Old 01-14-2016, 04:21 PM   #15
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by jdmblood View Post
Saw this picture on tumblr and wondered if there was anymore info on this build. Seems interesting but I wonder why you wouldn't just buy an s2000
Shoulder room? I don't fit well in an s2000, but I do fit in a twin.
Old 01-14-2016, 04:21 PM   #16
CSG Mike
CSG Mike's Avatar
I only found those two pictures. Unless you got the brz chassis for extremely cheap, I dont see why you wouldnt just buy an s2000 or swap an ls instead.
Because the BRZ chassis is superior.
Old 01-14-2016, 04:23 PM   #17
CSG Mike
CSG Mike's Avatar
More than anything I'm wondering what they did to get the engine to sit that low.
It's not the first time it's been done, and I may have been involved in a few projects, but the engine is particularly tall, and didn't fit well in the engine bay.
Old 01-14-2016, 04:57 PM   #18
Calum
That Guy
Does the F20C normally sit at the angle?
Old 01-14-2016, 05:14 PM   #19
jdmblood
jdmblood's Avatar
Drives: white subaru brz
yea kind of
jdmblood is offline   Reply With Quote
Old 01-14-2016, 05:45 PM   #20
CSG Mike
CSG Mike's Avatar
Yes; it doesn't fit "straight" in a s2k either
Old 01-14-2016, 06:00 PM   #21
jdmblood
jdmblood's Avatar
You can also fit the f series motor for fwd correct?
Theres a guy who shows up to car meets in an ek coupe with an s2k dash but he wont pop the hood!!!
Old 01-14-2016, 06:09 PM   #22
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
It's been done. Someone even managed to fit a 13B rotary under the hood of an FWD Civic.
This might not be a good example, but here it is anyway:
[ame="https://www.youtube.com/watch?v=_XIyS4vTch8"]Nyce1s.com - Jake Gavio's F2K Civic @ Honda Day Atco 2011!!! - YouTube[/ame]
Old 01-14-2016, 07:25 PM   #23
CSG Mike
CSG Mike's Avatar
You *can* but it's not cheap or easy.
Old 01-14-2016, 09:50 PM   #24
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
This is a "I did it because I can" type swap. Still believe this car should've came with some sort of inline engine...
hmong337 is offline   Reply With Quote
Old 01-14-2016, 11:02 PM   #25
seito23
Drives: Corn Juice junkie
FRS with a vvt-I engine from their line-up. I would test drive it.
seito23 is offline   Reply With Quote
Old 01-15-2016, 07:36 AM   #26
ZDan
ZDan's Avatar
Drives: '23 BRZ
How so? It might be stiffer, but the S2000 offers better weight distribution (49/51 vs. 53/47) and double-wishbones. Not that I have anything against struts, I don't, but double-wishbones do have the advantage of not requiring as much static camber. Weight distribution isn't a big deal at stock power levels, but with additional power, more rearward c.g. becomes more of an advantage.
I'm not a fan of the AP1's rear toe change with bump, but that can be addressed...
Interesting, as the hoodline of the FR-S/BRZ is a lot higher than the S2000's. S2000 hoodline is barely above the tops of its 25" tires. I would have expected an S2000 engine to have more headroom in a twin than in its original home.
I would LOVE to have a twin with F20C/F22C power...
Old 01-15-2016, 08:49 AM   #27
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
This is the swap forum, so I won't bother to address all the issues you raised in that post, thought it pains me not to do so.
But the hoodline / headspace question you raised is valid, and here is the answer. The twins have the thick, tall front crossmember basically straight on the axle line, and steering rack immediately behind it. Any engine in there must sit atop those 2 pieces.
In the s2k, the steering rack, and the main body of the crossmember are in front of the motor. That enables the engine to sit much lower.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 01-15-2016, 11:27 AM   #28
CSG Mike
CSG Mike's Avatar
We both know weight distribution means little beyond marketing, and as you drop weight in the S2000, it becomes much more nose heavy...
F20C performance out of the FA20 discretion Engine, Exhaust, Transmission 41 06-12-2015 10:37 AM
2JZ swapped BRZ ... rh9 Engine Swaps 32 12-08-2014 01:50 AM
How many of you Swapped your 86 for 15 WRX ? Xti Scion FR-S / Toyota 86 GT86 General Forum 45 08-09-2014 09:09 AM
F20c engine Whitigir Engine, Exhaust, Transmission 4 11-03-2013 07:03 PM
BRZ Swapped with LS2 weedtank FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 09-05-2013 05:02 PM
