Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
09-14-2017, 07:11 PM | #15 |
The Fail Boat
Drives: CWP S.B.
or maybe op is burning his clutch all the time..........hmmmmm
09-14-2017, 11:10 PM | #16 |
Drives: 17 86
Is tracking your car with a stinky wheel abuse?
09-15-2017, 04:35 AM | #17 |
Drives: 2020 BRZ tS
Stink palm?
The Following User Says Thank You to LancePower For This Useful Post: | RallySport (09-16-2017) |
09-15-2017, 10:42 AM | #18 |
Drives: 2017 Halo 86
I was thinking that maybe since I'm a beginner driver this can definitely be a probable case! However, I am also under the impression that in order to burn a clutch you'd REALLY have to be letting the clutch roast on the flywheel for a good minute before you start to smell (and see) the burning, no? I may be a beginner, but I feel confident enough to say I'm not -that- bad. I spend no more than 1 second maneuvering the clutch between shifts, and my connects are 95% seamless/non-jerky. I'm also always in neutral at stops, so definitely not riding or teeter-tottering as well.
09-15-2017, 10:55 AM | #19 | |
You don't rest your foot on the clutch pedal while cruising around right? |
09-15-2017, 11:12 AM | #20 |
Drives: Subaru BRZ
09-15-2017, 12:30 PM | #21 |
Drives: 17 86
09-15-2017, 12:32 PM | #22 |
Drives: 17 86
OP, can you better describe what it smells like and under what conditions you first smell it?
Wash hands after using restroom before returning to driving. |
The Following User Says Thank You to PetrolioBenzina For This Useful Post: | funwheeldrive (09-15-2017) |
09-15-2017, 02:02 PM | #23 |
The Following 2 Users Say Thank You to Lakitu For This Useful Post: | funwheeldrive (09-15-2017), JD001 (09-15-2017) |
09-15-2017, 02:20 PM | #24 | |
On the back of my hand: - Not sweet, like fruit, candy, syrup - Not pleasing like perfume, fabric softener, lotion, deodorant, febreeze - Not strong like burnt electronics/pcb, metals, rubber - Not stinky like sewerage, excretion, rotten food/drink - Not smoky like wood, charcoal, fire - Not chemical like oil, gasoline, cleaning spray, soap, hand sanitizer - Somewhat faintly burnt material smell on skin From vents: - Somewhat earthy, like hot dirt, damp wood, old water that has been in contact with wood - Somewhat like hot sandpaper Maybe it is something factory just burning off, but my car is 15k miles at 9 months. How long does it actually take to burn off factory smells? |
09-15-2017, 02:29 PM | #25 |
The Fail Boat
Drives: CWP S.B.
the car was flooded before!......ok sorry bad joke.
But have you check with the dealer? XD |
09-15-2017, 02:35 PM | #26 |
Some more notes on my stick driving ability:
- At lower gears (1-4) sometimes I can't quite feel the biting point of the clutch, I'll equally lift off the clutch pedal slowly simultaneously pushing in the throttle. This causes the sound of the engine to gradually decrease slightly then increase as the clutch becomes fully engaged. I can avoid this sound by faster clutch engaging, but that risks having too snappy of an engagement whereas the former is smooth. I've heard other drivers do this (the sound the engine makes is very audible - you can hear the engine tone gradually decrease then increase). Is this a bad practice? - My downshifts are shamefully not always clean. Clutch engagement can often feel like it does not want to bite when downshifting from 4 to 3, or 3 to 2 (btw: I never downshift to 1) even when being as slow as possible with the clutch, and then it will unexpectedly snap into place. You can feel it was a bit of a forceful engagement with a little car jerking and foot response from the pedal. I've observed that this happens ONLY at around 3100 rpms, and not less or higher. Seems that is an awkward rpm to downshift or upshift at in this car. This is something I'm working on as a driver, but I don't know if it could be related. |
09-15-2017, 02:38 PM | #27 |
09-15-2017, 02:50 PM | #28 | |
Senior gif poster
Drives: 2013 Asphalt FRS
If it does may make it more easy to show the dealer the smell your experiencing, if the problem is mold or something in your HVAC system or vent ways. Do you keep your HVAC system on recirculate or air from the outside? |
Similar Threads | ||||
Strange Smell after Driving | ThisGuyRett | Issues | Warranty | Recalls / TSB | 31 | 10-12-2016 05:17 AM |
Does anyone else occasionally smell a burning odor during cold weather driving? | Meanderchap | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 01-10-2016 02:10 AM |
2015 BRZ: Strange smell after shifting and when driving in 1 gear for a while | hosfordbrandon | Issues | Warranty | Recalls / TSB | 46 | 11-02-2015 02:42 AM |
Which car do you think we can get our hands on first? FR-S? or BR-Z? | NWIguy | BRZ First-Gen (2012+) -- General Topics | 10 | 05-01-2012 10:24 AM |
Hands on with a BRZ | markitect | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 03-07-2012 08:26 AM |
