Old 03-07-2016, 06:15 PM   #15
EssJay
Drives: '16 FR-S Halo White
Thanks all. Good to know they don't cause uneven tread wear. I'll look into it. Oh, and "learning to drive my car" lol
EssJay is offline   Reply With Quote
Old 03-07-2016, 06:44 PM   #16
cjd
cjd's Avatar
Drives: 2017 BRZ
With the amount of driving I do that's not racing, I'm not having much problem with -3.3 camber and tire wear...
And, yeah. Learning how to drive the car.
Old 03-07-2016, 07:46 PM   #17
strat61caster
strat61caster's Avatar
Originally Posted by boredom.is.me View Post
Learning to drive my car fixed my understeer issues. This is even on a staggered setup with stock alignment. I don't understand why it's always the car's fault on this forum.
Where are you driving the car to experience this? How are you managing brakes, gas, and steering?
When I added camber to the front I was astounded how much more grip was available, no other changes, just front camber adjustment. Being able to drive the stock setup fast is a good skill to have but to say the car is faultless is narrow-minded.
ineedyourdiddly
new2subaru (03-07-2016)
Old 03-07-2016, 07:53 PM   #18
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I'm running -2.1,-1.3. I never said the car is faultless, but if you don't know how to instegate or prevent a particular situation as the driver, making the car more capable will only get you into trouble sooner. But whatever, I guess I'm too narrow minded by looking further ahead than just this.
The Following User Says Thank You to boredom.is.me For This Useful Post:
strat61caster (03-07-2016)
Old 03-07-2016, 07:56 PM   #19
DarkSunrise
DarkSunrise's Avatar
As others have said, before spending money on a rear bar, try camber bolts and an alignment. Aim for -1.5 degrees camber in the front & 0 toe all around. I found that was a near neutral alignment at the track with the 2013 suspension on worn NT05 tires. It had a little more understeer on fresh BFG Rivals, but still quite balanced.
2022 BRZ Build
2013 FR-S Build
DarkSunrise is online now   Reply With Quote
Old 03-08-2016, 11:19 AM   #20
Ashikabi
Ashikabi's Avatar
More camber, won't hurt your tire life. Cornering too hard and rolling your tires because you don't have enough camber will affect tire life. Get more camber.
Old 03-08-2016, 11:53 AM   #21
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Figured I'd jump in here when i read that our STB was making your car understeer!
Everyone here has already pretty much nailed it, but the car always understeered, you're just more willing to push it to that limit. Front engine, rear wheel drive "performance cars" are almost always set up to default to understeer as it is the perceived "safer condition" compared to oversteer.
And the change that you're sensing (despite what everyone here who maintains the "strut bars do nothing mentality despite having not done the testing and not owning one, let alone ours) is that the strut tower bar really is keeping the tension and compression between the two towers tied together. No longer is one towers going left and the other right over a bump or through a turn, they both are opposing the forces and either going one direction, or none at all. The most surprising thing I learned was in a turn (we posted all this data in our development thread) was that the loading on the strut towers was cyclic, that is alternating between tension and compression. Granted these are very small deflections, but when those deflections are going the opposite directions of each other they double. When They are tied together they don't anymore, and end up with deflections in the same direction. This lends to more predictable handling because the car isn't gaining and losing camber and more importantly toe on opposing wheels when going through a turn.
So, there are some good suggestions in this thread (and don't worry about camber wear if your toe is correct, toe is the tire killer). But i mainly chimed in to remind everyone about the rear suspension design and rear strut bars:
A front strut bar is effective because there is no material between the two front strut towers. Also the strut is connected directly to the spindle and thus wheel in a very stiff, solid connection.
The rear strut towers have a lot of material between them. Some obvious and some non-obvious. But the springs and shocks are connected to the lower control arms, and hinged. So the strut tower bar would see 0 to near-0 lateral load, and very very little "up and down" load.
So I'd put your money elsewhere too
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
EssJay (04-12-2016), GeorgeJFrick (03-08-2016)
Old 04-12-2016, 02:29 PM   #22
EssJay
Thanks Chase! It definitely sounds like dialing in a bit of neg. camber (and maybe a slight drop) is my next journey!
FS: Grimmspeed Front Tower Strut Bar ThatBlueBRZ Canada Classifieds 1 07-21-2015 01:06 AM
Grimmspeed front plate relocation kit vroom4 Exterior Parts (Aero, Lighting, Etc.) 15 01-25-2015 08:53 PM
GrimmSpeed front license relocation Blastersix Exterior Parts (Aero, Lighting, Etc.) 1 01-02-2015 05:29 PM
[WA] Grimmspeed front strut bar - red Fizz Australia Classifieds 0 12-02-2014 04:33 AM
Grimmspeed Front Strut Bar Vlady Engine, Exhaust, Transmission 3 04-23-2014 03:46 AM
