Old 02-18-2016, 01:13 PM   #15
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Originally Posted by drewbot View Post
The new MTO safety rules that everyone is getting butthurt about now explicitly mentions spacers.
Hub adapters, say 5x100 to 5x114.3, may be legal but reads like it is up to the discretion of the safety tech.
Catless headers on this platform are illegal, yes. Many people put them on and pass emissions by bypassing ready sensors. You cannot do the same with spacers.
In the end, as long as you are aware that what you are doing is not street legal, it's up to you on how you decide to proceed. Spacers would just be on the list of a roadside blitz inspection, just like improper HID kit, improper muffler, improper wheel/tire size, wrong coloured fog lights, blacked out tail lights, etc.
Well, thanks for the heads up man! This kind of changes everything now lol
I'm going to think about it, but i might just get a new set of rims in the future than and stay legal.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 02-18-2016, 01:23 PM   #16
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I read the rules and the Ichiba v2s would be legal because they qualify as an adapter and those are legal as long as they aren't damaged. Regarding running the V2s, the stock wheel hub has indentations so you can run these type of spacers no problem.
Relevant rules copied straight out of the MCO .pdf document:
7. Wheel / Rim (General)
Note:
A Spacer is a solid piece of material intended to offset the wheel outboard. It has holes in it through which the studs pass without engaging the spacer.
An Adapter is a spacer that is attached to the hub with fasteners. The wheel is attached to the adapter by nuts on studs mounted in the adapter.
Reject if:
- wheel / rim is damaged, broken, bent, cracked or distorted
- wheel / rim has been welded or repaired in a way that does not meet industry standard
- there is less than 3 mm clearance between butt ends of the lock ring on a multi-piece wheel / rim
- incompatible wheel or component isused on a wheel system
- spacer has been used between any wheel and hub
- adapter is damaged, has damaged fasteners, fasteners of inadequate length, inappropriate material or incorrect grade of stud, nut or bolt
- wheel is installed incorrectly
- there is evidence of damage or deterioration, foreign material, excessive or uncured paint on a hub, drum or wheel-mounting face
Of course, my opinion is get new rims anyway but that is just because I don't like the look of the stockers.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
Mr.Impreza (02-18-2016)
FS: Ichiba Spacers cfig21 Wheels and Tires 34 06-30-2016 05:10 PM
For Sale: Ichiba Spacers RehabJeff86 Wheels and Tires 8 08-11-2015 01:44 PM
For Sale: Ichiba Spacers RehabJeff86 Brakes, Suspension, Chassis 4 08-11-2015 01:43 PM
FS: 2 Ichiba 15mm spacers sw20kosh Brakes, Suspension, Chassis 3 08-04-2014 01:20 PM
Ichiba Spacers - 25mm phatpanda Wheels and Tires 1 03-19-2014 04:16 PM
