#253 |
Are you 20/20?
Drives: Hopes and dreams
Can't wait for some install pictures and some numbers!
#254 |
Drives:
YES!
![]() I'll be busy polishing all the piping/intercooler the next several days! __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
| The Following 3 Users Say Thank You to zeal86 For This Useful Post: |
#255 |
Drives:
I could do that!
#256 |
Weight Weenie
Drives: 15 FR-S
#257 | |
Drives: 2004 350Z
INSTALLATION_FA20 ENGINE CONTROL_ IGNITION COIL AND SPARK PLUG.pdf REMOVAL_FA20 ENGINE CONTROL_ IGNITION COIL AND SPARK PLUG.pdf |
#258 | |
Drives:
The final install will look great polished... I wished it would have come polished though... oh well... time to get to work! __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
| The Following User Says Thank You to zeal86 For This Useful Post: | new2subaru (03-01-2016) |
#259 |
Drives:
Out of the box (most of the kit)
![]() __________________________________________ Also received this today... Beatrush aluminum underpanel ![]() __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix Last edited by zeal86; 03-02-2016 at 12:26 AM. |
#260 |
Drives: 1991 Formula Red NSX
So clean! Can't wait to see the new goodies installed and all polished up.
| The Following User Says Thank You to rookie For This Useful Post: | zeal86 (03-02-2016) |
#261 |
Drives:
Started polishing today... here are some pics of the process:
![]() ![]() ![]() ![]() ![]() Almost done with one so far...There is still some pitting in the finish, especially at the bends, but I don't want to take off much more from the surface...100 times better than before though. ![]() __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix Last edited by zeal86; 03-02-2016 at 08:50 PM. |
#262 |
Drives:
Accomplished a little more today...I removed a lot of the pitting and deeper marks in the aluminum. I followed up what I did yesterday with the following grits:
- 400 (dry) Its what I had with me. - 600 (wet) - 800 (wet) - Blue Magic Metal Polish Going to continue with the following grits: - 1000 (wet) - 1500 (wet) - Blue Magic Metal Polish Should be mirror like by the time I'm done! Here are some process pics: ![]() ![]() ![]() ![]() __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix Last edited by zeal86; 03-03-2016 at 11:09 PM. |
| The Following 4 Users Say Thank You to zeal86 For This Useful Post: |
#263 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
So polishing it won't have any negative effects in terms of heat will it?
#264 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
No if anything it might help reflect a tiny bit of radiant heat. Honestly if you are worried about heat wrap everything in exhaust wrap. Won't look good but it's functional. His is going to look like sex in the engine bay but could be more functional. But I highly doubt zeal will ever need that tiny extra bit of prefomance. I much rather see him with a sexy engine bay!!
| The Following 2 Users Say Thank You to go_a_way1 For This Useful Post: | new2subaru (03-04-2016), zeal86 (03-03-2016) |
#265 | |
Drives:
| The Following 2 Users Say Thank You to zeal86 For This Useful Post: | go_a_way1 (03-03-2016), new2subaru (03-04-2016) |
#266 |
Drives:
Btw, Blue Magic metal polish leaves a silicone film that helps protect the finish.
Blue Magic Metal Polish __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
| The Following User Says Thank You to zeal86 For This Useful Post: | new2subaru (03-04-2016) |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 10:59 PM |
| Kylefrs Build Thread | kylefrs | Member's Car Journals | 14 | 01-28-2015 09:27 PM |
| Jac's BRZ build thread | Jac | Member's Car Journals | 0 | 04-30-2014 08:09 PM |
| EOJ (Not much of a Build) Thread | jonbatz01 | Member's Car Journals | 41 | 07-31-2013 08:34 PM |
