Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
05-08-2012, 01:09 PM | #15 | |
Drives: 2006 Evo IX SE
05-08-2012, 01:26 PM | #16 |
It will depend on what your expectations are.
For instance, even at the dip, the BRZ is putting down more torque than an RSX-S. I posted this graph on a different thread, but I think it helps put the dip into perspective: The BRZ makes more torque across the board, including at the dip, until 7000+ rpm. So if you think the RSX-S has adequate midrange torque for daily driving, then you'll think the BRZ is fine or even better (they're comparably geared). If you haven't driven an RSX-S, you can substitute a comparable weight/torque car, like the 8th gen Civic Si, or NC Miata. I'll also add, I drove an FR-S automatic during a 1st drive event. The dip in the torque curve was not really an issue, at least from what I could tell wringing out the car on a course in mainly 1st and 2nd gears. |
05-08-2012, 01:27 PM | #17 | |
Drives: Scion FRS Ht Lva(AT)
05-08-2012, 09:36 PM | #18 | |
Reverse Burnouts
Drives: 2013 Argento FRS
my current car is like that as well, during the 3-5k rpm range fuel duty cycles are lower than at 2.5k rpms(less fuel is going into the chamber at 4k rpms per revolution vs at 2k) this also has to do with resonance frequency of the metal, in my engine the metals vibrate the least from 3-5k rpms allowing just a bit less friction thus less fuel needed per cycle, there was a big write up about it back in 2007 when someone was doing research and trying to figure out how toyota was able to achieve that, its lost in the newcelica.org threads , i cant find it anymore...
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
05-08-2012, 10:17 PM | #19 | |
Drives: Slowly
That's the engine I want in my BRZ. |
05-09-2012, 03:32 AM | #20 |
05-09-2012, 08:49 AM | #21 |
Drives: Slowly
Self explanatory, really.
12-10-2012, 06:51 AM | #22 | |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
12-10-2012, 08:20 AM | #23 | |
Reverse Burnouts
12-10-2012, 09:03 AM | #24 |
The Answer
Drives: Mazda 2
You only feel the dip when you are at WOT. Just driving around it's really like there isn't a dip there at all. That being said, if you want to accelerate fast downshift so you're over 4K and get over with the dip. There is more than sufficient torque at low rpm for quick city driving, and it's quite smooth power delivery too.
If it wasn't for DI, the dip would creep further down the RPM, it would be worst.
06-30-2016, 05:01 AM | #25 |
Drives: 2013 stock blue
this video shows the torque dip and kinda shows how to get rid of it
[ame="https://www.youtube.com/watch?v=iM_QmVF2-fQ&index=1&list=PLHxU7q4gi5_sFJCSzL7x5zPsz4WxzuKgd "]Searching for Torque - Header & Exhaust - FR-S Long Term #4 - Everyday Driver - YouTube[/ame] |
06-30-2016, 12:20 PM | #26 |
Senior Misanthrope
The Following 3 Users Say Thank You to kch For This Useful Post: |
06-30-2016, 01:15 PM | #27 |
Although surprisingly most of the people posting to it are still active. I bet they know the way to fix it by now though.
Much funnier when somebody replies to a 4 year old post where none of the people have been active for 3 1/2 years.
06-30-2016, 03:14 PM | #28 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
We need a mod to move this post. It belongs in the engine and/or tuning forum
Similar Threads | ||||
BATHTUB CURVE ON GRAPH | alan.chalkley | Engine, Exhaust, Transmission | 12 | 06-09-2012 10:58 PM |
Increasing torque with out forced induction | BigFatFlip | Engine, Exhaust, Transmission | 54 | 05-17-2012 08:03 PM |
Do dealers re-torque lugs during PDI? | Sport-Tech | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 05-08-2012 10:54 PM |
Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 12:22 AM |
Guesses about Gear Ratios and Wheel Torque | Deslock | BRZ First-Gen (2012+) -- General Topics | 4 | 12-01-2011 06:15 AM |
