Old 06-28-2012, 08:53 AM   #15
UncleFester
I weighed my stockers and they were at ~ 20.6 lbs.
UncleFester is offline   Reply With Quote
The Following User Says Thank You to UncleFester For This Useful Post:
bestwheelbase (07-03-2012)
Old 06-28-2012, 10:40 AM   #16
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Wish I knew where to order SSRs...although they're not cheap!
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 06-28-2012, 01:14 PM   #17
WRB-DZA-BRZ
Cookie Monster
WRB-DZA-BRZ's Avatar
Drives: 2013 Subaru BRZ Premium 6-MT WRB
I wonder if my 15x6.5 Konig SubZeros from my Neon would fit over the BRZ brakes.... Those are light weight, 12.9lbs. Probably not.
But I am interested in 16" light weight wheels for the BRZ. Has anybody installed 16" wheels besides the factory jdm wheels?
WRB-DZA-BRZ is offline   Reply With Quote
Old 06-28-2012, 01:50 PM   #18
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
RS Watanabe F8F Magnesium 17x7 13.2 lbs
RS Watanabe F8 Magnesium 17x8 12.8 lbs
i think offset is +40 for both
it's weird. those are the weights posted on their website but for some reason the 8" wide rim is lighter?
cyde01 is offline   Reply With Quote
Old 06-28-2012, 01:59 PM   #19
kanundrum
Drives: 2013 Whiteout FR-S
Its not really about weight of the wheel but the tire.
I thought I would have massive weight difference by switching over to the RPF1's that are 17 x 8 15.4lbs
How ever the New Tires I put on that are 245 Section Width weighs 25lbs so it turns out the New Combo is about 40.6lbs making it exactly the same as stock weight of tire and wheel.
How ever you are running more rubber and more wheel making it more beneficial. If you are just thinking about weight alone stick with 17 x 7's and a small tire and you can get your lightweight
Old 06-28-2012, 02:03 PM   #20
trifenix
Drives: Toyota Tacoma
Thinking lightweight 16s or even 15s if they will fit over the calipers.
trifenix is offline   Reply With Quote
Old 06-28-2012, 02:15 PM   #21
xwd
When moving to larger tires, I always look at the lightweight rim not as a means to save a bunch of weight on the car overall, but to offset the weight you are gaining in larger tires.
Now if you are using stock sized rims/tires then it's overall weight reduction.
The Following User Says Thank You to xwd For This Useful Post:
makesdrivingfunagain (08-03-2013)
Old 06-28-2012, 03:56 PM   #22
WRB-DZA-BRZ
Cookie Monster
Here is what I'd like to see...
Enkei Racing RPF1 16x7
Offset: +35mm (will this fit??)
Backspacing: 5.35"
Weight: 13.7lbs
Price: $207 each on TireRack
Hankook Ventus R-S3
Tire Size:225/50-16
Weight: 25lbs
Price: $123 each on TireRack
Apparently Tire Rack shows 16" wheels/tires if you go to the winter section.
Old 06-29-2012, 07:05 PM   #23
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
updated
quik1987 is offline   Reply With Quote
Old 07-06-2012, 03:05 AM   #24
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Havent ordered the BRZ yet, but already bought 9 wheels for her
1 set in white for slick time attacks
1 set in Takata Green for dorifto's
Forged, Custom made
8J*17
PCD: 5*100
Dia: 56,1 мм
ЕТ: +39
525kg load
and the most amazing thing - 6,09 kg = 13,4 lbs in weight ))
MSTiFK8R is offline   Reply With Quote
Old 07-06-2012, 10:23 AM   #25
xwd
And what brand/model are these mystery wheels?
davtbaum (06-07-2013)
Old 07-06-2012, 12:25 PM   #26
FTD
Drives: 2002 WRX
Originally Posted by dwx View Post
Motegi Traklite's in 17x7 +42 are 14 lbs.
Where did you locate these? Are they still in production? Seems like a good solution so long as the rear fender lips aren't an issue.
FTD is offline   Reply With Quote
Old 07-06-2012, 02:27 PM   #27
yoshiharadesign
Post
d-12c 18x8 +40 19lbs
our sister brand:
Velox vx-6R 17x7 +40 14.5lbs
Velox Glide 17x7.5 +40 16.5lbs
Velox PG-5S 17x7 +40 12.5lbs
Velox PG-5S 18x7.5+42 16.5lbs
yoshiharadesign is offline   Reply With Quote
Old 07-06-2012, 02:31 PM   #28
yoshiharadesign
sorry.. forgot about the pics.
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
TRD Wheels Re~Mix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 06-27-2012 06:11 PM
Forgestar wheels, great wheels at great prices!!!! IslandImportPerformance Wheels and Tires 0 06-15-2012 05:03 PM
O.Z. Wheels Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 02-28-2012 03:21 AM
Top 10 Lightest 300 Horsepower Cars Axel Other Vehicles & General Automotive Discussions 2 11-22-2009 02:23 AM
