| Engine Swaps Discussion of engine swaps. |
#15 |
That Guy
Drives: 2013 asphalt FRS MT
#16 |
#17 |
More than anything I'm wondering what they did to get the engine to sit that low.
It's not the first time it's been done, and I may have been involved in a few projects, but the engine is particularly tall, and didn't fit well in the engine bay. |
#18 |
That Guy
Does the F20C normally sit at the angle?
#19 |
Drives: white subaru brz
#20 |
#21 |
#22 | |
Sporadic Member
Drives: 2016 Halo FR-S M/T
This might not be a good example, but here it is anyway: [ame="https://www.youtube.com/watch?v=_XIyS4vTch8"]Nyce1s.com - Jake Gavio's F2K Civic @ Honda Day Atco 2011!!! - YouTube[/ame] |
#23 |
#24 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
This is a "I did it because I can" type swap. Still believe this car should've came with some sort of inline engine...
#25 |
Drives: Corn Juice junkie
FRS with a vvt-I engine from their line-up. I would test drive it.
#26 | |
Drives: '23 BRZ
How so? It might be stiffer, but the S2000 offers better weight distribution (49/51 vs. 53/47) and double-wishbones. Not that I have anything against struts, I don't, but double-wishbones do have the advantage of not requiring as much static camber. Weight distribution isn't a big deal at stock power levels, but with additional power, more rearward c.g. becomes more of an advantage.
I'm not a fan of the AP1's rear toe change with bump, but that can be addressed... Quote:
![]() I would LOVE to have a twin with F20C/F22C power... |
#27 |
...Just add nauseum
Drives: 2003 (AP1) S2000
This is the swap forum, so I won't bother to address all the issues you raised in that post, thought it pains me not to do so.
But the hoodline / headspace question you raised is valid, and here is the answer. The twins have the thick, tall front crossmember basically straight on the axle line, and steering rack immediately behind it. Any engine in there must sit atop those 2 pieces. In the s2k, the steering rack, and the main body of the crossmember are in front of the motor. That enables the engine to sit much lower.
There are many ways to displace.
-Spartarus |
#28 | |
| F20C performance out of the FA20 | discretion | Engine, Exhaust, Transmission | 41 | 06-12-2015 10:37 AM |
| 2JZ swapped BRZ ... | rh9 | Engine Swaps | 32 | 12-08-2014 01:50 AM |
| How many of you Swapped your 86 for 15 WRX ? | Xti | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 08-09-2014 09:09 AM |
| F20c engine | Whitigir | Engine, Exhaust, Transmission | 4 | 11-03-2013 07:03 PM |
| BRZ Swapped with LS2 | weedtank | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 09-05-2013 05:02 PM |
