04-02-2014, 01:44 AM | #15 |
Drives: White MT GT86 with TRD extras
The mounting plate is part of the kit. Everything you see in the pictures is included. Or at least it is in NZ.
Some early posts complain on how expensive this upgrade is, but they obviously don't realise just how much gear is supplied. I think they look great and easy to read when I am on track. Only takes a quick glance to see if things are as they should be. Oil temp and pressure is a must! The 86's oil temp can get to over 130 deg C on the track in a very short time if you don't have an oil cooler fitted. With mine fitted it never gets past 115 C which is perfect. If the track has a long sweeper then centrifugal forces will send all your oil to one side of the sump and the pickup tube will be sucking air instead of oil. If the pressure gauge drops you know you are in this situation and then goodbye motor. Without one you will get no warning until the engine seizes and then it's too late. Alternatively, fit a baffled sump. If all you do is drive around the streets at legal speeds, then none of the above is needed. Personally I like my trackdays and so does the 86. Last edited by Tech; 04-02-2014 at 02:03 AM. |
04-21-2014, 10:40 PM | #16 |
Drives: 86
Hi Tech
May I ask you how to install the water temp sensor attachment? Can I unplug the hose without take out the coolant? The hose is easy to cut? Thank you |
04-23-2014, 01:47 AM | #17 | |
I cut the hose (removed a section) with the hose in place and it was real easy with a sharp "Stanley" knife. Not sure what they are called overseas. Then screwed the sensor into the adaptor before fitting the adaptor into the pipe. I didn't have any trouble, but some might want to remove the pipe completely and cut/fit the sensor on a workbench then reattach the pipe to the car. Everyone will have their own preference. |
04-23-2014, 03:21 AM | #18 |
Drives: 86
Thank you for your information
It is very useful I think I will remove the hose for cutting How big is the container that I need to prepare? |
07-31-2014, 05:09 AM | #19 |
Drives: 10 Series TRD
beautiful gauges. might be my last mod. I know this eliminates the head unit but curious if you figured out a way to stream music thru your phone? that's my only hangup on this mod...still tempted lol
ty
"Electrons act like photons. They are both screwy, but in exactly the same way." Richard Feynman
Wave Particle Duality |
07-31-2014, 11:18 AM | #20 |
Drives: swp mt '14 brz premium
Where are these gauges listed? I can't find them on the TRD site. Thanx for any help.
07-31-2014, 11:30 AM | #21 |
Drives: (formerly) 2013 Raven FR-S
Japanparts is one place. I used Japanparts to get that oil sandwich plate. Going to be using the innovate gauge for pressure/temperature, but I got the sandwich plate in from Japan in about 2 weeks time and it is definitely a quality piece. I'm actually suprised they sell it for only 80 bucks.
The Following User Says Thank You to malave7567 For This Useful Post: | jcw99 (07-31-2014) |
09-16-2014, 12:18 PM | #22 |
Drives: WR blue
How much is that and where did u get that?
02-04-2015, 07:02 PM | #23 |
USMC
Drives: 2013 FR-S 6-MT Raven
So your oil temp was connected through the sandwich plate? Needing a different size adapter or just tap the block. Nice setup by the way! How do you listen to music?
04-12-2015, 10:27 AM | #24 |
Drives: 2013 Sonic, 2013 BRZ ltd
Can you tell me if the wiring for the power is plug and play or if you had to splice the wires in yourself?
I was looking at the instructions online and it looks like it comes with a wiring harness that you plug into somewhere. I'm looking at installing my own gauges and was planning on using fuse taps but if there was some where under the dash you could just plug in an adapter, that would be great. |
05-16-2015, 09:46 AM | #25 |
Marine Electrician
Drives: Toyota TRD86, 2014
Sorry, but would this kit work together with the mishimoto oil cooler with thermostat`?
If it does, hello TRD kit and mishimoto oil cooler
My Toyota TRD86 can be found here:
http://www.ft86club.com/forums/showthread.php?t=63303 |
The Following User Says Thank You to Teclis For This Useful Post: | DAEMANO (05-16-2015) |
08-17-2015, 07:51 AM | #27 |
Drives: GT86
10-14-2015, 09:26 PM | #28 |
Drives: 2013 Genesis Sedan
So would the aux cable on the bottom be completely useless if we cant use the bluetooth?
Sent from my SM-G920V using Tapatalk |
Similar Threads | ||||
Cyberstork gauges | ANREX | Cosmetic Modification (Interior/Exterior/Lighting) | 53 | 08-11-2016 06:07 PM |
WTB: Gauges | AtlasMick | Engine, Exhaust, Bolt-Ons | 2 | 03-29-2013 12:04 AM |
gauges where the radio is? | J-Money | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-05-2013 10:11 PM |
GTS owners... difference between 'sports' abd 'vsc sports' button? | UnLeasHer | AUSTRALIA | 5 | 07-26-2012 03:22 AM |
Gauges | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 07-24-2010 06:26 PM |
