Old 07-06-2012, 12:08 PM   #253
encity5
encity5's Avatar
Originally Posted by sierra View Post
If this is the cause of the chirping, below? The simple solution to fixing the crap fuel could be to add some 2 stroke oil to the tank. The added bonus would be a slight gain in economy/power. I add 2T at 1-200 in my current 2.5 TD to compensate for the lack of lubrication in the low sulphur diesel. If I had my GTS 86 now and it was chirping I would add 100ml, that's 1-500 at the next fill up to test the theory. Good quality 2T.
FRS direct injection fule pump problems.
Just wanted to give you all a heads up. I had to replace this pump today due to the fact it was making a loud chriping noise almost like a wet drive belt. The toyota reps came out to my work and listened to it. It only happens once the temp gets to around 140f. They explained it to me as follows. The pump has a washer inside of it which if not lubercated properly it will make that noise. They said that Japan gas is way better and has more lub in it the USA gas. SO the usa gas casued the washer to not be lubed properly. There is no known fix or TSB for this. i got a new pump but keep your ears open so you can catch it and report it. Its not a preformance issue jsut an annoying sound thats all. Hope this helps.
Im not sure if this would be directly related, but the very first time i heard an audible chirp was when i added 91 octane (instead of 93)
After a long drive without any issues (in traffic) went to gas station, added 91, started the car, and heard it.
encity5 is offline   Reply With Quote
Old 07-06-2012, 12:09 PM   #254
Marrk
Drives: Honda Fit
Originally Posted by Brimford View Post
confused if your trying to be rude, this is my first performance car, and my TC never had a smell no matter how hard i drove it, so I was just commenting.
I was just kidding, bro. Sorry.
First performance cars are an exciting moment. I envy you.
New cars are likely to have numerous smells. That's normal. Old cars, as they get some dirt on them, are also liable to smell once in a while. Sometimes the heat from the powertrain will bring them out.
Marrk is offline   Reply With Quote
Old 07-06-2012, 12:13 PM   #255
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
From the sounds of sierra's report it seems that the engineers forgot that most people in the US only have 91 & did not test extensively for this =P
I can't wait to see when Toyota releases an official statement to address our concerns!
How sierra pointed out this only happening once temps reach 140f makes sense for why most people (my self included) only hear the chirping after a while of driving; what is also interesting about that statement is the insufficient lube in US gas causing the washer in the pump to start making noise; this could explain the differences of when people start hearing the noise (200mi or 900+ like others) as gas quality for 91 can even vary depending on gas station/ additives; I only started hearing the noise past 1k mileage using Chevron 91; overall sierra's post seems valid; just need an official manufacturer statement to put us all at ease =D
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
Old 07-06-2012, 01:41 PM   #256
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I think you missed the intent of his statement... he was using the comment in a completely different context than you intended as a joke.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-06-2012, 01:42 PM   #257
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Most? Not sure about that..
Mine makes the noise and I only use 93.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-06-2012, 01:47 PM   #258
Stu baru
Official Cobb beer knurd
Stu baru's Avatar
Drives: 2013 BRZ-L MT SWP
Sounds a good round of fuel and additive combination testing is in order to help prove/disprove this assertion.
Don't text while driving, everyone around you will appreciate you not endangering their lives.
Stu baru is offline   Reply With Quote
Old 07-06-2012, 01:53 PM   #259
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Just don't use the octane-in-a-bottle boosters... 93.3 won't differ much from 93
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-06-2012, 02:37 PM   #260
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Just got my car back from subaru. The regional tech rode with me and documented the tweet noise under driving condition. He said it could be related to the chirping at idle so he recommend focusing on fixing the chirping noise first. He also took the car in the garage and listen for the source of the chirping noise. He said the noise is coming from the direct injection high pressure fuel pump. He offered to order a new pump and see if that will fix the noise. I told him if it's the same pump he is replacing with I'd rather wait and see if there are any new development from corporate (maybe a new fuel pump design). He did say its a known issue and Toyota is taking the lead at finding a solution. If I hear anything new I will keep you guys posted.
Hanzo is offline   Reply With Quote
Old 07-06-2012, 02:51 PM   #261
gt86init
yoimlevinit
Drives: gt86
just a lil over 100 miles and heard it last night while warming up the car.. i didnt hear it at first not until the temp gauge needle reached the first bar and i started hearing the chirping sound.. ;( so my concern is...
does this affect the performance of the motor? could it be possibly hurting the motor or maybe running lean because of the lack of lubrication on fuel system?
gt86init is offline   Reply With Quote
Old 07-06-2012, 04:40 PM   #262
csaba
Drives: scion tc
So how is the car sounds now are you happy with the fix?
Is it sounds like when it was new
Thank you
csaba is offline   Reply With Quote
Old 07-06-2012, 04:41 PM   #263
csaba
Drives: scion tc
Originally Posted by Marrk View Post
Please, let's not respond to this.
Ha ha ha that's funny!!!
Old 07-06-2012, 04:44 PM   #264
csaba
Drives: scion tc
I'm confused now the car brings the smell of the girl out lol
If you drive it hard? Or her. Lol
Old 07-06-2012, 04:46 PM   #265
Marrk
Drives: Honda Fit
What can I say? You know I like how girls smell.
Old 07-06-2012, 04:49 PM   #266
csaba
Drives: scion tc
[QUOTE=Koji_Online;299587]From the sounds of sierra's report it seems that the engineers forgot that most people in the US only have 91 & did not test extensively for this =P
How sierra pointed out this only happening once temps reach 140f makes sense for why most people (my self included) only hear the chirping after a while of driving; what is also interesting about that statement is the insufficient lube in US gas causing the washer in the pump to start making noise; this could explain the differences of when people start hearing the noise (200mi or 900+ like others) as gas quality for 91 can even vary depending on gas station/ additives; I only started hearing the noise past 1k mileage using Chevron 91; overall sierra's post seems valid; just need an official manufacturer statement to put us all at ease =D[/QUOT
Yes I agree. Its makes a lot of sense . So maybe they will suggest to use some kind of lubricant in the gas. Especialy for ppl who use only 91 octane ,
Or use a different kind of washer in the pump.
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
What function can it be used for, the idle button place yuli8466 Cosmetic Modification (Interior/Exterior/Lighting) 50 01-29-2013 03:17 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 10:16 AM
