go_a_way1, MisterSheep
Old 02-22-2016, 07:32 PM   #15
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
ST, Bilstein B14, Flex Z
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
wparsons (02-23-2016)
Old 02-22-2016, 08:02 PM   #16
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by MrStickers View Post
I was looking at the tein flex z but heard from reviews that they blow out quick. And I'm just thinking about dropping it 1.5-2" at most. Can't really go too low cause the roads are pretty trash. I want the camber plates because I've learned in the past that 0 toe and 0 camber takes out less $$ out of my pocket in the long run on tires.
0-0 camber and toe also makes for terrible handling when lowered 1.5-2 inches but carry on
fumanchu1 is offline   Reply With Quote
The Following 2 Users Say Thank You to fumanchu1 For This Useful Post:
cdrazic93 (02-23-2016), wparsons (02-23-2016)
Old 02-22-2016, 08:07 PM   #17
fumanchu1
used kw v3? Seriously I wouldn't touch any of the 2 you asked about with a 10 foot pole. Suspension is literally one of the 3 most important things on your car, why would you cheap out on that? aside from rubber, it's the only thing keeping you on the road so one would think you wouldn't want to skimp out on that aspect but wtv you seem to already have made your mind (like others have said and you just want someone to confirm what you have made up in your mind). Unfortunately for you, most people in this section actually know a thing or two abnout suspension and will not suggest that you install crap coilovers on your car (that's why everyone is recommending other products).
Anyways you want them in pink(megan), blue(cusco?), green(tein), red(godspeed),black(Bc). They most likely come from the same factgory anyways.
Old 02-22-2016, 08:18 PM   #18
MrStickers
Drives: 2013 Subaru BRZ Premium
Seriously? Since when is spending $1k on suspension cheaping out? Since when is megan racing trash? Also, since when the fuck is TEIN garbage? TEIN was and still is one of the most respected suspension brands out there. It's a damn daily, not a everyday track car.
2000 BMW 323i
MrStickers is offline   Reply With Quote
Old 02-22-2016, 08:21 PM   #19
Knshro13
Drives: 10 series FRS
ST.
best bang for your buck.
Knshro13 is offline   Reply With Quote
The Following User Says Thank You to Knshro13 For This Useful Post:
STV3 (02-23-2016)
Old 02-22-2016, 08:27 PM   #20
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Megan has always been trash. Tien in the 90s sucked too. The Flex Z are legit though. Non bouncy comfort costs money. Pretty much anything else not mentioned under $1k would be outperformed by good springs (RCE, Swift, Eibach Prokit) especially considering our struts are pretty good stock
Old 02-22-2016, 10:05 PM   #21
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
There are suspension systems that literally cost 10k plus. Of course, that's entirely overkill, especially for somebody like yourself with your goals for the car.
You have to understand that for $1,000, you're buying an ENTRY LEVEL coil over system. So you have to expect to get what you pay for. It's like buying a car. You can't buy a CLA Mercedes, which is the entry level car that costs 32k, and expect to get the same luxury as you would in a $100,000 S class. It just doesn't work that way.
So when you spend the minimum on coilovers, expect to get the minimum in terms of R&D and quality. It's just the way it works.
From the sounds of your responses, you sound pretty set on what you want. Best of luck.
Originally Posted by Knshro13 View Post
ST.
Ken Gushi is a well established diver and knows his stuff. I'd listen to him; even if he's sponsored by KW, which is ST, and he might have a bit of a bias lol.
Megan has always been trash. Tien in the 90s sucked too. The Flex Z are legit though. Non bouncy comfort costs money. Pretty much anything under $1k would be outperformed by good springs (RCE, Swift, Eibach Prokit) especially considering our struts are pretty good stock
Yes. Megan has never exactly been a name associated with "quality". Back in the early 00s, people in the 240 community would cross shop between Megan, Circuit Sports, and EBay suspension arms. They've always been considered a lesser-than part.
That doesn't mean they're going to spontaneously combust or anything.mhowever, don't buy them and expect to have some godsend handling in your vehicle- even though people really believe they substantially improve the handling of their cars.
And yes again. TEIN really was considered to be a subpar company back in the day. Their basic/entry level stuff was trash, but their high end stuff was good. From the sounds of things lately, it seems as though TEIN has stepped it up a bit, especially on their lower level stuff.
OP: for your car, based on the info and budget you've given, I think mt of us here will recommend ST. You really can't beat them for the money. Even a good spring would be an improvement over stock and a lot of the coilovers systems in that sub $1,000 price range.
Please remember: STIFFER DOES NOT AUTOMATICALLY MEAN BETTER HANDLING!
TylerLieberman is offline   Reply With Quote
The Following 5 Users Say Thank You to TylerLieberman For This Useful Post:
8R6 (02-23-2016), Apex-Apex (02-23-2016), finch1750 (02-22-2016), Knshro13 (02-22-2016), STV3 (02-23-2016)
Old 02-22-2016, 10:13 PM   #22
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
I was just at the Tein Factory in Yokohama less than a month ago and they definitely make stuff in house. I'm not sure all models but they were building flex z's when i was there.
JDLAutoDesign is offline   Reply With Quote
The Following 3 Users Say Thank You to JDLAutoDesign For This Useful Post:
DAEMANO (02-23-2016), finch1750 (02-22-2016), fumanchu1 (02-23-2016)
Old 02-22-2016, 10:25 PM   #23
Knshro13
haha I may have a bit of a bias but all bias-ness aside, I seriously think ST coilovers are great for what they cost.
I personally have KW V3 on my street car and ST on my dad's FRS. For a budget of <1000, I'd go for ST all day.
But Tein Flex Z is not bad either.
The Following 3 Users Say Thank You to Knshro13 For This Useful Post:
8R6 (02-23-2016), STV3 (02-23-2016), wparsons (02-23-2016)
Old 02-23-2016, 12:45 AM   #24
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
"Tein" is a brand. They make dampers from $500 to $14,000. To say their top end dampers is the same as their bottom end dampers is just wrong.
Old 02-23-2016, 12:53 AM   #25
Captain Snooze
Drives: Red Herring
The Following 10 Users Say Thank You to Captain Snooze For This Useful Post:
8R6 (02-23-2016), calmtigers (02-26-2016), Calum (02-23-2016), cdrazic93 (02-23-2016), finch1750 (02-23-2016), Kestrel (02-23-2016), Kristjan (02-23-2016), Strife26 (02-24-2016), STV3 (02-23-2016), TylerLieberman (02-23-2016)
Old 02-23-2016, 04:45 AM   #26
Apex-Apex
Apex-Apex's Avatar
I would just go with Godspeed.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 02-23-2016, 05:27 AM   #27
Captain Snooze
Drives: Red Herring
I was looking at the tein flex z but heard from reviews that they blow out quick. [1] And I'm just thinking about dropping it 1.5-2" at most. [2] Can't really go too low cause the roads are pretty trash[2]. I want the camber plates because I've learned in the past that 0 toe and 0 camber takes out less $$ out of my pocket in the long run on tires.
1/ You've been told (heard) or you have read? People are more likely to post bad reviews than good. That is, they are more likely to complain about about a bad experience. For this to be meaningful you would have to know the conditions under which the dampers failed and also the total number of dampers sold. If there were 10 bad reports for 15 dampers sold then they are crap. If 2 million were sold then they are reliable.
2/ You are giving conflicting goals. You have "trash" roads but are wanting to drop 1.5". Suspension needs travel to work, especially at your budget.
Mike from CSG rates the Flex Z. His opinion is worth taking note of.
http://www.ft86club.com/forums/showthread.php?t=81829
Old 02-23-2016, 08:31 AM   #28
Foxystyle
Drives: FRS / S13
A thing to keep in mind is that many of these entry level coilover companys all source their dampeners from the same taiwanese manufacturer. In the end, it is all very similar in terms of performance. Megan, ksport, bc, godspeed, fortune, stance many of these similar companies source from the same or similar venues. The difference in price is when it comes to purchasing a fully assembled Megan piece from Taiwan, or a "assembled" in US with maybe or maybe not a dyno quality check state side, like Fortune claims. If you go fortune, I wouldn't do prime, at least do the 500s. Stance is another worthy option to look up on, as they're an inverted mono strut (if thats the proper term). Either way, you spend 700-800 on trash, 1k on longer lasting performance, or 6k-10k on racing application performance. I've owned ksport in the late 00's, stance supers a few years ago, fortune 510's, and have riden in Megan streets and tracks. Megan was by far the worst, they're the coilovers you put on to tow your car to not damage your nicer dampers. Swift coils are a worthy option to consider, as they may safe you from a shitty damper; with a proper revalve.
Foxystyle is offline   Reply With Quote
*Coilover Systems* | Fortune Auto 500|510 :: | BC Racing BR|ER |:: Tein | *KamiSpeed* Kami Speed Brakes, Suspension, Chassis 143 10-21-2014 05:35 PM
PTUNING Coilovers Ohlins, Fortune Auto, BC Racing and More! Ken@PTuning Brakes, Suspension, Chassis 17 02-28-2014 12:19 PM
Enjuku Racing - Fortune Auto 500 Series Coilovers ** In STOCK ** Enjuku Racing Brakes, Suspension, Chassis 0 04-10-2013 06:43 PM
Fortune Auto vs BC Racing D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 09-11-2012 11:18 AM
