Old 05-18-2014, 03:12 PM   #253
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by SirBrass View Post
I know! So badass. What're you dynoing with the kw sc?
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
I didn't get a chance to dyno after the install and tune but I will post dyno graphs as soon as I get a chance.. since many people see similar gains with 2.5" exhaust, 92 octane and KW kit, I am guessing it should be around 260-270 to the wheels..
glamcem is offline   Reply With Quote
The Following 2 Users Say Thank You to glamcem For This Useful Post:
MINOCIN (05-18-2014), SirBrass (05-20-2014)
Old 05-19-2014, 11:22 PM   #254
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Originally Posted by glamcem View Post
what did I tell you ?
Awesome race dude. Wasn't expecting a new video that quickly.
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
glamcem (05-20-2014)
Old 05-20-2014, 08:57 AM   #255
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Not that I have exhaustive experience, but the only commercially available vented hood that I've seen is the Seibon one, and I've heard from several people with them that there's usually fitment problems with those hoods.
Would be nice if someone came out with a lightweight aluminum vented hood where proper R&D had been done for efficient venting and fitment.
Mine fits like OEM once you dial in the leveling adjusters. I also installed aero-catch pins which keep it completely stable at 130 mph.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
Old 05-20-2014, 01:52 PM   #256
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
How long do those seibon hoods last...? I like the idea of the vented aluminum hood @SirBrass brought up.
Old 05-20-2014, 02:02 PM   #257
xwd
The hood will last forever unless you damage it somehow, how it looks may be a different story. If you paint it or getting it clear coated it will look good for a long time, if not and it sees lots of sun, etc. they start to yellow. I will likely pick up a vented one, but I'll get it painted to match the car.
Old 05-20-2014, 02:14 PM   #258
CSG David
CSG David's Avatar
The turbo BRZ we are working with has a vented hood already. It was one of the first mods that was performed when the turbo was installed besides the Robispec radiator/oil cooler.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
cdrazic93 (05-20-2014), SirBrass (05-20-2014)
Old 05-20-2014, 03:14 PM   #259
sw20kosh
Drives: 2013 Black FR-S
So even with the Robispec cooling system temps are not kept in check out there in the dessert heat?
Old 05-20-2014, 03:36 PM   #260
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Location and the sheer amount of heat produced by a turbo is probably the biggest problem. EGTs out of a turbo are incredibly hot, which means the turbine housing itself is at least as hot, especially with insulative materials, and then it's exposed to that downpipe, so you have additional radiative surface area. It's like putting a space heater inside the engine bay.
Thing is, you have to keep exhaust gas velocity up to keep power. The problem is keeping that heat contained to the exhaust path without overly cooling that air. Thus the heat problem.
Unless you better isolate the hot parts by physical isolation (such as with a rear mounted turbo, or to a lesser extent a behind-engine-mounted turbo), where you can immediately shunt the exhaust gasses away from the engine bay, instead of a good bit of the hottest part of their path still be between the radiator and the engine block, the heat issue is going to continue to be a problem.
That is, unless, you can come up with a more efficient (heat and velocity converted into kinetic energy to drive the turbine wheel) turbine housing... aka, a bigger turbo running lower boost pressures (but moving more air).
However, it sounds like the constraints the customer put on CSG negate the best solutions.
So, the best they can do is the best they can do... unless you can somehow put in a kind of coolant chiller into the system that can act as a heat sink for the excess heat... even then, you still need to keep oil and coolant to at least a certain degree of heat for them to cycle well in an operating engine block...
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
CSG Mike (05-20-2014)
Old 05-20-2014, 03:56 PM   #261
diirk
diirk's Avatar
Drives: 4Runner
Catalytic convertors and the exhaust all add to the heat by increasing EGT's.
Reducing EGT's will help performance, increase longevity and reduce overall heat.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 05-20-2014, 04:32 PM   #262
kanundrum
Drives: 2013 Whiteout FR-S
0 Issues at NCCAR Tracking. Basically Hot Lapping by the end of the day in time attack format
You can see my spinout/recovery around the 4:30 Mark. Car was strong in every shift and felt amazing at WOT. I make sure to hit that 8k RPM every single time and got into 5th towards the end of the straight away. Brakes were Hawk HPS and they were horrible and over heated so I will be switching to HP Plus this week as a temp solution for this season (maybe even another brand) until I get a BBK.
[ame]http://youtu.be/ghxIto6sZt4[/ame]
Old 05-20-2014, 04:38 PM   #263
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The S in HPS is Street. HP+ is the Hawk street/track pad. I enjoyed them during my HPDE days. If you don't mind a little extra squeel then step up to the DTCs if you want to stick with Hawk. My personal favorite pad is the newer PFC 08 as it is a track pad that lasts a long time.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
kanundrum (05-20-2014), rb6freak (05-24-2014)
Old 05-20-2014, 04:41 PM   #264
kanundrum
Yah originally the format of the Track was Time Attack so I thought the pads would be fine for the 1.5 minutes we were out there, after an evo exploded all over the track everyone left and it was just me and a few other cars so we were basically hotlapping and the brakes did not care for that haha.
Old 05-20-2014, 04:56 PM   #265
Jon H
Jon H's Avatar
Drives: 2013 GT-R
I'll take that bet.
Tell me how many GT-Rs you can find that lap Buttonwillow under 2:00.
O hai.
But yeah, a lot of GT-R drivers are pretty bad. I guess it's cool that they are out there at least though.
2013 GT-R
Jon H is offline   Reply With Quote
The Following User Says Thank You to Jon H For This Useful Post:
Old 05-20-2014, 05:05 PM   #266
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
I'll be at Sebring June 7. Should be a pretty hot day. We'll see how the FBM cooling equipment holds up.
Ironsquid is offline   Reply With Quote
The Following User Says Thank You to Ironsquid For This Useful Post:
Sportsguy83 (05-20-2014)
going forced induction ft86me Forced Induction 14 02-05-2014 09:23 AM
So who is running Forced Induction and tracking their car? track_warrior Tracking / Autocross / HPDE / Drifting 88 08-20-2013 11:00 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 04:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 08:17 AM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 08:50 PM
