Old 01-20-2014, 01:56 PM   #2759
OrbitalEllipses
Drives: Attitude
Originally Posted by tendogy View Post
Wha?! Ah well, I will be updating nonetheless. It's not The Holy Grail, but it's still A Pretty Great Grail
Goose's car has always been a freak.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Calum (01-20-2014), wrxgoose (01-20-2014)
Old 01-20-2014, 05:33 PM   #2760
trackjunkie
Drives: Subaru BRZ Blue
Ordered the innovate with intercooler and invidia catback exhaust. The build will come next. Will make next track season more fun!
trackjunkie is offline   Reply With Quote
Old 01-20-2014, 05:54 PM   #2761
CSG David
CSG David's Avatar
Originally Posted by xxscaxx View Post
I will have intercooled dyno charts up very soon as i'm going to get dyno tuned in the next few weeks. Sooner than later.
I will basically be at the limit of this charger with a 70mm pulley and flex fuel.
Old 01-20-2014, 06:06 PM   #2762
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
[ame]http://youtu.be/2dva5Xn2MsA[/ame]
Do you even whine bro?
Pure Automotive is offline   Reply With Quote
The Following 5 Users Say Thank You to Pure Automotive For This Useful Post:
Area86 (01-21-2014), EJ33177 (01-22-2014), MadFRS (01-21-2014), powerj2 (01-23-2014), wrxgoose (01-20-2014)
Old 01-20-2014, 06:50 PM   #2763
phloozy
phloozy's Avatar
Drives: Scion FR-S
Originally Posted by swift996 View Post
I just ordered a little something...
grats! can't wait to hear what you think
phloozy is offline   Reply With Quote
Old 01-20-2014, 07:38 PM   #2764
xjohnx
Grip>Slip
xjohnx's Avatar
so we just finished bolting everything up for the intercooler, and we were about ready to start bleeding the coolant, however we noticed that when you turn the car to on (without starting), the pump kicks on, which we expected, but when we turn the car off, the pump continued to run. It didn't stop until we pulled the battery. We tested again after reconnecting the battery and had the same results. What's going on? has anyone experienced this?
Old 01-20-2014, 08:00 PM   #2765
swift996
swift996's Avatar
Originally Posted by xjohnx View Post
so we just finished bolting everything up for the intercooler, and we were about ready to start bleeding the coolant, however we noticed that when you turn the car to accessory, the pump kicks on, which we expected, but when we turn the car off, the pump continued to run. It didn't stop until we pulled the battery. We tested again after reconnecting the battery and had the same results. What's going on? has anyone experienced this?
Strange, I thought it plugs into the injector harness? That should only get power in the ON position.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-20-2014, 08:04 PM   #2766
xjohnx
Grip>Slip
xjohnx's Avatar
sorry, i meant we turned it to the on position (without cranking the car), not accessory.
Old 01-20-2014, 08:09 PM   #2767
swift996
swift996's Avatar
Yeah, we're talking the same language.
BTW - How do you bleed the air out of the intercooler system? Is there something to look for to make sure all the air is out?
Old 01-20-2014, 08:11 PM   #2768
xjohnx
Grip>Slip
xjohnx's Avatar
lots of hose squeezing, from what i hear, we didn't get that far since we ran into the pump issue and it was getting dark/cold again.
they tell you the exact amount to add (2200ML) so you will know when you're done bleeding it. also apparently the pump sounds different too.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
swift996 (01-20-2014)
Old 01-20-2014, 08:42 PM   #2769
Aza
Drives: Toyota 86 GT Manual
The pump runs when IGN is on, and also continues to run for about 30 secs after you turn it off.
Sent from my HTC One XL using Tapatalk
Aza is offline   Reply With Quote
Old 01-20-2014, 09:21 PM   #2770
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm assuming there's a replay between the injector power circuit and the pump. So, based on that, it sounds like your relay is sticking. First ensure the power to the injectors is in fact turning off when the key is turned off. Next look for continuity between the normally open contacts on the relay with it removed from the system. If both of those check out, try to simulate the problem by energizing and de-energizing the replay and ensuring it is in fact opening and closing the normally open contacts. If it's not, you'll need to replace it.
Old 01-20-2014, 09:27 PM   #2771
Calum
That Guy
A timed delayed relay wouldn't surprise me as I think it would be a good idea to help prevent shingling or whatever the term would be for screw type compressor. And I'm sorry that this is gonna come off as being a jerk, but I've got to ask if you're sure that's done intentionally, or if anyone can say they also see the same thing?
Old 01-20-2014, 10:37 PM   #2772
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Well, whatever relay it is would be the factory relay for the injectors, as the pump for the intercooler is run off of the driver side injector harness.
That's what was perplexing to us. If its normal, cool - it just wasn't expected. If it's not normal, wtf m8?
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
