Old 07-02-2012, 08:21 PM   #15
jimbobrand
jimbobrand's Avatar
Drives: 2013 Subaru BRZ Premium
Originally Posted by Razz View Post
The only thing wrong with those wheels is; it looks like your still 4 wheelin
Get it lowered.
Maybe someday but I'm enjoying not tearing up my front bumper on curbs or parking barriers.
Jim Brand
2013 Subaru BRZ Premium 6MT WRBP
Oklahoma Subaru Crew-OKSC.org
TXIC San Antonio
jimbobrand is offline   Reply With Quote
Old 07-02-2012, 09:35 PM   #16
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
Those look like they would be a lot of fun in a closed course
Exhaust is offline   Reply With Quote
Old 07-02-2012, 10:25 PM   #17
jimbobrand
jimbobrand's Avatar
From the few miles I got to drive them on the street, I'd say you're right.
Jim Brand
TXIC San Antonio
Old 07-24-2012, 02:59 AM   #18
sw20kosh
Drives: 2013 Black FR-S
WHen you say they had some rubbing issues and you recommend +42 or +40, do you mean that:
1. The problem is in the front?
2. The rubbing is on the spring coil/strut and not the fender?
Old 07-24-2012, 03:39 AM   #19
Midnight Run
Action Thriller
Midnight Run's Avatar
Drives: E46M3
I believe he meant the tires are rubbing inside the fender linings when he turns right.
The 245/40/18 R-comps tires he has now maybe much wider and slightly taller than factory/OEM wheels/tires setup.
Midnight Run is offline   Reply With Quote
Old 07-24-2012, 08:10 AM   #20
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by Eric@GetYourWheels View Post
If you run a +42 or +40 this will push the wheel out further than the +45 you have now.
Originally Posted by jimbobrand View Post
I know. The tire wasn't rubbing on the fender.
I put about 30 miles on the setup and only experienced slight rubbing when I had the wheel turned all the way to the right driving in tight circles (this didn't happen when turning left). The car is still on stock suspension and I think this combo might rub the fender if lowered since the tires stick out a little ways from the fender. Also, I think a +42 or 40 offset would be better for this combo of width and tire. I'm planning on refinishing the wheels, since several have curb rash, and going with a 225/40/18 or a 235/40/18 street tire when I get back from a TDY in August.
Why would you want a lower offset if
a) you think it's going to rub the fender (from inside or outside? its not clear)
and
b) the tire pokes a bit already
since a lower offset on the same width wheel is only going to stick out more.
From what I have seen, your fitment should actually be spot on, and maybe a small spacer in the back would be perfect.
But you have to provide us with is the shot from the rear since we can't go on whats been posted. Do it wen you get back.
It's likely that you WONT rub if you lower it. Actually it'll probably make them fit better, if anything.
That being said, they look really good on your car. If you don't want em, I'll take em...
dori. is offline   Reply With Quote
Old 07-24-2012, 06:52 PM   #21
jimbobrand
jimbobrand's Avatar
It currently doesn't rub the fender with stock ride height (but would if lowered) but seems to rub the suspension on full right lock when driving in a circle (also it doesn't rub much). A 42 or 40 offset might work better with the current 245/40/18 R compounds at stock ride height on the front but the 45 offset wheels will be better overall when I go to a street tire of either 235/40 or 245/40/18 and lowered. The R1's are only temporary and came with the wheels so I could test fit them on the car. The wheels and tires are in another state at the moment until I have the time and cash to get some street tires and refinish the curbing on a couple of the wheels.
Jim Brand
TXIC San Antonio
Old 07-24-2012, 06:54 PM   #22
jimbobrand
jimbobrand's Avatar
Also, as stated, it only rubs the suspension in the front. The rear has tons of room.
Jim Brand
TXIC San Antonio
Old 07-26-2012, 01:13 AM   #23
BRZranger
Originally Posted by ultra View Post
Meaty. I like the look.
TWSS.
BRZranger is offline   Reply With Quote
Old 08-20-2012, 05:32 PM   #24
jimbobrand
jimbobrand's Avatar
A couple new pics with the Gram Lights w/ 235/40/18 Hankook Ventus Evo 12 tires:
The new tire combo has absolutely no rubbing and doesn't poke beyond the front fenders like the race tires.
Jim Brand
TXIC San Antonio
Old 08-20-2012, 08:21 PM   #25
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Looks good i think 235/40 is the way to go if you aren't lowering for sure.
JoeBoxer is offline   Reply With Quote
Old 08-20-2012, 09:40 PM   #26
jimbobrand
jimbobrand's Avatar
Thanks! I came pretty close to getting 245/40's or 245/35's but decided on those for the time being.
Jim Brand
TXIC San Antonio
Old 09-25-2012, 10:35 AM   #27
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Say u were to wanna lower it 1" or 1.5". What would need to be adjusted to have them fit
karma003 is offline   Reply With Quote
Old 09-25-2012, 10:45 AM   #28
jimbobrand
jimbobrand's Avatar
I'm pretty sure as it sits with the 235/40/18 Hankooks on the Gram Lights it wouldn't have any rubbing issues if lowered. I'm just not in a big hurry to lower the car. Also, it looks like you could maybe go a little wider in the front with lowering but I'll have to wait a while to test that out.
The 245/40/18 R-compounds are much wider than a typical street 245/40/18 and I don't think you can fit them with the car lowered without modifying the fenders or running a decent amount of negative camber.
Jim Brand
TXIC San Antonio
The Following User Says Thank You to jimbobrand For This Useful Post:
karma003 (09-25-2012)
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 jadewbj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 378 06-26-2017 05:57 AM
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 06:46 PM
Wheel Directory: Gram Lights 57FXX 18x8.5 +45 r4m3n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-17-2014 02:22 PM
Wheel Directory: Gram Lights 57DR 18x8.5 +38 JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 06-26-2013 12:44 AM
Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-05-2012 12:44 PM
