#15 |
Minor correction, they do actually shift the spring mounting point from OE top hats, I'll definitely try to post a picture of the OE rears later, but it's inconsequential for every height adjustable coilover I've seen as you can easily move the spring perch up to compensate.
#16 |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
I haven't driven on the Ohlins, so I can't compare, but I can say that a lot of people don't realize what you get with the KW V3s. They have low and high speed compression valving. That is huge...it's like the holy grail of suspension. Normally to get separate lo/hi speed compression valving, you need Motons or high end Ohlins stuff. The reason KW can do it so cheap, is because the high speed compression is not adjustable like on those more expensive setup. They use a fixed valve.
"So what does this mean for me?" It means that when your car goes over bumps and potholes in the road, harsh "high speed" events, there is a separate valve that cracks open and absorbs that impact. Normally that bigger valve stays closed, and the tighter "low speed" valving is controlling things, like body roll and brake dive, and that one is adjustable. So what you get is a car that handles like it has tight suspension, but rides like it has soft suspension. Plus it is more able to soak up mid-corner bumps while pushing it than typical stiff suspension. We have V3s on one of our S2000s and they are impressive, although they are also a bit soft all around, and the clubsports are a better performance version as I understand it. Hope that helps!
#17 | |||
A.K.A. Starlord
Drives: 2015 Series.Blue
I think I'm leaning towards the V3s. I could keep going for better and better options, but I'm not sure if it's really worth the price differential unless I was doing a lot of tracking and planning on constantly tweaking the suspension all the time. Plus the money I save on the V3s I can put towards some good LCAs. I definitely am not interested in the MP20 Ohlins if they are softer than stock! Quote:
So this is what I'm thinking at this point for a setup that will be good for DD use, and adequate for a bit of autocross and track use: Coilovers: KW V3 Front Camber Plates: Raceseng Rear Strut Mounts: OEM Rear LCAs: Stance V1.0 (20mm drop) Total Cost: $3,162.98 shipped Rear LCAs are the last thing I need to decide on. I'm told the most important thing is that they have an Aurora bearing, as that will "outlast the life of the car" as compared with... not an Aurora bearing. Just looking on ft86speedfactory alone I see, like, 10 different LCAs to choose from, and I have no idea where to begin. They all seem to be around the $500 mark. Seems like it's just down to what color you want, or which manufacturer you want to support (I just want black! I hate the look of bright, colored LCAs poking out under the car. Just makes it look like the rear bumper is too short.) I'm told I should just get the Stance ones. At least they're a dark brown color, and they have the Aurora bearing. I was looking at the Stance LCAs and they have 2 versions: One of them raises the hub 20mm, and the other raises it 60mm. I'm assuming the 60mm one is for slammed cars. From the description: Quote:
http://www.ft86speedfactory.com/stan...l#.Vr5rN_krJhE
#18 |
Stock rear top hats with Bilstein springs, compare the plane where it bolts to the chassis and where the spring sits to the images above, the spring will be moved up towards the chassis a good ~1" on the raceseng top hat, not a bat thing for height adjustable coilovers.
#19 |
A.K.A. Starlord
I wound up ordering the Raceseng front camber plates, and the Velox STX rear LCAs. I'll be ordering KW V3s in a few weeks. Between those three things, am I missing anything that I will need to perform this install myself (other than the requisite tools), or is there anything else that is highly recommended to replace at the same time?
Really appreciate everyone's input. Made the decision easier, and made me more confident that I chose the right parts! |
#20 |
AutoX-10/10ths every run
I'd get at least 1 set of these to put under the front springs to prevent spring bind when turning the front wheels.
http://www.summitracing.com/parts/eib-trb250/overview/
#21 |
Drives: Many
^If you run a radial bearing in the upper spring perch (like the Raceseng ones) you don't need those.
Also, those torrington bearings tend to get pretty cruddy if you street drive them, especially in the weather. Radial bearing upper mount is a much more elegant solution. |
#22 |
A.K.A. Starlord
Hooray! Glad I got the Raceseng camber plates then
#23 | |
Drives: WRB BRZ Series.Blue
V3's only have separate rebound & compression, no low speed compression adjustment. The Racecomp Tarmac 3 which is based on the KW Clubsport 3 way, has 3 way adjustments for rebound, and high/low compression. |
#24 | ||
Here, I'll make it even clearer: Quote:
https://robrobinette.com/S2000KWV3.htm
#25 |
Drives: 02 Celica GT
Was going through the same thought process as you and wondered how you were getting this deal on the V3s? That is a great price!!!
#26 |
A.K.A. Starlord
#27 | |
#28 | |
| Raceseng 2" Extended Rear Shock Mounts | Silverspeed | Brakes, Suspension, Chassis | 7 | 01-06-2016 03:53 PM |
| Rear shock top mounts | rick s | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-12-2015 11:32 AM |
| Raceseng 2" Rear Shock Mounts for BC Racing Coilovers | dmarkey | Brakes, Suspension, Chassis | 2 | 06-01-2015 05:17 PM |
| WTB: Rear OEM Shock | taimysho0 | Want-To-Buy Requests | 2 | 09-12-2013 11:23 PM |
| Color options Camber Plates, Stress Bar, & Shock Mounts | GC_Adam | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 03-26-2013 01:08 PM |
