent Pod (60mm) | Xiao Li | Want-To-Buy Requests | 0 | 09-25-2015 02:07 PM |
| WTB: P3 Vent Gauge | Akari | Want-To-Buy Requests | 0 | 08-15-2015 10:59 PM |
| Defrost vent single gauge pod | spitfire481 | Interior Parts (Incl. Lighting) | 5 | 07-03-2014 09:58 PM |
