Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#15 |
Drives: 2013 frs base
A few years ago, there was a lot of discussion about porting the galleys on the timing covers. Anybody still doing that? I talked to Dewey at IAG about purchasing a new timing cover and possibly doing some port work. He said their oiling mods are in the block not the cover and they use the stock oil pumps.
No word yet about my engine's problem. If my guy doesn't find an obvious problem, then I'll replace the cover. If porting is still a thing, I might have it done on a new timing cover. |
#16 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (05-10-2023) |
#17 |
Generally porting only makes sense if you're running large clearances, super high RPM, and high viscosity oil. Really, it's how they did things back on 2007 and it worked OK for the time, but the knowledge and tech has improved quite a bit since then. No one does it anymore.
Larger and/or ported pumps (and passages) are more snake oil than anything. You can make a bigger improvement by adding a 20-cent washer and shimming the pump's bypass. That will net you ~2-4% improvement in flow/pressure, which really, isn't enough to save your engine vs it's natural pressure. Also, the pumps on the Suby engines (especially the FAs) are grossly oversized to accommodate the AVCS system. Under load and high RPM where flow is at its highest, only ~40% of the pump's total capacity is going through the engine. The rest is being bypassed. |
The Following 5 Users Say Thank You to KillerBMotorsport For This Useful Post: | blsfrs (05-12-2023), Compelica (05-12-2023), DarkPira7e (05-12-2023), NoHaveMSG (05-12-2023), Ultramaroon (05-13-2023) |
#18 | |
Drives: 86 GT
DIY stuff at Compelica Works
#19 |
The Following 4 Users Say Thank You to blsfrs For This Useful Post: | DarkPira7e (05-12-2023), KillerBMotorsport (05-13-2023), NoHaveMSG (05-12-2023), Wally86 (05-12-2023) |
#20 | |
Drives: 86 GT
Not great with my understanding of pumps and how the engine lubrication system works, I could be wrong but I recall seeing experiences where pressures drop after an oil cooler is installed. Where oil pressure is measured would likely play a role as well...
#21 | |
I agree that with our pump's excess volume, oil coolers should not be a problem. For that matter, refilling an oil accumulator shouldn't be of much concern either. Killer B most likely has a different opinion.(LOL) A couple of years ago, Ultramoon posted his findings on sensor location. Not a huge difference in where you measure pressure. https://www.ft86club.com/forums/show...=134863&page=7 |
#22 |
My engine guy pulled the timing cover off of my engine. Unfortunately, he did not find anything out of the ordinary other than Element Tuning putting a restrictor on the port going to the left head.
I'm going to put a new timing cover on and see what happens. |
#23 | |
If it's done correctly there should be minimal losses (1-2psi) and those should be more than made up for by the reduced oil temperatures. |
#24 | |
Observational note on the testing. Different gauges and gauge types were used. |
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post: | blsfrs (05-20-2023), Ultramaroon (05-19-2023) |
#25 |
That is a decent reduction in port size. I'd like to see the reasoning and data behind that.
#26 | |
chicken tonight
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | blsfrs (05-20-2023), KillerBMotorsport (05-22-2023) |
#27 |
Drives: 2014 Toyota 86
KillerBMotorsport, a similar method to feed the mains directly could be extremely beneficial and I imagine it has a big market if integrated into a sandwich plate. Definately something down your alley! Look into a less DIY solution for the masses.
The Following User Says Thank You to wizzo For This Useful Post: | blsfrs (05-24-2023) |
#28 |
When replacing the front cover, other than the crank/op seal, what else do I need?
I'm guessing everything else will get transferred from the old cover. |
Oil pressure | Limitless_BRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 76 | 06-08-2021 12:25 AM |
oil pressure | Legend@wheels | Engine, Exhaust, Transmission | 23 | 12-25-2018 11:45 AM |
best tire pressure gauge (tire pressure question) | steveholt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 03-21-2015 10:27 PM |
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 04:54 PM |
Oil Pressure.. too low? | Dave-ROR | Tracking / Autocross / HPDE / Drifting | 65 | 08-24-2013 12:43 AM |
