Tracking / Autocross / HPDE / Drifting What these cars were built for! |
08-14-2022, 09:18 AM | #15 | |
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
08-14-2022, 10:28 AM | #16 | |
Drives: Crapcan
The mounting on the two piece Verus unit isn’t that good. I built a bracket for mine that bolts to the lower rad support and it’s much stouter. I’ve still broken it twice and it always seems to get warped, it’s getting tossed for a homemade splitter this winter.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | DocWalt (08-17-2022) |
08-14-2022, 01:53 PM | #17 | |
08-14-2022, 01:57 PM | #18 |
Drives: Crapcan
Yes. There is not enough support at the rear is the main issue I see so it hinges on the splitter rods. I also made a plate that mounts the halves together more solidly. In the end, with the amount of wing I have it isn't enough splitter anyway.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | jflogerzi (08-14-2022) |
08-14-2022, 04:43 PM | #19 | |
08-14-2022, 04:47 PM | #20 |
Drives: Crapcan
It's pretty much the whole back edge needs better support. Mounting to the bumper cover isn't that solid and the rear mounts that go under towards the back just are not enough to handle an off into the grass or a light curb strike. I supported it with a bracket about 8" across in the middle and mounted the splitter to that support and that support to the lower rad mount.
08-14-2022, 05:04 PM | #21 | |
08-14-2022, 05:55 PM | #22 |
Drives: Crapcan
I will try to.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | norcalpb (08-14-2022) |
08-14-2022, 06:10 PM | #23 |
Drives: 2013 frs base
For my side splitters (2.0), I used 1/4" composite aluminum that I bought directly from Falken Design. There prices were good and their shipping was fast. Good source of material for the DIY crowd.
08-14-2022, 06:38 PM | #24 |
Drives: 22 BRZ limited
I have a message in to them already. I don't know if they verified for BRZ, but I'm not too far south from them.
08-14-2022, 10:15 PM | #25 |
no rush to be honest. I am wondering if they will sell me the Mounting hardware from there adjustable splitter that ties into edge support and if it would work with the 2 piece.
08-15-2022, 11:44 AM | #26 | |
Drives: Crapcan
I would imagine it would fit. If you do notice that the rear part of the splitter is sagging get it off the car and fixed ASAP or it will start to warp it. I had to heat mine up and park the box truck on it over a weekend to get it somewhat flat again.
08-15-2022, 01:41 PM | #27 | |
Drives: Track preped NA FRS
Also, I dont mount the splitter to the bumper. I mount it to the chassis, the bumper just happens to be above the splitter, resting on it. I assume anyone building a splitter would do the same. |
08-19-2022, 02:37 PM | #28 |
What's in the box?
The Following User Says Thank You to dragoontwo For This Useful Post: | norcalpb (08-19-2022) |
Similar Threads | ||||
2022+ BRZ/GR86 specific oil cooler options | CSG Mike | Tracking / Autocross / HPDE / Drifting | 0 | 07-26-2022 07:25 PM |
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 37 | 07-18-2021 03:38 PM |
Downforce for an FR-S? | HachiRo | Cosmetic Modification (Interior/Exterior/Lighting) | 40 | 08-26-2014 10:24 PM |
Scion FR-S options:what options did you have dealer installed? | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 01-06-2014 01:35 AM |
Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
