#15 |
Drives: Impretzal
Well when I said originally, I meant the path I took for it, not buying it for drifting if you know what I mean. There are better cars out there for that specifically :p.
#16 | |
Drives: Impretzal
Stock torsen LSD Rear and front sways -2.3 camber front -1 camber rears KW3 coilovers dropped 1.5 hard suspension 2 clicks away from full Volk te37 17x9 +36 offset squared Wasp front splitter, aeroflow dynamics canards, aeroflow side skirts and rear diffuser. To answer daemono's wholesale comment. It was actually the splitter first then the underpanels and sideskirts. I didn't notice too much oversteer with just the splitter so it seemed perfect for a/x; at this point didn't even need any other aero. But for drifting it felt as if I had a bit of understeer so I opt'd in getting the front canards. Call me crazy, but I honestly like the torsen diff. I was thinking about getting a 2 way / 1.5 way to help kick out of a drift and connect to the next but wasn't really a big fan of clutch types. |
| The Following User Says Thank You to MyNameIsCacauate For This Useful Post: | MisterSheep (01-27-2016) |
#17 | |
Time Traveller
| The Following User Says Thank You to DAEMANO For This Useful Post: | SkAsphalt (01-28-2016) |
#18 | ||
But from that response, I can tell a few things. 1. not enough rear camber. need to work on alignment. no mention of toe settings. 2. Stock KW spring rates are pretty low on lower end models, not sure on the kwv3 3. no mention of damper settings front or rear, probably too stiff. 4. no mention of tire. need to work on alignment/tire temps/pressure 5. a/x and drifting are two different setups. Alignment and Tire setup/tuning goes a long way. You can certainly buy a wing and it will probably help. But it will just mask problems in the current setup. Last edited by swarb; 01-27-2016 at 05:19 PM. |
| The Following User Says Thank You to swarb For This Useful Post: | SkAsphalt (01-28-2016) |
#19 | |
Drives: 2013 Firestorm FRS
| The Following User Says Thank You to continuecrushing For This Useful Post: | SkAsphalt (01-28-2016) |
| AERO Kit for sale (Factory Toyota AERO Kit) | GTS86 | Exterior Parts (Aero, Lighting, Etc.) | 28 | 02-11-2017 08:34 AM |
| PW:JDM Aero for your FR-S!!! | password:jdm | Exterior Parts - The Rest | 99 | 01-28-2015 03:16 PM |
| Aero Fin | cslntuee | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 04-16-2014 10:53 AM |
| aero kit | ric342 | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 09-23-2012 07:15 AM |
| GTS Aero! | Staticfrost | AUSTRALIA | 11 | 06-15-2012 07:07 PM |
