Old 01-20-2014, 10:47 PM   #2773
olorin
olorin's Avatar
Drives: GBS Premium
After removing the key from the ignition, my pump stays on for about a minute then shuts off. I think this is normal behavior.
olorin is offline   Reply With Quote
The Following User Says Thank You to olorin For This Useful Post:
civicdrivr (01-20-2014)
Old 01-20-2014, 10:56 PM   #2774
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by xjohnx View Post
so we just finished bolting everything up for the intercooler, and we were about ready to start bleeding the coolant, however we noticed that when you turn the car to on (without starting), the pump kicks on, which we expected, but when we turn the car off, the pump continued to run. It didn't stop until we pulled the battery. We tested again after reconnecting the battery and had the same results. What's going on? has anyone experienced this?
Mine did this too.
It did it before I turned the actual car fully on, but I also think it had to do with air still being in the system. When I first put the car to the on position, then shut it off, the pump would stay on for a WHILE. At first I thought this was normal, but once I finished getting the air out of the system and actually turned the car on, the pump would shut off after like 5 seconds.
Finish getting the air out (you will know when the pump goes silent and doesn't gurgle), then test it after turning the car on, then shutting it off.
speaking of getting the air out, my coolant was a tad bit lower, so it must have pushed out a tiny bit more air out of the lines. I topped it off today.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
civicdrivr (01-21-2014)
Old 01-20-2014, 11:25 PM   #2775
xxscaxx
Originally Posted by Pure Automotive View Post
Do you even whine bro?
Damn is that literally just from the Perrin intake on there? (Think it's Perrin)
Old 01-20-2014, 11:34 PM   #2776
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
yea that's the only thing different from every other one that we've installed, its so loud in person and on the road, pretty cool
Pure Automotive is offline   Reply With Quote
The Following 2 Users Say Thank You to Pure Automotive For This Useful Post:
CK_Bladesmith (01-20-2014), xxscaxx (01-20-2014)
Old 01-20-2014, 11:39 PM   #2777
xxscaxx
Well.. I'm jelly
Old 01-20-2014, 11:57 PM   #2778
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Pump pump pump blow blow blow blow she said.
Give a blow into the coolant bottle to add a little pressure to the system, you will hear the air move around if any in the system. Just be damn careful when you release the air do it slowly as it has back pressure into your mouth.
Believe me coolant taste yummy NOT.....
As mentioned you will hear the pump change to a smooth quiet sound when it's pumping properly.
Take a small amount of coolant with you when you first run, the car as you may need to top up on the road for the first couple of km.
Also interesting there is a small filter in your coolant bottle make sure it's clipped in properly by turning it clockwise. Heard it can interrupt the flow if not in properly.
Enjoy
Ryan86 is offline   Reply With Quote
Old 01-21-2014, 03:50 AM   #2779
Ryan86
Road Warrior
Ryan86's Avatar
Has anyone changed there plugs to a colder plug, if so what plugs did you use?
Old 01-21-2014, 04:10 AM   #2780
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Damn that sounds amazing!! I know what I buying next (as in now lol).
Area86 is offline   Reply With Quote
Old 01-21-2014, 08:20 AM   #2781
swift996
swift996's Avatar
Have you seen the level of effort for this? Seems like a pain in the rear. I wish it wasn't.
More whine? (with Perrin CAI)
[ame]http://youtu.be/o1aQICnesCI?t=55s[/ame]
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-21-2014, 08:45 AM   #2782
Ryan86
Road Warrior
Ryan86's Avatar
Ive just changed the plugs with OEM Denso at my dealership. Im hearing that i should have opted for colder plugs or closed the gap on the OEM, which is required for Supercharger.
Just trying to establish more around this and if valid.
Old 01-21-2014, 08:56 AM   #2783
swift996
swift996's Avatar
Yeah it's valid. Usually when people force induct a car they add a colder spark. From what I remember you have to basically drop the engine to change them. I could be wrong.
Old 01-21-2014, 09:06 AM   #2784
xjohnx
Grip>Slip
xjohnx's Avatar
well that's good news. I'll reflash it this afternoon and see if she starts up. does anyone know if it's safe to drive without the coolant circulating? My parents house is about half a mile away and they have the warmth of a garage that would make bleeding the coolant much easier.
Old 01-21-2014, 09:18 AM   #2785
swift996
swift996's Avatar
As long as everything is sealed, I don't see any issue with it not circulating for a short cruise. The coolant will likely heat up quick without circulation but a short drive shouldn't be a big deal. The only thing that would warm it is boost pressure, so I'd just take it easy.
The Following User Says Thank You to swift996 For This Useful Post:
xjohnx (01-21-2014)
Old 01-21-2014, 09:20 AM   #2786
utekineir
blowhard
Drives: frs, project forester
The easy way would be to raise the engine a side at a time by removing mount nut and using a block of wood and jack on oil pan. Basically if you can get the plug holes to clear the frame rails it becomes really easy
Foresters have the same heads between the frame rail situation because the subframe has spacers that lower the engine and the angle of the tie rods since the platform is basically a lifted impreza
Changing plugs is doable (at least on forester) without lifting or dropping the engine. But it pretty much requires putting things into the hole one by one, socket, extension , etc and working with 0 space, it is a big pita though compared to a typical engine.
utekineir is offline   Reply With Quote
The Following User Says Thank You to utekineir For This Useful Post:
swift996 (01-21-2014)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
