Old 08-04-2015, 12:06 PM   #253
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
These Maps?
MGPAX is offline   Reply With Quote
Old 08-04-2015, 01:08 PM   #254
mid_life_crisis
Drives: FR-S 10 #103 AT
Nope. This one.
It just occurred to me that I might be looking at this table incorrectly. It's possible that the ECU uses it as a cross reference where it finds the RPM and goes across to the throttle plate opening it currently is using and then goes up to read the value that has been confusing me to use that somewhere else.
Old 08-04-2015, 01:16 PM   #255
alamando
Drives: 2014 86 GT
Originally Posted by mid_life_crisis View Post
Nope. This one.
I'm guessing the true values are 0.01,0.02 ect. and it's being rounded down/up to display as is
alamando is offline   Reply With Quote
Old 08-04-2015, 01:26 PM   #256
Kodename47
Kodename47's Avatar
Drives: UK GT86
Exactly this, I have set mine to 3 d.p. to view correctly.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-04-2015, 03:07 PM   #257
mid_life_crisis
Where is this setting?
Old 08-04-2015, 06:23 PM   #258
Kodename47
Kodename47's Avatar
Drives: UK GT86
Find the scaling of that table in the definition. It'll likely be 0.0, change it to 0.00 or 0.000. You can do this for anything you want if you think the standard settings don't work. Alternatively download my OFT defs and it's all done for you
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
mid_life_crisis (08-05-2015), steve99 (08-04-2015)
Old 08-05-2015, 12:06 AM   #259
mid_life_crisis
I thought you meant a setting in Romraider. I didn't think of a variable declaration in the def.
Old 08-05-2015, 02:56 AM   #260
ATaraxias
Drives: 1994 Geo Metro Hatchback
Finally got an opportunity to post some of the datalogs from the past week showing the knock issues I've been having. Please check them out and send some suggestions my way on solutions and any potential engine popping risks.
http://datazap.me/u/ataraxias/knock-...g?log=0&data=1
Checked 02 Sensors and the MAF sensor's location in my GS intake, both are where they should be and tightened down. Could the header/exhaust cause this type of knock?
Much thanks Wanyo/Steve99,
PS: I'm seeing FLKC and MAF flux at the same time in log2. Also, 7-10% on LTFT so it is running rich as well. Ideas?
ATaraxias is offline   Reply With Quote
Old 08-05-2015, 05:26 AM   #261
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
People still don't know how fuel trims work, probably due to the focus on blind MAF scaling with tools. A LTFT value doesn't mean it's running rich. Having AFR far below target AFR when target AFR < 14.8 means it's running rich. End of story. Period. Full stop.
You shouldn't have that 2 deg FLKC at 4000 rpm. Do you have any part of your exhaust hitting bodywork at that rpm or any other noises then?
I've uploaded fuel maps that will rule out most knock due to running lean in CL.
- CL will run 0.25 leaner than OL, instead of between 0.5 to 1.0 leaner than OL. Before, when you switched from CL to OL, your AFR target could drop as much as 0.5 to 1.0.
- I don't know what side effects this can have on fuel trim learning, it should be nill.
- There may be a hit to economy.
- Once trims settle, it should feel smoother.
- There's some more fuel in the 0.8 g/rev column to deal with the knock there.
Just copy the 3 fuel maps out of it.
v84
Old 08-05-2015, 08:22 AM   #262
ollie
ollie's Avatar
Drives: GT86
Originally Posted by Wayno View Post
Roms attached to first post have been updated.
See inside zip for all changes.
- Stg2 BPB 98RON map re-made.
- E85 now using petrol MAF scale as a base which is good for about +0.25 AFR in open loop.
- E85 has slightly modified MAF scale to lean up 3.2V and 4.06V by a further +0.25 AFR.
I.e.
3.2V = 69.5 (-1%)
3.44V = 87.74 (0%)
3.71V = 112.57 (0%)
3.91V = 134.75 (0%)
4.06V = 152.05 (-1%)
Before (OTS E85 scale - flat, but hitting 11.5 AFR at 7200rpm):
http://datazap.me/u/lipton54321/v44-...22-168-189-204
I'm currently running these values for my MAF. I haven't seen another car resemble mine though, even with the exact same hardware.
3.2V = 67.4 (-4%)
3.44V = 87.74 (0%)
3.71V = 110.3 (-2%)
3.91V = 131.8 (-2.2%)
4.06V = 150.2 (-2.2%)
Before (OTS E85 scale - 11.7 at 6000rpm, 12.06 at 6800):
http://datazap.me/u/wayne/206-stg2-u...zoom=1249-1419
After (OTS PETROL scale - 12.5 down to 12.06 at 7200rpm):
http://datazap.me/u/wayne/v48-5-dry-...1934-1941-1955
Just wanted to check if you have the latest tunes for A01I? I could not find the zip file for the updated changes. I am running a GTS Auto Trans.
My setup as of Yesterday is the following.
Openflash UEL Headers, BPB, Perrin crank pulley. Does Stage 2 BPB include UEL Headers?
Sorry for the silly questions very new to all this, Steve99 on GT86 forum directed me to your post. I read through the post an have to say 60% was German to me
Thanks for all the hard work.
ollie is offline   Reply With Quote
Old 08-05-2015, 11:13 AM   #263
mid_life_crisis
Looking at that table (especially with the values expanded), it's obvious that I don't understand what's going on with this table, because the values look truly odd. Right off idle they jump up high then drop down, then do a roller coaster number (up and down, no loops) until they reach max rpm.
Old 08-05-2015, 01:46 PM   #264
Kodename47
Kodename47's Avatar
Drives: UK GT86
X Axis = % of requested torque (1 = 100% in Romraider, 0.5 = 50% etc)
Y Axis = RPM
Output = Throttle plate angle
In ECUtek the max values are 86 rather than 102 and seems to tie in better with the actual output angles, so in mine the values are all multiplied by (86/102)
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-05-2015, 04:42 PM   #265
mid_life_crisis
Y Axis = RPM
That much I could figure out. What's puzzling is that you would expect the throttle angles to go more or less smoothly up as the RPMs increase, but they don't. In fact they make some rather abrupt reversals in value.
Old 08-05-2015, 06:21 PM   #266
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's all to do with relationship of RPM vs actual torque output. You really need to combine that with the pedal to torque table to get a fuller picture
.: Stealth 86 :.
Kodename 47 DJ:
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 10:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 11:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 01:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 06:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 05:26 PM
