#15 |
#16 |
Drives: 2022 BRZ Limited
I have to disagree with some of the above comments ..yes, the tires, brakes and suspension mods make a lot of difference but I think we all have to agree that this car is very very slow in stock form simply because it doesn't make a healthy 200 hp with its torque dip... and OP already mentioned that he tracks his FRS regularly so don't you think that "address other issues before more power" line getting old?
Also "fast driver > fast car" is a very bold statement.. how much of a fast or technologically advanced car are we talking about here? sure a more experienced driver can make better lap times in his/hers slightly lesser car but I can almost guarantee you if you put a mediocre driver in a GT-R, he/she'll be always faster than your stock powered BRZ/FRS unless of course it's their very first track day or something wrong with the car simply because GT-R does everything for the driver and a lot easier to drive fast with confidence .. HP advantage makes up for the difference in many cases .. take a look at the below video that I took last week, I am pretty sure the driver in the GT3RS is a new driver or something (brake, tires) are wrong with his car since even I was a lot faster at tight corners and was able to catch him! the car pulls away like a train as soon as it sees a straightaway which makes it for the difference easily (my car is stock powered with Nitto NT01 R -comps) does that mean fast driver > fast car ? no, it only means fast driver > extremely slow driver (or fast car with a problem) ![]() [ame="https://www.youtube.com/watch?v=lvz-aYHuF44"]https://www.youtube.com/watch?v=lvz-aYHuF44[/ame] Long story short this car only lacks about 50hp ( stable hp without the dip) not some crazy amount of power but rather sufficient power to balance its weight
#17 | |
Tell me how many GT-Rs you can find that lap Buttonwillow under 2:00. |
#18 | |
So since everyone LOVES to say that their turbo setup runs cool, I'll say it again: Lets see if your turbo setup can survive 3 laps at the track with me driving. Heat is an issue. The fact that Mercedes separated their hotside and coldside is precisely why the Mercedes engines are dominating in F1 right now. They eliminated a major source of heat. |
#19 | |
Drives: Nuisance BRZ
By fast driver > fast car, I don't mean a seasoned driver in a miata will be faster around the track than a medicore driver in a gtr. What I mean by this is driving skill ALWAYS comes first. A seasoned driver will be able to utilize changes to the car much better than a medicore driver can.
#20 | |
Drives: AE86, 2x GT86, TE27
I blame the IC unit being too small. F1 comparison is strange. Boxer has hot parts on bottom cool parts on top. 70% of the heat in the engine bay is from the engine itself, not the hot parts. Just because you can overheat the car at the track doesn't make you a better driver by the way. The difference between a good driver and a great driver might be a second or two per lap, but you're only working with the same motor. A great driver doesn't magically load the engine more. The key to this car is managing the airflow. Air in air out. I can assure you that's what I'll be focusing on with my new system. I don't think it will be that hard. |
#21 |
Drives: Toyota 86 TRD Version AT
IMO, the centrifugal sc kits with FMIC (Vortech, JR, KW) seem to manage heat better than the turbo kits with the turbo located near the radiator. Before I got the Vortech, I was looking at the AVO kit. I had other turbo cars in the past and wanted to try the sc route so I went with the Vortech.
I have a buddy here with a FBM kit and he has yet to track his car because he is afraid of the car overheating. I've seen his car after some spirited runs on the street and it does run hot. Even with the supporting cooling mods. @diss7, I have been following your cars build and know you were disappointed with the bullet kit. It seems to have put you off on super chargers on this platform. I get that. But the bullet/innovate kit design seemed to be less heat efficient than the other sc kits.
#22 |
in orbe terrum non visi
Drives: violent
I'm running a gtx28 on the street at 16psi in the south with factory radiator, no oil cooler and no overheating. 8+quart oil pan filled with amsoil dominator helps.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#23 | |
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
#24 |
Drives: violent
Really? I'm fully aware of this. I was commenting because people in the same location as me making similar power are having overheating problems WITH a radiator and oil cooler but without a high capacity oil pan.
#25 | |
Drives: 2014 Scion FR-S
Sent from my GT-N5110 using Tapatalk |
#26 |
Drives: violent
Georgia, map performance.
#27 | |
![]() This is the only result that I could find where I can compare GT-R to BRZ ..it's a whopping 17 seconds faster in a 2 mins circuit ( no surprise there) ![]() http://fastestlaps.com/tracks/button...ration_13.html but I see your point on a very tight track GT-R has a lot of weight to fight with but I still doubt a stock powered BRZ/FRS can keep up with a GT-R , and like I said there are exceptions such as extremely inexperienced driver driving it..
#28 | |
you would be surprised how some young drivers are capable of, I used to think the same way then I realized we live in a different era that many youngsters can take advantage of internet and youtube to capture information a lot more efficiently than trial and error of 20+ years of driving (my case ugh)
| going forced induction | ft86me | Forced Induction | 14 | 02-05-2014 08:23 AM |
| So who is running Forced Induction and tracking their car? | track_warrior | Tracking / Autocross / HPDE / Drifting | 88 | 08-20-2013 10:00 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 03:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 07:17 AM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 07:50 PM |
