Old 07-23-2015, 02:28 PM   #2661
Originally Posted by 264grendel View Post
Hey guys, not sure if my google-fu sucks or what. Thought I'd try here to find some answers. For those who have supercharged their car and have installed a wideband AFR gauge with stock headers, where are you guys mounting your O2 sensor at. I've seen a thread where they have welded the O2 bung on their front pipe right before the cat, or on their overpipe, but instructions and other people say to place the sensor before any cat. Does that mean you can't have any cats in front of the sensor including the primary to have an accurate reading. Or does it mean you just have to have it in front of a cat? So would I be good welding the O2 bung to either the overpipe or the front pipe? Any help would be appreciated.
Typically it's mounted in the front pipe, but that's because the majority of people with a wideband have also deleted their cats.
You'll want to replace the primary O2 with the wideband.
The factory sensor is pretty robust; why do you feed the need for an aftermarket wideband?
Old 07-23-2015, 02:59 PM   #2662
264grendel
Drives: 2013 Scion FR-s
Thanks for the response. Just wanted to monitor my afr's. I plan to go flex fuel in the near future. Are you saying an AFR gauge is not needed?
264grendel is offline   Reply With Quote
Old 07-23-2015, 03:10 PM   #2663
Correct; your factory wideband should be more than sufficient
Let us know when you want to order a FF kit.
264grendel (07-23-2015)
Old 07-26-2015, 01:56 PM   #2664
natsunohorumon
Drives: 2014 Subaru BRZ
I recently finished my wear in miles, but I noticed that my car squeaks a little bit when I initially put it into reverse.
Anyone know if this a symptom of a larger problem?
TEIN SRC Coilovers|VOLK Racing TE37 TTA 18x9|Dunlop Direzza Z2 SS tires|PMU Club Racers|JDL UEL Headers|Motiv overpipe|HKS Double Resonated Front pipe|Perrin 3" resonated cat back|Jackson Racing Supercharger (Tune from Elite Performance) + Oil cooler|Toms Racing JDM rear lights|Perrin license re locator | AP Racing Sprint BBK | Spiegler SS Brake Lines | SPL LCA
natsunohorumon is offline   Reply With Quote
Old 07-26-2015, 06:31 PM   #2665
Automatic? Like a belt slip squeak?
Old 07-26-2015, 10:29 PM   #2666
natsunohorumon
Yeah, it's an Auto and I thought it might be the timing belt slipping but I'm not quite sure
Is there any concerns for damage?
Old 07-27-2015, 12:13 AM   #2667
I need to hear it in person...
Old 07-27-2015, 01:58 AM   #2668
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Anybody have any ideas? http://www.ft86club.com/forums/showt...94#post2335894
ScionOfHorus is offline   Reply With Quote
Old 07-27-2015, 01:48 PM   #2669
chuccwagon
Drives: 2013 Subaru BRZ
I'm getting CEL code P2096. I think it's because of the carb tune. I had Nameless headers, Perrin catted front pipe and exhaust with stock overpipe. Everything was fine until installing the supercharger. I keep clearing the code, but it seems to pop up more frequent now. Any solutions?
chuccwagon is offline   Reply With Quote
Old 07-27-2015, 01:49 PM   #2670
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You should be running the stock header with the carb tune.
That code is cat related.
The Following User Says Thank You to Andrew025 For This Useful Post:
JDMChris (07-27-2015)
Old 07-27-2015, 02:07 PM   #2671
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
As it was already stated, the CARB tune is designed for a stock setup. You'll need a custom tune, or swap back your stock parts.
phanguy is offline   Reply With Quote
Old 07-27-2015, 03:18 PM   #2672
There's your problem. The CARB tune is made for OEM headers and OEM front pipe.
You probably never had issues before because you never really had enough flow to upset the engine. Now you do.
I recommend you get a custom tune for your setup. If you do not have any local tuners, we can set you up with a Delicious Flash-n-go.
Old 07-28-2015, 03:19 PM   #2673
Lebby83
Drives: 2019 BRZ, 2016 Touareg
Well, I have just spent the past few days on and off reading all 122 pages of this thread. Lots of great info! JR will be my choice, that is for sure.
Does anyone that has a JR SC live in or around Bucks County, PA or Mercer/Hunterdon Counties, NJ?? I would love to go for a ride in one.
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
The Following 3 Users Say Thank You to Lebby83 For This Useful Post:
Bramick (07-29-2015), CSG Mike (07-28-2015), ScionOfHorus (07-28-2015)
Old 07-29-2015, 05:39 PM   #2674
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
^^^ Add to cart. Click pay now
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following 2 Users Say Thank You to Bramick For This Useful Post:
CSG Mike (07-29-2015), Lebby83 (07-29-2015)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
