Old 03-07-2016, 01:05 PM   #15
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I tow using the factory hooks in the front and straps through the wheels in the rear. Those Rennline hooks that @IPGJames linked to look interesting though. I may pickup a set now that I know they exist.
FrX is offline   Reply With Quote
Old 03-07-2016, 11:42 PM   #16
justint5387
Drives: 4 wheels
I used the factory recommended spots. T hooks thru the oval hole
justint5387 is offline   Reply With Quote
Old 03-08-2016, 12:15 PM   #17
JimR
JimR's Avatar
Drives: '15 FR-S, '92 Sentra SE-R
I may look at that. I have strapped down some friend's domestic cars with T-hooks in the chassis slots, but haven't thought about that on the FR-S. Prior to now, I have owned only cars with factory eye hooks on all four corners.
JimR is offline   Reply With Quote
Old 03-08-2016, 12:18 PM   #18
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Every time I come in here, I quickly scroll down the page to see a picture of an 86 strapped down to a trailer. Nothing yet. Just because...
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 03-08-2016, 04:45 PM   #19
philooo
Drives: 13' Scion FRS Track car
ok posting some
philooo is offline   Reply With Quote
The Following User Says Thank You to philooo For This Useful Post:
LOLS2K (03-16-2016)
Old 03-08-2016, 05:46 PM   #20
FrX
Some images where you can sort of see how I strapped down the car:
The Following 2 Users Say Thank You to FrX For This Useful Post:
LOLS2K (03-16-2016), Sisko's_Baseball (12-29-2019)
Old 03-08-2016, 08:09 PM   #21
ka-t_240
You guys have some really nice trailers. I wish we had better options here.
ka-t_240 is offline   Reply With Quote
Old 03-08-2016, 08:55 PM   #22
ls1ac
ls1ac's Avatar
note several straps to the back, you can control how fast you accelerate but not how fast it maybe necessary to stop.
trailer is a rollback, the axels move to the front of the trailer for load and unload. very handy for very low cars.
The Following User Says Thank You to ls1ac For This Useful Post:
DocWalt (03-09-2016)
Old 03-10-2016, 09:59 PM   #23
jmimac351
Chin Chief Instructor
jmimac351's Avatar
Drives: 2015 Ford F150 Aluminium Couch
Originally Posted by redlined600 View Post
I think he was stating where he was intending to tie the vehicle down.
I think this is how I have done mine as well. I really don't like going through the wheels though. Hooks(eyelets) on the rear subframe would be awesome.
Edit*
Here is what the manual recommends
I do the above with T-hooks from Northern Tool. I've towed several different cars on a trailer MANY times. So far, this is my favorite setup. The straps are staying snugger than in other setups. For the T-Hooks, I pull the straps straight back to the rear mounts. Some cross them. You need to be careful about the angle when you cross straps. Too much of an angle adds an exponential amount of stress to the strap. I'm not worried about the car going from side to side on the trailer, I'm worried about the car going forward or backwards under braking or acceleration.
I leave the car out of gear, and pull the e-brake. Hookup to the factory hooks in front, use T-Hooks in the rear with the straps pulled straight forward and straight backward. I just did a trip from Orlando to VIR for a Chin event this past weekend and didn't have to touch the straps once on stops.
T-Hooks here: http://www.northerntool.com/shop/too...ct_43572_43572
2015 Subaru BRZ
2008 NC Miata with 2.5 swap
Building 1963 289 Cobra Le Mans Replica
Cobra Replica Build Pics
Chin Chief Instructor www.ChinTrackDays.com
jmimac351 is offline   Reply With Quote
The Following User Says Thank You to jmimac351 For This Useful Post:
TMF (01-23-2019)
Old 03-10-2016, 10:04 PM   #24
jmimac351
jmimac351's Avatar
You want straps that have this sort of end on them to fit both the factory front mount hooks and the T-hooks. Regular tow straps do not fit. These also have a spring loaded closure so they stay attached even if you get a little slack in them. The link posted above to the Summit straps with the ratchet mechanism at the far end is a good idea. It keeps you from trying to operate the ratchet mechanism as it gets close to or under the front or rear of the car. I plan to pickup a setup of those but I think I may need more than 6' in length to use the t-hook setup in the rear.
2015 Subaru BRZ
Old 03-11-2016, 09:39 AM   #25
ka-t_240
What is everyone's thoughts on gettign custom lenght straps made, with out ratches. Just straight strap with the appropriate ends for the front, then having ratchet straps on the rear?
Old 03-11-2016, 10:13 AM   #26
jmimac351
jmimac351's Avatar
Not a good idea. If the car isn't straight, one of the straps will have slack. To unload the car, you're going to have to move the car forward to get slack in the straps. You're just making more work for yourself. Since I load the car with the parking brake on, I just pop my straps loose all around and I'm ready to back the car off. If you're trying to get the car in the same spot on the trailer each time, rather than use straps of a defined length, put something on the trailer that you pull up to and against with the front tire. See the picture above for someone who did just that. I didn't even go that far. I marked a spot on my trailer and I put something on it that I pull up against. Then I toss it back in my trailer box.
2015 Subaru BRZ
Old 03-11-2016, 12:22 PM   #27
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
I use axle straps wrapped in soft covers through the wheels.
Sleepless is offline   Reply With Quote
Old 03-11-2016, 08:23 PM   #28
philooo
Be careful with the Macs strap I linked to earlier.
They are the greatest strap quality, but the hook are a little too big for the front transport "loop" under the front. they do hook and close but they are very thick and when you add tension to the strap they will not be able to stay aligned with the strap, they will be "trapped inside the transport hook" . I'll try to get a pic to illustrate. Hard to explain
Towing with the FR-S tobkin Scion FR-S / Toyota 86 GT86 General Forum 36 08-21-2020 01:08 PM
towing capacity? CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 24 11-30-2019 11:34 AM
Towing a FRS Lunatic Scion FR-S / Toyota 86 GT86 General Forum 7 07-24-2014 10:55 PM
Towing with the FR-S CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 23 07-18-2012 09:34 AM
