Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
View Poll Results: Oil Temperatures seen WITH and W/O Oil Cooler | |||
WITH Oil Cooler Spirited Street Driving < 195 F | 12 | 8.28% | |
WITH Oil Cooler Spirited Street Driving 195-215 F | 9 | 6.21% | |
WITH Oil Cooler Spirited Street Driving 215-230 F | 11 | 7.59% | |
WITH Oil Cooler Spirited Street Driving 230-245 F | 3 | 2.07% | |
WITH Oil Cooler Spirited Street Driving 245-260 F | 0 | 0% | |
WITH Oil Cooler Spirited Street Driving 260+ F (Oil cooler not doing its job) | 0 | 0% | |
With Oil Cooler Tracked 195-215 F | 5 | 3.45% | |
With Oil Cooler Tracked 215-230 F | 4 | 2.76% | |
With Oil Cooler Tracked 230-245 F | 7 | 4.83% | |
With Oil Cooler Tracked 245-260 F | 6 | 4.14% | |
With Oil Cooler Tracked 260-280 F | 2 | 1.38% | |
With Oil Cooler Tracked 280 + F | 0 | 0% | |
W/O Oil Cooler Spirited Street Driving < 195 F | 5 | 3.45% | |
W/O Oil Cooler Spirited Street Driving 195-215 F | 6 | 4.14% | |
W/O Oil Cooler Spirited Street Driving 215-230 F | 30 | 20.69% | |
W/O Oil Cooler Spirited Street Driving 230-245 F | 16 | 11.03% | |
W/O Oil Cooler Spirited Street Driving 245-260 F | 11 | 7.59% | |
W/O Oil Cooler Spirited Street Driving 260-280 F | 5 | 3.45% | |
W/O Oil Cooler Spirited Street Driving 280 + F | 0 | 0% | |
W/O Oil Cooler Tracked 215-230 F | 0 | 0% | |
W/O Oil Cooler Tracked 230-245 F | 2 | 1.38% | |
W/O Oil Cooler Tracked 245-260 F | 8 | 5.52% | |
W/O Oil Cooler Tracked 260-280 F | 24 | 16.55% | |
W/O Oil Cooler Tracked 280-290 F | 5 | 3.45% | |
W/O Oil Cooler Tracked 290 + F | 4 | 2.76% | |
Multiple Choice Poll. Voters: 145. You may not vote on this poll |
02-27-2013, 11:06 PM | #15 |
Drives: 2013 Firestorm FR-S
I've been monitoring the oil temps through my Scan gauge and driving home in stop and go with keeping it under 4,000rpm my temps top out at 212f. Where does the ECU read the temp? I assume that's coming out of the engine?
2013 Firestorm FR-S, MTX, build date 1/13.
02-27-2013, 11:40 PM | #17 |
Drives: ex500r
Can you make another record as well in 80-90 degree weather. This assuming it warms up before you get your turbo
02-27-2013, 11:44 PM | #18 |
Drives: 2023 WRB BRZ (MT)
so basically this is pointless for us down here if it's jus a N/A DD?
The Following User Says Thank You to lbroskee For This Useful Post: | Sportsguy83 (02-27-2013) |
02-27-2013, 11:44 PM | #19 |
Site Moderator
Drives: Stuff
Definitely IMO.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
The Following User Says Thank You to Dave-ROR For This Useful Post: | Sportsguy83 (02-27-2013) |
02-27-2013, 11:45 PM | #20 |
Drives: Perrin/VORTECH Supercharger TestBRZ
I'm installing sc in coming weeks, and will gladly try and capture same stuff, before and after oil & IC temps; logging using ECUTek which uses the factory sensor
02-27-2013, 11:53 PM | #21 | ||||
I Love custom Turbo kits
Drives: Limited BRZ
When I said I would see higher oil temps, I meant doing the same test I did today but ambient temp. at 90+. When I install the temp gauge to the oil galley I will do comparisons to the OEM sensor. Thanks for sharing your numbers! Sent from my HTC One X using Tapatalk 2
02-28-2013, 12:32 AM | #22 | |
Drives: Limited BRZ
Your numbers are prior to oil cooler or after? |
02-28-2013, 01:13 AM | #23 |
Red wine
Drives: Subaru BRZ(R.I.P)
Thanks for the results, I was actually going to try this myself once raining season gets here.
Well, not if you plan on fleeing from the popo. lol jk jk dont do it.
02-28-2013, 01:25 AM | #24 |
Drives: GT86
Why do you think an unloaded engine tells you anything about oil temperature?
02-28-2013, 01:47 AM | #25 |
Drives: Limited BRZ
02-28-2013, 02:09 AM | #26 | ||
Drives: Limited BRZ
#1) He has not been reading the forum in which vendors are saying an oil cooler is ABSOLUTELY necessary even for a DD (thus why independently test it myself on harsher conditions). #2) He didn't read my first post to see what type of tests I did. |
The Following User Says Thank You to Sportsguy83 For This Useful Post: | LeeMaster (02-28-2013) |
02-28-2013, 02:17 AM | #27 |
Drives: WRB BRZ
It would be interesting to see data of NA with oil cooler.
02-28-2013, 02:20 AM | #28 |
Drives: Limited BRZ
Tags |
oil cooler |
Similar Threads | ||||
Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 08:10 PM |
ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 04:30 PM |
One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 05:42 PM |
Best oil cooler | whitefrs | Engine, Exhaust, Transmission | 4 | 02-21-2013 11:36 PM |
Oil Cooler Location? | Captain Snooze | Engine, Exhaust, Transmission | 5 | 11-26-2012 05:02 PM |
